Question about Miele Premier-Plus Built-in Dishwasher
Miele dishwasher had F85 on the screen
Miele dishwasher model G1220 i think the cycle had finished and the F85 was on the screen i have know idea what this means
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 70 Answers
Hi
On that model to save water and energy water is sent to bottom and middle spray arms alternately. This is done via a shutter in the circulation motor. F85 mean this shutter is jammed,Most likely with debris,But is possible motor is faulty
Posted on Apr 28, 2010
Does the Miele G665 dishwashers have a heat element as no heat is coming from my dishwasher
If it like other Mieles, it has an element to heat water if required to reach cleaning temperature, but does not have a drying element. Even then, it should give off some heat in the drying cycle and be hot after finishing.
Nov 17, 2014 | Miele 24 in. G665 Built-in Dishwasher
Miele g1220 dishwasher displaying F14
In my case, F14 appeared when the waste pump was not be able to exctract the waste liquids. This happened because lemon kernels (that I use to remove bad smells) has clog the non return valve and the circulation pump passage way. I followed the directions from manual to clean the valve. I found about 30 lemon kernels on the bottom of the dishwasher. After the kernels removal and valve cleaning and refitting, my dishwasher operated as usual.
Mar 11, 2012 | Dishwashers
I have Meile G1220 SC Dishwasher and it comes up with F84 and That seems to be the drain when I get that right it comes up F85. Not sure what that means. Can you help.
disconnect the pump and check for a blockage in your pump assembly or the drain hose itself the error refers to a shutter on the pump either being blocked or not opening if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations in the future Thanks Rick
Apr 16, 2011 | Dishwashers
Hi, Our Miele G611SC plus is making a high pitched noise for about 1 minute when (I think) it is on the rinse cycle. When it then changes to the next cycle, the high pitched noise stops. We got the unit...
Hey Berni,
I've been having the same problem for quite sometime with my Touchtronic G 892 SC. It goes away if I open up the cabinet under the sink and wiggle the water inlet hose where it's connected to the dishwasher's "backflow" water inlet. I'm getting ready to disconnect the fitting and see if there's lime (or some other type) of buildup in the filter screen. I don't know what else it could be. I'll try to follow-up when finished with this task.
Nov 02, 2010 | Miele 18 in. G611SC Plus Slim-Line...
My dishwasher stops and flashes up F85 can you tell me what this means please?
Fault code F85: Slide shutter signal change fault.
Defective shutter system, inside circulation pump. Circulation pump needs to be replaced.
Oct 05, 2010 | Miele Premier-Plus Built-in Dishwasher
Hi, my Miele G1142SC makes noise at startup
Mine is doing the same thing. I tried running a finish cleaner though a cycle. I did nothing I was about to do the same thing again when it just stopped doing it. What did you end up doing?
Jul 20, 2010 | Miele Dishwashers
The G638 finished its cycle but didn't completely
pump maybe on it's way out, though i doubt it, is the washing machine on the same drain out? if so you may have back wash, another could be lengh of drain hose, i had the same problem with my miele dishwasher because of the position in the kitchen i doubled up the drain hose and though it pumped out fine, with the volume of water left in the hose it came back in untill i repositioned the drain hose so it could't run back, hope this helps.
Aug 03, 2009 | Miele 24 in. G638 Plus Free-standing...
Miele g665 sc
i think its daft as well but nearly all dishwashers have this feature. you have a leak somewhere to cause this
Jun 26, 2008 | Miele 24 in. G665 Built-in Dishwasher
Miele Premier-Plus Built-in Dishwasher Logo
1,962 people viewed this question
Top Miele Dishwashers Experts
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
