Question about HP PSC 1315 All-In-One InkJet Printer
Printer Anamoly? Hello... Upon turning on the power of the printer, it produced a test page every single time. How do I adjust this so that it doesn't and only ptrints upon request? Thank you and all the best, Rich.
  • mebel Apr 16, 2008
    My printer is very slow. (stops on every line of print) Takes up to ten minutes to print a page with a few small graphics.
  • 975 Answers
When turning ON your printer and you hear that is going to print HIT the cancel button right away and then go to the menu see if you see a setting named DEFAULT hit that , turn off printer ,wait a couple of seconds a turn on again , it should stop printing automatically, hope it helps
Posted on Apr 18, 2008
SOURCE:
The printer is recognising that the Yellow is full but when I print out a test page the yellow doesn't print. Is this a printer or cartridge issue?
try to do deep head cleaning, few times. If this doesn't helps you need to remove the ink's and print head and bottom of print head ( where are ink nozzles ) few times press on wet cloath.
Then repeat the deep cleaning.
Aug 04, 2011 | Canon PIXMA iP4000R InkJet Printer
I have faint line printing down the center of each page. Is there something I need to clean to get rid of it?
Hi
I will assume the type of printer you have is an inkjet printer. If a single jet is not working then a single white line will be produced in the middle of the page. If one of the jets is activated all of the time then output will be produced as a single black line. Use the following steps to isolate the problem: - Replace the print cartridge - Check the flexible cabling for continuity and for short circuits between adjacent connectors - exchange the control board for a good one - finally check the power supply
Hope this helps!
Mar 09, 2011 | Office Equipment & Supplies
Can't figure out how to print test page when not connected to PC
Please follow the steps given below to perform a Self test:
1. Turn off the power by pressing the Power button once.
2. Press and hold both the Start button and the Power button.
3. Once the screen displays Mfg Menu enabled, release both buttons.
4. Press the Mode button three times. All the indicator lights will go out and the screen will display LCD button test.
5. Press the up arrow (Up arrow button) twice. The screen will display Single Test Page.
6. Press the Start button once. The self test will begin. The printer will stop once the page has printed in full.
7. Turn the printer off and then back on to disable the manufacturer menu (Mfg Menu).
Apr 05, 2009 | Lexmark X3480 All-In-One Printer
ALIGN HP 1510 printer
1Verify that the printer is turned on. If the printer is not on, check to ensure the power cord is securely plugged into a working electrical outlet, then press and release the power button one time. Wait for a few seconds while the printer powers up. Step2Lift the paper output tray. Load the letter or A4 unused plain white printer paper into the paper input tray. Lower the paper output tray. Step3Double left click the "HP Solution Center" icon to open the application. Single left click the "Help and Support" tab. Single left click the "Printer Toolbox" link. Single left click the "Align Print Cartridges" option to open the "Alignment Page" window. Single left click "Align." Step4Wait while the printer prints an alignment page. Examine the alignment page carefully and select the option that appears to be most correctly aligned. Select that option by single left clicking the corresponding option on the drop-down choices in the alignment window. Step5Single left click the "Done" button once you have entered all appropriate options. Wait while the printer prints a confirmation page. hope this helps
Jan 11, 2009 | HP PSC 1510 All-In-One InkJet Printer
Dell 540 photo printer
It might be time to, but try these first:
(1) Try rebooting the computer (Press Ctrl+Alt+Del>Shutdown>Shutdown OR press and hold the power button down on the front of the workstation/computer/tower/CPU until the unit turns OFF)
(2) If that doesn’t work, then try clearing the print queue: Start>Settings>Printers>Double-click on the printer>Right-click on the print job(s) and click cancel/delete/purge documents and try reprinting a document
(3) If that doesn’t work, then try a power cycle: Try turning the printer off, then unplug the power supply from the printer, then unplug the USB cable from the printer then the back of the computer; wait 30 second; then plug the USB cable back into the computer, then back into the printer then plug the power supply back into the printer and turn it on – run a test print
(4) Run a Test Print: Start>Settings>Printers>Right-click on the printer>Properties>Print Test Page
Jan 02, 2009 | Dell 540 Photo Thermal Printer
Will not print test page or documents
  • Make sure the printer is turned off and the paper-release lever is pushed back to the single-sheet position. Raise the paper guide upright.
