If the cell phone senses that the charging is too strong (that is, if the charger is giving too much voltage that could make damage) the cell phone will react with a message tha tcharging is wrong or by blinking until you remove the overcharging item. Also, it could be that the battery is shorting (internally) and causing the charger to react toa short and the cell phone sense this as incorrect voltage, and thereforeis warning that something is wrong. Try the charger problem by attaching the cell phone to someone' elses phone charger and see if it continues, or if you have or can cheaply buy a car charger adapter for the cigarette lighter outlet; this will tell you if the wall electric charger is at fault or it is the battery.. if you still get the same results with the car charger, hopefully you can go to a cell store or a friend and try another battery before buying one. If a different battery does not stop the blinking, the problem is the phone.. if it is ithe phone, try turning off the phone and wait one minute before turning on.
