Mypen drive has information in it but shows that it has 0 used space and 0 free space.also when double clickd tells there is no disk in drive.this happend because i manually ********** the hiddeen folder option of the folders in my pen drive.these folders got hiddend due to virus.plz answeer immidiately
  • farmin09 Apr 30, 2010
    i cudnt format nor scan it...cus it says"no disk in drive" just been sumtime i strtd using it......dnt wnt 2 thro it away
    Sergeant:
    Champion:
  • 305 Answers
Try doing a shell scan (anti virus) and see what happens other wise all you can do is reformatt the drive and as you know that will delete all info on drive.you might be able to download a program to retreive the info but i have found these to be very difficult to use.
hope this helps.
Posted on Apr 28, 2010
My dvd drive(D:) drive shows o space used free space o
Try a different blank DVD, 0 space means that is something written on that CD.
Jun 15, 2014 | Dell OptiPlex 780 MT Desktop Computer...
Transcend jet flash v33
Hi Virus or Trojans can run some process that keeps running in background. This not only harms the computer, but also prevents the pen drive from formatting as it shows that the drive is in use. Remove and re-insert the pen drive, don't double click on drive and cancel autorun operations if it starts automatically. Run a virus scan on pen drive, this will help fix the issue. Now format the pen drive.
Mar 30, 2014 | Electronics - Others
Pen drive showing 0 byte
Do not use any more and get some data recovery freeware.
Sep 14, 2017 | Transcend (589307) Media
My Transcend external harddsik when plugged show as loacal disk(H) but when I double click on it it gives msg"Disk not formatted do you want to format"Also it shows used space 0 & free space...
It's possible that your 500GB drive is damaged so the first thing to do is determine the condition of the drive. You can check if there are problems with the drive using the free trial version of http://www.hdtune.com/
If it checks out ok then you can try to recover your data with Recuva it's free http://www.piriform.com/recuva
Or if you need data recovery help this a good choice for low cost and fast data recovery. All data recovery work is performed remotely over the Internet from a boot cd that you download and the best part is they just ask for donations if you are happy with the results: http://FreeDataRecovery.us
Sep 07, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
I have a scandisk pen drive it show free space 0 kb and use space 0 kb and shows disk unusable plz help
Format the drive by right clicking on its icon and selecting format. Once in the format window, click start. This will take a few minutes and will check the disk for errors as well as format. If you encounter errors while formatting, it may be that the device is defective. Otherwise you should end up with a functioning pen drive.
Nov 02, 2009 | SanDisk Computers & Internet
It can't read or burn any data on any empty disks (CD-Rom/DVD)! but it can read any other written disks like: programs , Movies , audio disks , data disks just when I put a blank or Empty disk it seems...
Some CD burners are either "+" or "-" or both "+ -".
That said you will have to check what type of burner you have. Example, you cannot stick a "+" blank cd into a "-" burner, and visa versa.
However, if your cd burner can read and burn both types, you should be okay.
Sep 25, 2009 | LG SecurDisc 8x External Double-Layer DVD...
Pen drive is showing o bytes
I would first put it through a fast formatte then a standard formatte, then i would recommend asector scan and see if there are any sectors that are not recoverable, if they are messed up and or still not solved try to uninstall the file that has stored the recognition files for the pen drive remove the main file in c drive program files , find the file by name corresponding to what it is you have and delet it then do a full shutdown and after a full cold start reboot install pen and software when asked if you still experience this post the results and i will try to help in a higher level of tech knowledge and support
May 31, 2009 | Transcend (589307) Media
Toshiba 2 gb flash drive showing 0 disk space
You can only format these drives in mode FAT16 or FAT32.
Try to format it in FAT32 mode and let Windows choose the default sectors for you. This is the better solution.
As I can see, the operating system recognise your drive that mean the correct driver was loaded.
After a new format whith the correct params if your flash drive shows the same thing 0 disk space 0 disk space used, your drive is DEAD.
It happens if you had unplug your flash drive whithout stoping it by cliking on the icon in the notification window (near the clock), the icon is mini drive whith a green arrow. Allways unplug the USB devices by this because you have the +5 voltage on this connector and if you don't do this an arcking effect happens betwen your device and the connector.
Dec 14, 2008 | Toshiba 512MB USB 2.0 High-Speed Flash...
Hard disk problem
First u should format disk from disk management mmc snap or from command prompt.without formatting a disk's properties says 0 bytes used and 0 bytes free space.
Sep 03, 2007 | Seagate Barracuda 7200.7 (ST360014A-20PK)...
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