  • While holding down the LF/FF button, turn on the printer. The PAUSE light flashes.
  • Slide the left edge guide until it locks in place at the guide mark. Next, adjust the right edge guide to match the width of your paper.
  • Slide a sheet of paper down firmly between the edge guides until it meets resistance. The printer loads the sheet automatically.
  • Press the PAUSE button. The printer begins printing the self test.
  • To stop printing temporarily, press the PAUSE button.
  • To end the self test, make sure the printer is not printing. Press LF/FF to eject the sheet; then turn off the printer.
Jul 04, 2008 | Office Equipment & Supplies
Keep printing test sheets
A lot of HP printers print a page to enable the print head alignment and calabration. This normally orcurs when a cartridge has been changed. If the alignment page fails then it will reprint alignment page until it can align.
So, you need to get that page it prints and place it on the glass and press scan, then it will complete alignment and be ready to rock.
See Here
Cheers
Jan 19, 2008 | HP PSC 1510 All-In-One InkJet Printer
Cannot restore the settings of printer like the tear of on the keybord... what did do to restore the settings of this printer... i cannot print  the print out is a symbol . same on the printest on the...
To do a Default Setting Mode to an Epson LX300+, you need to:
1. Power OFF the printer (for at least 10 seconds or more);
2. Press Tear Off button while simultaneously powering ON;
3. Release button, maintain power ON, printer will print basic/default settings.
At most times, it is the parallel/printer cable that gets dislodged. loosely connected or perhaps would even require replacement.
Should you want to do a printer self-test on an Epson LX300+:
Printer's Self-Test - The built-in self test function demonstrates that the printer is working properly. You can run the test with either continuous paper or single sheets; this describes the easier way, with single sheets.
* Make sure the printer is turned off and the paper-release lever is pushed back to the single-sheet position. Raise the paper guide upright.
* While holding down the LF/FF button, turn on the printer. The PAUSE light flashes.
* Slide the left edge guide until it locks in place at the guide mark. Next, adjust the right edge guide to match the width of your paper.
* Slide a sheet of paper down firmly between the edge guides until it meets resistance. The printer loads the sheet automatically.
* Press the PAUSE button. The printer begins printing the self test.
* To stop printing temporarily, press the PAUSE button.
* To end the self test, make sure the printer is not printing. Press LF/FF to eject the sheet; then turn off the printer.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Dec 04, 2007 | Epson LX-300 Matrix Printer
NO RESPONSE, PRINTER DISPLAY BLANK
sounds like you have a bad formatter....there is a way to circumvent the formatter and print whats called an engine test. this is used just to test the mechanics of the machine and leave the brain out of the equation...
Engine Test Button Location HP laserjet printer 5000 series
The engine test verifies that the print engine is functioning correctly.
The Formatter PCA is completely bypassed during an engine test.
This test is very useful for isolating printer problems. The engine test
prints a full page of lines across the entire printable area, and is also
useful for checking and adjusting registration.
laserjet-5000-engine-test.jpg Note Engine test will print from the last input tray used.
If the last input tray is empty or if the last input source was the duplexer,
then the Engine Test will print from Tray 2 (standard 250 CST).
If Tray 2 is empty (and the last input tray is empty or the last input source
was the duplexer), then the Engine Test will not function.
Printing an Engine Test HP laserjet printers 5000 series
To print an engine test, use a non-metallic object (such as a pencil) to
press the engine test button. A single test page with horizontal lines
will be printed. To print multiple test pages, hold down the engine test
button.
If the engine test prints ok then you have a formatter issue...if you have added memory or a network card try taking them out one at a time to see if the problem goes away. Otherwise the formatter will have to be replaced.
Inkworks
Sep 05, 2007 | HP LaserJet 5000 Printer
HP PSC 1315 All-In-One InkJet Printer Logo
19 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
