Question about Garland H283 Gas Kitchen Range
I had a fire in a home and the knobs got damaged beyond using and I need to get replacements and can not find them. Can you help?
  • Rick Ead
    Rick Ead May 11, 2010
    have you tried contacting directly to the manufacturer? Are the knobs dicontinued? the manufacturer willbe able to tell you if they still make the part if they dont then it may be a long search on many sites
  • 15 Answers
Try the garland website www.garland-group.com
you should be able to get them from this site if you can't find the parts you need just contact their service and parts dept.
hope this helps
Posted on Apr 30, 2010
This home had a fire 18 months ago there are heavy soot stains on the frames.
Here is a site that might help.
http://www.jondon.com/how-to/technical-tips/restoration-disaster-recovery/fire-and-smoke-damage/cleaning-soot-damaged-contents/soot-removal-from-hard-surfaces.html
Mar 04, 2015 | Motorcycles
How to get out a stuck control knob in a Ducane five burner grill
If "get out" means you are trying to remove the control knob, the Ducane knobs are simply pressed-on and pulled-off the valve stem. There is not a screw or a bolt. The control valve stem looks like a round post that has been cut so the perimeter looks like a capital letter D and there will be a hole in the bottom of the knob in the same D shape. If they will not pull free I have been able to forcibly remove a knob by using 2 screwdrivers as levers at the same time opposite one another.
Usually when someone says they have a stuck knob they are incorrectly describing a stuck control valve. Pull the knob free. If the stem of the control valve is stuck pressed in then we can usually douse it with a degreaser while wiggling it until we can slide it out and in while continuing to douse the stem with degreaser. This will get us past this one use but the actual problem is the result of some previous over-heting damage that ruined the lubrication inside the valve body.
This happens when there is a fire, when the bbq is left on overnight or when wind is blowing at the vent so convectional heat cannot escape. The heat will damage the lubrication inside the valve and will damage the gaskets and seals around the valve and manifold.
It will have to be replaced and it is very common for this to damage more than one valve so you may have to replace several although they take time to pull the grit into the ball valve and start locking up.
Oct 19, 2014 | Grilling
Had a fire in the control panel along the front where the knobs melted off. BBQ is a Grill Chef approx 4 yrs old. Took control panel off and cleaned it up. Would it be safe to continue to use or would...
Yes, there could be unseen damage to the gas manifold, that the control knobs attach too. To check this, you will need to remove the control panel cover. Turn the gas ON and paint soapy water on all the fittings. Do this with the control knobs in the OFF position. If you see any bubbles that get larger in size, that's where the leak is. Then turn each control knob one at a time and check for leaks again. DO NOT Smoke or have any open flame close by, when you do this.
Just for my own information, how did the control panel area catch fire? Was there an existing gas leak?
Hope this helped you. Please let me know. Thanks.
Jun 27, 2011 | Grilling
My knob was on fire today and fire beneath it melted knob sticking out
burner is clogged or faulty and allowing flame to "back up." If it is a Jenn-Air, call them to replace all burners. You may have a damaged valve(s) now due to the excessive flame being where it should have not been. I would not use grill until further inspection.
Aug 08, 2010 | Grilling
The control knob is stuck on my D40
You could do that, but I don't recomend it. You could damage the camera beyond repair. Take it to a local electronist or Nikon dealer for repairs and cleanings.
Apr 02, 2010 | Photography
Beyond Micro BMMDU2 250 GB external hard drive not working
It is highly unlikely that it will work. A circuit board from the same make and model hard drive would be a better choice, but I think a fire damaged hard drive would not work with a functioning circuit board. It depends upon how much heat the hard drive was subject to.
There are companies that can recover data from faulty hard drives, but it will cost you an arm and a leg for their services. Depending upon how valuable your data is, I suggest you get a quote first.
Apr 01, 2010 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
Wiring dimmer to knob and tube
You should attach the green grounding wire to the metal box using a green grounding screw. You don't want to leave the wire loose, as any contact with the switch screws could cause a short.
Also, you should wrap the switch with at least 2-3 complete wraps of electrical tape to prevent the screws from contacting the sides of the wall box.
As a side note, you should likely have a complete check done on your house if you still have knob and tube wiring installed, as the dangers associated with this very old wiring are many. Typically, older K&T wiring was used in homes well over 60 years ago and houses then only had minimal electric current drawing devices, such as lights and a couple of other small appliance devices (toasters, coffee pot, TV and radio, etc.)
The problem with older homes with K&T wiring still in use, is that the circuits can be easily overloaded with modern electric convinences and lead to a possible fire situation, especially since there is no dedicated ground to help mitigate short circuits, etc. Also, the rubber based insulation used on this type of wiring deteriorates after 40 years (+/-) and rodents tend to chew on exposed wires in attics and crawl spaces.
I don't wish to alarm anyone, but as a Licensed Master Electrician, I've seen and done my share of repair work involving Knob & Tube wiring and even had a couple of homes that had a mix of it and other, newer wiring, that I've completely rewired. Many states require K&N wiring be replaced before a home can be sold, so getting a jump on it will make your home safer and better suited to operate all the devices that people tend to have, in today's society.
Hope you find this Very Helpful and best regards!
Aug 27, 2009 | Cooper Wiring Devices 6009W-K ROTARY...
Water boiled over into control knobs for the cook top elements.
Just fixed this problem and repaired the corner of the Ceran cooktop.
Disclaimer: These cooktops run on 220V and will kill you if you don't know how to work with electricity. If you're unsure, get some help.
The boiling water slopped out of your pot, and went over to your controls (knobs) and went down the shaft and into a component call "Infinity Switch". The water caused the switch internally to weld one of the two internal sets of contact points into a permanent position. The fix is to replace the
"Infinity Switch" that the boiling water spilled into. The Infinity switch is the component that the control knob slides on to.
In my cooktop one of the infinity switches failed and appears to damage the adjacent switch. Mine actually caught on fire and damaged the wiring and the connector. Hopefully you are better off. Since they were in such close proximity I replaced them both. For $20 you might consider the same. I replaced both to be safe and they were $21.47 each.
My cooktop has 4 elements 2 small, 1 large and 1 combined (small and large) surface. A large element was definitely damaged and possibly a small element. I ordered both. I mention this in case a multi-element was damaged on your cooktop.
You will need to contact either Jenn-Air or someone. Since you can't see an exploded parts list online, you'll have to use the schematic. It is in a plastic sleeve and it stuck to the side of the ventilator housing underneath the cooktop.
When you wire the new part in, make sure you have the wiring correct or when you turn it back on you will burn up the new part.
I hope this helps.
Apr 02, 2009 | Jenn-Air JED8430 Electric Cooktop
Garland H283 Gas Kitchen Range Logo
Top Garland Kitchen Ranges Experts
John Tripp
John Tripp
Dennis Boxerman
Are you a Garland Kitchen Range Expert? Answer questions, earn points and help others
