Question about Xerox DocuColor 12 Color Copier
Hello i have problem with docu 12 its not printing 11x17 image on 12x18 and the registration on back and front is not matching i dont know how to make business cards.
    Champion:
  • 241 Answers
Try to adjest tray 5 knob on that location
like is 11 x 17 image properly in center
if not
adjast registraion from engineer
Posted on Oct 05, 2010
Line through print
Perhaps did not specify paper thickness (check control panel and print driver).
Toner getting low.
Clean registration roller with clean damp cloth.
Aug 17, 2012 | Ricoh Aficio SP C811DN Laser Printer
How do you clean the print rollers? All my copies have a long vertical smudge/streak that runs entire length of the right side of the sheet (8.5x11 and 11x17).
It might not be the rollers but the image drum. A bad image drum will sometimes cause streaks on print outs. If you look at the right side of the image drum you will probably see a streak that matches what is being left on your paper. Be careful not to touch the image drum as it will cause fingerprint on your printouts! Of course if the image drum is bad it will need replacing and fingerprints won't matter.
Mar 01, 2011 | Ricoh Aficio AP610N Laser Printer
How do i set it to print 11x17. It jams everytime and will not print to that size
Hello :-)
Please open the paper supply tray you wish to use. At the very front of the tray, to the right, you will see a blue dial. This dial is used to tell the copier what size paper it can expect to be fed. You can put many sizes of paper in the tray, but the blue dial MUST match the size that truly is in the tray. If ,for example, the blue dial is set at "LETTER" but the paper in the tray is 11x17, the copier will look at the dial setting and expect the paper to have passed its paper path sensors in a certain amount of time. So if the dial says 8.5x11 and the actual sheet of paper fed just keeps on moving by the sensors (11x17) the copier freaks and treats it as a paper jam assuming it has fed multiple sheets. Happy New Year to you and yours! :-)
Jan 19, 2011 | Canon ImageRunner 3025 Black and White...
Ink will not fuse to the page
I have a technical bulletin on a fusing problem in this machine that may help. It requires entry into service mode and making a few adjustments. I don't like to post service mode adjustments here. If you email me, I will send you the instructions to try it.
sandman68@sympatico.ca
Mar 18, 2009 | Ricoh Aficio CL7000 Laser Printer
Konica Minolta Bizhub C350. Precut 4x6 full bleed postcards.
Hello
Yes, there is no 4x6 choice, you have to input costume size.
For the bord-less part, i first would recommend to use a little bigger costume size so if paper with is 20 mm and there is a boarder about 1-3 mm then input costume size 23 mm. Caution, this can cause a paper jam, because there is a solenoids, what read paper. or you can use a bigger paper and later cut off the boards. Because this printer is not capable printing board-less photos
Jan 21, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Dc12 copier print is some times darker and lighter
i dont understad you problem all rigth, but maybe you need a calibration, see when was the last time
Nov 25, 2008 | Xerox DocuColor 12 Printer
I Have image registration
bad transfer belt(the transparent one under the drums )
Nov 08, 2008 | Ricoh Aficio AP3800C Laser Printer
Color registration
Whenever you change the fuser unit you have to do the fuser registration.You have to use the manual feed tray with A3 or 11x17 paper for this registration.The details should be inside the new fuser box carton.
May 16, 2008 | DSC GESTETNER - DSc38u Color Printer
Printing bleeds
This machine, like almost every other laser based device on the market does not print bleeds.
The spec for the image masking at the edge is probably in the 3 to 4 mm range. When the sales person tells you that you can do "full bleed" what they are saying (even if they do not realize it) is that you can print an image larger than 11x17 onto a 12x18 sheet of paper and then trim the page back to 11x17 so that the final product bleeds over the edge.
Mar 03, 2008 | Canon imageRUNNER C3200 Color Printer
Full bleed
sure, first you need to use 12x18 paper in the bypass tray. The using your application select to print 11x17. you then cut the paper to 11x17, thats the only way to print full bleed on this system.
http://www.websitetoolbox.com/mb/copierquestions
Jan 07, 2008 | Ricoh Aficio CL7000 Laser Printer
Xerox DocuColor 12 Color Copier Logo
165 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
