Question about E-Machines eMachines Desktop PC
Need help bigtime
I need to know where the pwr led , h.h.d. led and the power sw hook-up on an intel D33007 VG31 motherboard
POWER SWITCH DOES NOT START MACHINE
  • 123bob Mar 24, 2008
    power switch does not respond. no led lite, no responce at all
  • zanterific Apr 24, 2009
    When the computer is plugged in, nothing happens when I press the power button. I even tried swapping out the power supply that I know is working, but I still get 1. The machine is a T1862 E-Machines Tower.
  • 236 Answers
Are those all seperate connectors for the button? Or are they all together on one block? Should be something near bottom right hand corner of mobo saying pwr, hdd, sw, snd, led, that kind of thing
Posted on Mar 26, 2008
    New Friend:
Your cpu is loose or damaged.
Posted on Mar 27, 2013
Well I think you could look on the motherboard itself. it has a schematic for the connection. It's hard to see but it's there. I hope this would help
Posted on Dec 12, 2008
    Genius:
  • 1,913 Answers
HI
SEE *********** BORD U CAN SEE IN VERY SMALL WORD POWER SWITCH,TURBO , SWITCH
IF U CANT SEE
PUT IN HAND SCREW DRIVER
AND CHECK THE TWO NEARLY PINS ONE BYE ONE
ONE PIN IS + AND OTHER - SO IF YOUR SCREW D RIVER TOUCH THE SAME TIME TO TWO NEARLY PIN AND IF POWER IS START THEN ATTACH THE POWER SWITCH CABLE TO IT
ALSO SEE HDD AND LED CABLE NEARLY IT
Posted on Mar 24, 2008
2 Suggested Answers
SOURCE:
  • 377 Answers
SOURCE: need help bigtime
Here Mouthy22 the diagram:
If you need a manual for your MOBO just click HERE..
Enjoy!
Thanks,
Posted on Mar 01, 2008
I have an MS-7502VER:1.2 motherboard and i cannot find wher to plug the power switch into
Hi scouts692
The Front Panel Header Pin arrangement for this motherboard is unusual, in that the header only appears to have 8 pins in a single column rather 2 parallel columns of 6 Pins with 1 blank, as most conventional motherboards do.
Pin 1 is POWER SWITCH orange or red (PWR SW 1)
Pin 2 is POWER SWITCH white or black (PWR SW 2)
Pin 3 is POWER LAD + (PWR LED -)
Pin 4 is POWER LED - (PWR LED +)
Pin 5 is HARD DRIVE LED - (HD LED -)
Pin 6 is HARD DRIVE LED + (HD LED +)
Pin 7 is RESET SWITCH blue or green (RST SW/RST 1)
Pin 8 is RESET SWITCH white or black (RST SW/RST 2)
Please refer to a PDF of the Motherboard Manual for additional information about the setup of this motherboard (the relevant page for the Front Panel Header is page 17/Section 2-13)
hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it. Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can. If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa.
Sep 17, 2011 | Intel Motherboard
I need help connecting the power on cable and led cable as well as the hard drive light cable. for my emachine w3644
These cables are attached in the lower right corner of the motherboard. There are two rows of pins there. Probably 10 pins in all. They should be marked with letters something like hdled (hard drive LED), pwr (power light) pwr sw (power switch) spk (speaker) etc. Anyway, if you can't find markings, hooking the little plugs up to sets of the pins one plug at a time will tell you which works.You can't hurt anything by trying various combinations
Feb 13, 2011 | E-Machines Computers & Internet
I have a GA-81865GME-775-RH motherboard, which i put into my box, made all the connections, but have no power once I switch the box on. I suspect it has something to do with the wiring loom running from...
Hello julian_ad681
I will tell you how wire your case front panel, but before that lets test the motherboard to make sure the problem is not the board itself.
Remove all the wire connections to the front panel.
Turn the power on and with a small screw driver or anything that is metal short (touch) the two pins that are the PWR SW. (look at the list of pins I have put at the end)
If the computer turns on then it means the board is ok.
