Question about Brother DCP-330C All-In-One InkJet Printer
Unable to clean 46 error for a brother DCP-330C printer
  • 4,041 Answers
Error "unable to clean" on Brother MFC Hi there
Solution:
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 28, 2010
  • 1 more comment
  • Barry Oct 02, 2010
    Absolutely nothing to do with the question, its a dcp 330c not MFC you clown.
    For a dcp 330c #46 error code means your ink absorbing pad is full (usually asks you to get Brother to fix it), undo
  • alex_kwong Mar 06, 2011
    Mine is DCP330C,... should doing as below.
    After cleaned the ink absorbing pad.
    1. press following keys/buttons one-by-one (Stop/Exit), (Menu), (Mono Start), then the up arrow key 4 times. it should go into maintenance mode with black and white display.
    2. using up arrow key select 8 then press (OK) key, use up/down arrow key select 0 then press (OK) key.
    3. press (Mono) key several times till found the display like Purge:009680 (the number is count)
    4. use up/down arrow key select 2 press (OK), then 7(OK), 8(OK), 3(OK). Now the counter should reset to 000000
    5. press (Stop/Exit) key exit to maintenance mode top manual.
    6. use up/down arrow key select 9(OK),9(OK), then the display should the maintenance mode back to normal color display without the Unable to clean 46 error code.
    PS: In your country the (OK) key maybe marked as (Set) key
    Good Luck!
    Alex
  • jittoo Mar 16, 2011
    It really helps me. Thanks a lot. :-D
My printer brother dcp-330c have "unable to clean 46" problem.. the answer in your website doesn't help as i was unable to enter the maintenance mode from the instruction.. my printer does not...
I developed the same problem "unable to clean 46" on my brother dcp -330c printer.. after taking to a maintenance guy... he told me to remove my ink absorption pads and wash them out with water and leave to dry then once dry replace back in..
Apr 14, 2011 | Brother DCP-330C All-In-One InkJet Printer
My brother dcp-330c was unable to clean 46
If you are giving the error as 46 see below the error chart fix. I hope this gets you going and thanks for using Fixya. The number is 800-284-4329 What the error is saying is shown below. I copy and pasted so let me know if it doesn't show up for you and thanks for using FixYa.
Error 46 Ink absorber pad is full...replace it contact brother customer service.
46 The ink absorber pad is full and needs replacing. Please contact Brother Customer Service from "Contact Us".
Jan 26, 2011 | Brother Office Equipment & Supplies
My Brother DCP 330C says " Unable to print 4F" What does this mean and what can i do to fix it please??...... Thank you Kindest reagrds Milli
Hi millih,
An error coded 4F means that there is a mechanical problem with the printer, usually, "unable to print means one of two things. Firstly an empty cartridge, secondly a full absorbing pad. I am guessing that the latter is not the priblem as the code would be #46, so if the ink cartridges are empty, get them replaced or refilled then disconnect the machine from the power for about 5 minutes, then reconnect and it should reset itself.
Sincerely
rover620
Sep 20, 2010 | Brother DCP-330C All-In-One InkJet Printer
DCP-165C Compact Colour Inkjet Multifunction Printer: in brother dcp 165 printer the error message clean...
brother dcp-165c printer unable to clean , see troubleshooting and routine maintenance chapter in User's guide
May 16, 2010 | Brother DCP 165C Compact Color Inkjet...
Want the reset info for g46 unable to clean .dcp-330c .and would it be better to clean the waste pad as well?cheers.
Cleaning won't help as it's a counter that sets the error. It's a sealed plastic box that needs to be replaced and then reset thru service mode.Brother only gives the reset codes to authorized service centers.
Nov 27, 2009 | Brother DCP-330C All-In-One InkJet Printer
Brother DCP 330C 'unable to clean 46' printer will not print
responded to this on a error 46 post by joachim.
hth,
razors
Mar 24, 2009 | Brother DCP-330C All-In-One InkJet Printer
DCP-330C All in one
Hi. I had unable to print and unable to init 46 error. Any help available to reset my machine please. Thank you
Jul 27, 2008 | Brother DCP-110C All-In-One InkJet Printer
Brother DCP-330C All-In-One InkJet Printer Logo
1,360 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
