Question about EnGenius DLink DWA131 IEEE 80211n (draft) WiFi Adapter WIRELESS N NANO 11NBG USB ADAPTER USB 54 Mbps
My D-link nano won't talk to my wireless modem (NB9WMAXX ADSL2+); Internet (via ethernet cable) works, and both devices seem to work, they just don't seem to recognise each other despite going through the setup routines.
2 Suggested Answers
Macs R We
  • 481 Answers
SOURCE: How to setup internet between 2 EnGenius EOC-2610 devices?
Thanks for a very thorough problem report. It's a little ambiguous near the end, though, so I will have to restate what I think I understand you are saying.
You are saying that you have your internet connection and AP in one building, and two devices or PCs in that building can access the internet and share files (though you don't specify if they are using the EOC-2610 access point or are just accessing the router in some other fashion). But you have a remote building where there is one PC and one EOC-2610 in Client Bridge mode, and although both EOC-2610 units seem to be communicating with each other, the PC will not communicate with anything. (I presume you have inspected the access point's configuration screens and verified that it does have the other EOC-2610 listed as a connected client.)
First, the PC in the remote building has to be connected to the Client Bridge EOC-2610 by its ethernet cable in order to access the network. Second, the PC in the remote building has to have a valid IP address in the range 192.168.0.0/24, or it won't communicate with anything. If you are relying on your router's DHCP to assign your PC an IP address, verify that this has happened by examining your PC network properties. If you are assigning all IP addresses manually, make sure you have assigned the PC an address, and one that doesn't duplicate some other device.
Sometimes failure to specify DNS servers appears to be a lack of communication with the network. Open a browser and type 66.70.119.204 in the URL bar. If you get to fixya.com, you have a good network connection. If you type fixya.com in the URL bar and can't get the same result, you need to define DNS servers on the PC (or inside your router).
Posted on Jun 17, 2010
Can I disable wireless and connect with ethernet cord and modem, for work do not want remove wireless cord, in the day want to be able to use my wireless.
Are you talking about direct-connecting via Ethernet to a cable or DSL modem? You shouldn't have to disable wireless to do that. If the cable modem has an open Ethernet port, you should be able to run a straight-thru Ethernet Cat-5 cable between that port and the Ethernet port on your laptop. The laptop should recognize that it is connected to the modem through the direct connection. Check the manual for the cable modem or information supplied by your ISP for connection details. You may have to do some setup on the modem to get an Internet connection, like having your ISP 'activate' the modem. Just be sure your Ethernet cable is a straight-thru, standard Ethernet cable, and not a 'cross-over' cable such as is used to transfer data between two computers.
Jul 24, 2014 | Dell Inspiron Computers & Internet
Just got a qwest pk5000z when plugged in power light stays solid green, dsl light stays solid green, then I receive Internet connection.. After about 30 seconds it resets and starts the whole process over....
Are you using the RJ45 ended Ethernet cable?
I've been battling an issue where an Ethernet cable plugged in caused the PK5000Z to reboot approximately every 120-300 seconds (2-5 minutes).
Switching to just the wireless and not having any Ethernet cables plugged in resolved the issue.
Unfortunately this won't work for me since I only use the modem as my gateway to the internet and actually have an Astaro Secure Gateway Firewall that connect to the modem via Ethernet. I'll be contacting their technical support again tomorrow as I've had 3 modems RMA'd and not a single person there at Century Link could figure out what to try except to keep RMAing them.
So anyone else hitting this issue, try using just the wireless instead of the Ethernet Cable.
Jan 24, 2012 | Computers & Internet
I have a D-Link DSBroadBand G ADSL2+router. I cannot access the internet with the ether cable plugged in. I can access the internet via wireless and the ethernet cable with a laptop. I am able to access...
I suspect that your ethernet adapter has been made 'not enabled', but can't explain how to check it since I don't know which version of windows you're running. If you can get to the Device Driver panel, you can change it there...
May 02, 2011 | D-Link ADSL2/2+ Modem/Wireless Router...
I recently moved from Cable ISP to DSL ISP service. For the DSL service, I was asked to configure my Router to use PPPoE with Dynamic IP addressing. I also provided the router with my username and password...
The reason you have no internet is because the router is specifically for cable. your description contains errors what i think you mean is that you have gone from cable dsl to an adsl, correct me if i am wrong. Basically your modem connected to your router via an ethernet cable and then the router fed the wireless signal to your wireless devices or via ethernet through the 4 ports in the back. With adsl you have a feed from your phone line to an adsl modem so the only way for you to get the dsl router working is to have two ethernet leads connecting to your pc, one from the modem to the pc and one from the pc to the router. You would also need to setup internet sharing on the pc thats connected to both devices.
Either do it that way or buy an adsl router
Nov 10, 2010 | D-Link DI-624M Router (DI624MRE)
My D link ADSL2 plus router work fine thru ethernet cable but has no wireless signal
while connected with a wire surf using internet explorer into the routers console its either at 192.168.0.1 or 192.168.1.1 (most of the time anyway) , Enter the username and pass to get in, often both are admin or admin and blank. check the wireless tab settings in there to see if its enabled and configured.
Aug 27, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Recently i am using a d-link glb-802c router modem.i have noticed that i can access net without ethernet cable & the lan led is not lit when i am using this.is this abnormal?
This is a wireless router, so yes, you should be able to access the internet without a cable. The router also only supports wired lan, not wireless.
Aug 26, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Wireless connection works fine from the d-link router but the desktop linked from the phoneline keeps going offline. Why?
You've omitted some information about your hardware & configuration & connections.
You should have:
1. cable-modem connected to cable socket (or DSL-modem connected to telephone wall-jack);
2. router connected via Ethernet cable to the cable-modem (or DSL-modem)
3. desktop computer connected via Ethernet cable to the desktop computer
4. wireless device (iPod or netbook or notebook) connected over the "ether" to the router -- this connection will stay "up" almost "forever" (as long as there is AC-power to the router and power to the wireless device).
Which parts & connections do you have?
Dec 26, 2009 | D-Link Computers & Internet
Ethernet connection of DI-524 does not work
You have to make the Ip changes on the laptop not on the modem.
You said you have internet acces on one computer. Then use that computer to find out the exact IP address used by the modem.
On the laptop use the exact same numbers, (IP, Sub mask, Gateway, Primary DNS)
and chek if it works.
If you want to have both computers on the Internet, simply change the last number on the IP address ONLY.
Please don't forget to rate this answer if it helps
Sep 22, 2009 | D-Link AirPlus DI-524 Wireless Router
My Linksys WRT54G Will Not Work.
It seems that your cabling is wrong. This is what it should look like:
  1. Telephone outlet to cable modem (Via telephone cable)
  2. Cable modem to router (via Ethernet cable)
  3. router via Ethernet cable or wireless to computers
Does your setup look like this? Please let me know if not so we can configure it correctly.
Jul 08, 2009 | Linksys Wireless-G WRT54G Router
Trying ti install my dsl-2640b wireless g adsl2+modem router
If you have plugged the ethernet cable directly into the motherboard, make sure the onboard lan is enabled in the bios, if you have plugged into a pci nic adapter you will have to install a driver for it, winxp should have the driver for your adapter other than that I cannot help any further.
best of luck
Ray Winter
Dec 30, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
EnGenius DLink DWA131 IEEE 80211n (draft)  WiFi Adapter WIRELESS N NANO 11NBG USB ADAPTER USB  54 Mbps Logo
159 people viewed this question
Top EnGenius Computers & Internet Experts
rdarell
Level 1 Expert
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
