Question about Toshiba Televison & Video
DVD's won't play in a Toshiba SD-P1707SE
When trying to play region 2 DVD's in a SD-P1707SE region 2 player ther is initially some very loud disc noise which either does not end or usually results in "Not a valid disc message". These disks play well on all other dvd palyers
shaggyrat
  • 1224 Answers
SOURCE: hello i need help lol
you gotta open the disk tray and then run the code
Posted on May 28, 2008
  • 5 Answers
SOURCE: WANT TO PLAY REGION 1 DVD ON REGION 2 DVD PLAYER TOSHIBA SD370EKB
try this:
http://www.avforums.com/forums/showthread.php?t=508285
Posted on Jul 20, 2008
SOURCE: Unlock code for Toshiba SD-270EKB
dvd model SD-270EKB
1.power on dvd
2.open disk tray
3.while tray is open press 98790
the last number zero represents all regions unlocked.
Posted on Dec 26, 2008
SOURCE: Toshiba DVD SD-3980SU2 or SC2 player loads every disc as "bad disc"
Toshiba says:
Information for Owners of Toshiba SD-3980 and SD-K750 DVD Players spacer.gif To ensure the satisfaction of our customers and to maintain the integrity and quality of our products, Toshiba America Consumer Products, L.L.C. is issuing an important product update. This is not a safety issue.
Toshiba is committed to customer service and to continuously improving the quality of its products. It has come to our attention that certain DVD players bearing the model numbers SD-3980 and SD-K750 may at some point in their life stop playing discs due to a component part failure. In such case, the error message "bad" will be shown on the unit's display. Affected units will have "SU2" at the end of the model name (e.g., SD-3980-SU2), which can be found on the back of the unit.
If you own either of these models and experience the issue described above, please contact Toshiba Customer Solutions at 1-800-631-3811 for information on how to obtain a replacement unit.
Posted on Jan 18, 2009
Obertelli
  • 3006 Answers
SOURCE: I have a region 2 samsung dvd player. All of a
What follows is mostly generic advice which applies to the vast majority of DVD players which I've tinkered with.
Your problem normally only happens if someone else has played a different region coded DVD on your machine. Normally you get seven chances to reset the region code before the machine locks itself permanently to one of them. before the changes are permanent the player will usually ask you if you want to change the region code when you try to play a disc from the wrong region.
Before doing anything else it's worth asking other members of your household if they have recently used the player, especially if you know anyone may have been using imported discs. If they've used up all of the region changing opportunities then hacking the machine might not work at all.
If you use a search engine you can search for DVD-P181 hack and these will guide you through the process to make your DVD player a multi-region machine, but there are three different hacks which I've seen for the same player so you may need to try them all.
Posted on Jul 03, 2009
Model# SD-V296-K-TU Is this DVD player region free?
I do not believe this is a region-free DVD player. I believe it only plays Region 1 or All commercial discs. The manual for the SD-V296 is available from Toshiba here: http://cdgenp01.csd.toshiba.com/content/support/manuals/userguides/su2810535/SD-V296_OM.pdf .
I hope this helps.
Jul 10, 2015 | Televison & Video
Does anyone know lock code for vcr/dvd player: Toshiba SD-V394SU? I want to play a region 2 dvd. Appreciate if someone could help. Joe B.
When a DVD disc is created, it is encoded with a "Region number." The disc will only play on DVD players with the same Region number - for instance, a Region 3 disc won't play on a Region 1 player.
Region 1: U.S. and U.S. Territories, Canada
Region 2: Japan, Western Europe, Middle East, South Africa
Region 3: South Korea, Hong Kong, Taiwan, Southeast and East Asia Region 4: New Zealand, Australia, Pacific Islands, Mexico, Central/
South America
Region 5: Russia and the former Soviet Union, Africa, Indian
subcontinent, North Korea Region 6: China
The only way to get around the region codes, is to rip a DVD to your computer and remove the region code. Then burn the DVD to a DVD R. There are programs around on the net, but I'm not sure it is legal in all countries.
Google for the programs.
A DVD player sometimes allows you to change the region code once. But it not even would allow you to switch back after you changed it once.
Feb 01, 2015 | Toshiba Televison & Video
I insert a disc. It loads, then either 1 or 2 shows in the display, but nothing functions and the disc will not play. It is a region 2 disc I tried
\usually when a disc won`t play ,it just displays "No Disc".
Is the disc matching the dvd code?
Is the region code correct?
Have you checked what discs the dvd will play, in front of manual.
If those are ok the dvd must have condensation in it.
Place in a warm room,turn on and leave for 2-3 hrs
Then try again fingers crossed for you.
Dec 03, 2009 | Toshiba SD-3800 DVD Player
I cant play my moovies it will say region error how come?
Some DVD players have region coding only allowing discs to play specific to that country (or region) only . If you lucky you might find region hack online to re-program your player - just type <model number> region hack into Google. The alternative is internal modification which can be expensive - buying a region-free player would be cheaper.
Jul 10, 2009 | Toshiba SD-V394 DVD Player/VCR
Toshiba SD-P1400
what region this is set for now?
May 21, 2008 | Toshiba SD-P1400 Portable DVD Player
dvd model SD-270EKB
1.power on dvd
2.open disk tray
Apr 06, 2008 | Televison & Video
Multi Region Toshiba HD-E1 DVD
RCE Hack.
1) Turn on player
2) Open tray, put disc in tray but don´t close
3) Push T.search on remote
4) Push 1, 3, 9 and "Region number" (e.g. 1 for US discs)
5) Push T. search on remote.
You will see TEST on your player
6) Press PLAY on the remote
When player is turned off, this setting is cleared.
Mar 14, 2008 | Toshiba HD-E1 DVD Player
Toshiba SD-4900
Try this, as posted on www.videohelp.com:
Put in DVD.
When you get region whine message press: [menu] [1] [play]
Disc should play, but with region message still up.
Press Marker then Clear. Message is now gone.
You can go to the menu for setup, or keep watching the movie.
Mar 08, 2008 | Toshiba SD-4900 DVD Player
Toshiba SD-K760 region codes.
I found this on another site, worked for me, hope it helps...
icon_minipost.gifRegion code hack posted by Stratos, April 30 2006:
1. Press the Open button on your remote control to open the drive tray
2. Press the 2403960 button on your remote control
3. Press the 1 button on your remote control to change the region to 1, 2 for region 2, and so on, or 9 for multi-region playback. New region number will appear on screen.
4. Press the Open button on your remote control to close the drive tray
5. Power off the DVD player
6. Power on the DVD player
Jan 17, 2008 | Toshiba SD-K760 DVD Player
Televison & Video Logo
132 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