The following information is also availabe in the motherboard manual available from the gogabyte web site download section
On the motherboard next to the battery is the front panel header pins. it looks like
0 0 0 0 0 0 0 0 i also write them as numbers as well to make it easy for you)
0 0 0 0 0
1 2 3 4 0 0 0 0
5 6 7 8
1 and 2 are message LED. you don't need any connection to this.
3 and 4 are the power switch connections no polarity, just connect the wires
5 and 6 are the hard disk LED. 5 is the positive side (usually red)
7 and 8 are the reset switch. no polarity, just connect the wires.
Next to the message LED there is a three pin connection. This is for the power LED.
hope this has helped you.
please leave comment, vote if the helped
Feb 10, 2011 | Intel Motherboard
My computer is a clone, brandname Digitek, motherboard model is Pvm7 V:1.0 Mercury, it has aproblem with power switch n the motherboard has not indicated where to plug in the sw power, hdd power, led power
The connector is right below the battery, it is marked on your motherboard Panel1, the battery is the lower right hand corner of the board, ( it looks like a quarter)
Pin Signal Pin Signal
1 HD_LED_P(+) 2 FP PWR/SLP(+)
3 HD_LED_N(-) 4 FP PWR/SLP(-)
5 RESET_SW_N(-) 6 POWER_SW_P(+)
7 RESET_SW_P(+) 8 POWER_SW_N(-)
9 RSVD_DNU 10 KEY
Oct 14, 2010 | Intel Motherboard
Intel motherboard how to find power switch,led,reset,hdd switch,led
It is silkscreened on the moterboard at the bank of pins for the switches and lights. it is usuall abreviated as PWR SW, RST SW, HD LED, SPKR, PWR LED, ...If it is not silkscreened then look at the manual on the manufactures website. they will have a photo of the MB with it illistrated. go to
http://www.retrevo.com/support/MSI-K8T-Neo-FSR-manual/id/8353ci976/t/2/
Apr 22, 2010 | MSI K8T Neo-FSR Motherboard
Dont know where to hook up the power and leads on the p4m80 -m4 to get power
missed placed the manual of the m935dlu motherboard having problem hooking up the panel switches the led sw, hhd sw, reset sw, suspd led and pwr sw
Jun 29, 2009 | Biostar P4M80-M4 Motherboard
Can't Fix FRONT PANEL HEADER on my Motherboard
Here is a link to your motherboard manual:
D845PEBT2 Manual
Go to Page 33 for the Front Panel connections...with pictures. :-)
Thanks for using Fixya.
Jun 12, 2009 | Intel Desktop Board D845PEBT2 Motherboard
TRYING TO HOOK UP MU POWER BUTTON NEED TO KNOW
Hi there
The front panel connectors are mainly,
  • harddisk activity connector
  • power switch connector
  • reset switch connector
  • power LED connector
  • speakers connector
  • USB connector
Harddisk activity connector
This normally comes red in colour and is labeled as HDD-LED
Power switch connector
This comes green in colour and is labeled as POWER-SW
Reset switch connector
This usually comes grey in colour and is labeled as RST-SW
Power LED connector
This is usually green in colour and is labled as PWR-LED
Speakers connector
This speaker will give different beep sounds during boot to tell the user if there is any errors. It occupies 4 pins, however only 2 is important for the function. Be sure to connect the red coloured cable to the positive polarity and the black to the negative.
front_panel_connectors.jpg Front panel connectors pins on the motherboard
front_panel.jpg Front panel connectors from the casing
Good luck and thanks for using FixYa!!
May 13, 2009 | eMachines T6420 PC Desktop
New tower
the symbol is there writen there on the board or abrivation you can follow it.. like( pwr sw/ Hddled/ spkr..
Apr 17, 2009 | MSI K8N Neo3-F Motherboard
Need help bigtime
Enjoy!
Thanks,
Mar 01, 2008 | E-Machines T4060 PC Desktop
E-Machines eMachines Desktop PC Logo
645 people viewed this question
Top E-Machines Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
