Question about Kenmore 63942 Dryer
My kenmore 700 series electric dryer squeaks when running
I came home from a 7 day vacation and when we started it up it squealed like crazy. i think that some moisture got in through the discharge vent. We ran it on about 10 loads and it has improved some but still squeaking. this dryer is only about 2 years old. it does get a work our as we are dairy farmers but still expect many years of drying to come? what is best way to look inside? What screws should be removed first? Does small panel under door pop off? Hope you can help.
  • Rick Ead
    Rick Ead May 11, 2010
    are you able to check the tensioner pulley that is onthe bottom of the machine? it is located under the drum
hunter19_46m
  • 7482 Answers
SOURCE: dryer squeals and squeaks while running
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
For this FREE answer, Please rate me
Posted on Oct 04, 2010
catriver
  • 878 Answers
SOURCE: Squeak
Pinot, usually the squeak on these 417's is coming from the drum ball and plastic bearing. Sometimes they crack and sometimes just need to be greased. Go to this link http://www3.sears.com/ and enter your model number, upper left hand corner. Follow the link and click on view diagram, page 1. Look at number 12 and 34. This is the drum hitch and plastic bearing. Your husband will have to remove the top and once he has the belt off, pull up on the drum to get it off the bearing, (plastic coupling that the ball sets into. If it's not cracked and the ball is is good shape, just grease it. If it's cracked and the ball is a chewed up, replace them both. This job is done better with 2 people cause it's not the easiest deal. You can find the part numbers on the parts link right next to view diagram. Let the cat know if you need any more help, Catriver.
Posted on Jan 06, 2008
  • 184 Answers
SOURCE: DCXR463GA2WW Squeak
YOU MOST LIKELY HAVE A REAR DRUM BEARING FAILING. IT IS A SMALL TEFLON BEARING THAT SLIPS ON OVER THE REAR SHAFT OF THE DRUM AND INTO THE HOLE IN THE REAR OF THE DRYER. THERE ARE ALSO FRONT GLIDES THAT SUPPORT THE FRONT OF THE DRYER. OLDER DRYERS HAVE THE FRONT SUPPORTS UNDER THE DRUM SO THE DRUM RESTS ON THEM. NEWER G.E. DRYERS HAVE A PLASTIC RING WITH THREE TEFLON GLIDES ON TOP OF THEM AND THE DRUM HANGS FROM THESE GLIDES. REPLACE ALL OR SOME OF THE ABOVE PARTS TO ELIMINATE YOUR SQUEAK.
ON OTHER POSSIBILITY, THE IDLER PULLEY THAT KEEPS TENSION ON THE BELT CAN BECOME A SQUEAK MAKER.
Posted on Apr 08, 2008
  • 50 Answers
SOURCE: makes squeaking noise after running for about 10 minutes
there are 2 drum rollers at the back of the dryer. shut off power, pull drum and you will see 2 rubber wheels. there is a little plastis triangle that keeps the roller in place. try spinning the rollers . they probably will not spin too freely. remove triangles ,inspect inside of roller the stainless steel bearing may have gunk on it try to clean off . also check shaft roller rides likewise remove any debri use a little rubbing alcohol to remove gunk. also check the idler roller that routes the belt for the same things. good luck
Posted on Jan 30, 2009
TheMobilian
  • 8220 Answers
SOURCE: Squeaking Kenmore Stackable Dryer
Your rear drum bearing has worn through the plastic and is now hitting the metal support underneath it,
soon it will act like a guillotine and slice of the ball, the drum will fall backwards into the heating element and short to ground causing the fuse to blow the heater element to burn intwo and the whole thang will be dead in the water.
Posted on Mar 07, 2009
98 series. Why doesn't it run?
Kenmore Whirlpool Dryer Won't Start - Easy Fix - YouTube
? 3:52
https://www.youtube.com/watch?v=MhVUEhngZMg
Jul 21, 2012 - Uploaded by Bill Newberry
This video will show you what you need to check if you press thestart button on your Kenmore or Whirlpool Dryer and it does notstart up. ... the button won't start it, and putting those wires together doesn't start the dryer, what ...
What to Test When Whirlpool or Kenmore Dryer Won't Start ...
? 7:17
https://www.youtube.com/watch?v=sTRP6kHqAFs
Jan 24, 2013 - Uploaded by canyonman1963
What to Test When Whirlpool or Kenmore Dryer Won't Start orRun ... discusses all of the common causes of an electric dryernot starting or running. Category. People & Blogs. License. Standard YouTube License. Show more
Whirlpool & Kenmore Dryer Repair #02 - Won't Start or Run ...
? 7:29
https://www.youtube.com/watch?v=SPRqKVE8JfY
Oct 21, 2011 - Uploaded by canyonman1963
This video is the 2nd of several that will show you how to diagnose and repair a Whirlpool or Kenmore electric dryer that will not start or run.
Jan 13, 2016 | Kenmore Dryers
Dryer
Squealing could be a loose belt very seldom see this squeaking more than likely the drum rollers
Mar 22, 2014 | Kenmore Elite HE4 Electric Dryer
I have a Kenmore 70 Series dryer that squeaks when it runs, do I have to oil some thing?
A lot of the Kenmores start squeaking if the main bearing is starting to wear out and then it starts to rub against the frame.
Jan 18, 2012 | Dryers
I have a kenmore 70 series electric dryer that squeals or squeaks when you start it and will squeak periodically during the drying cycle. From what I can tell the actual model number is 66702692 or 110...
hello there and welcome to fixya
There is several areas that you will want to check and listen to it carefully
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them. Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn. Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
Oct 01, 2011 | Kenmore Dryers
I have a Kenmore 700 series dryer. It has been making squealing noises as it runs for the past few weeks. Today I turned it on and it worked for awhile. I put in a new load to dry it started working and...
Jan 09, 2011 | Dryers
Kenmore 70 Series dryer squeaks while tumbling - otherwise it works - what might be causing the squeak - a belt or loose screw?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Dec 16, 2010 | Kenmore 64722 Electric Dryer
My dryer started making a squeaking sound. It's
Belt needs to be replaced,have you ever had a car drive by and heard a squealing noise? dryer belts "glaze" and squeal due to wear just like the ones in your engine
Apr 01, 2010 | Frigidaire Electric Dryer
Makes squeaking noise after running for about 10 minutes
Nov 16, 2008 | Kenmore 67082 Electric Dryer
Squeak
Jan 06, 2008 | Dryers
Kenmore 63942 Dryer Logo
1,322 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
