Question about Cell Phones
Used blackberry 8800 (B) just arrived need to know how to turn on/how to charge in box was charger & lap-top cable only do I need anything else & where can i perchase instruction manual...reg's - ****.
  • micheal (mick) mcgowan Apr 28, 2010
    thanx very much all i need to know now is how to turn off/on & how to access the battery please/or should i just give up & stick with my 3nokia's??? reg's...****.
    very very grateful thanx ( I'm frustrated enough being disabled)...****. now please how do I remove the back to check the battery
  • 1,555 Answers
First of all you shall charge your mobile for a minimum of 12 hrs as it has came brand new and the battery must be charged otherwise it can drain to death. Here is the link for your mobile's user manual It tells you everything about your black berry.
www.vodafone.in/documents/pdfs/blackberry_8800.pdf
Posted on Apr 28, 2010
  • 1 more comment
  • Aruna Singh
    Aruna Singh Apr 28, 2010
    Instructions
    1. Step 1
      Make
      sure the battery is correctly in place and charged. Often, a user is
      unable to turn on her BlackBerry phone because the battery is either
      incorrectly placed or the phone is out of charge. Verify that the
      battery is correctly placed by removing the battery, and then placing
      the battery back in the BlackBerry so that the metal lines on the
      battery line up with the metal lines in the phone. When the battery is
      in correctly, plug in the charger and allow the phone to charge for at
      least an hour before attempting to turn it on again.
    2. Press the button with the red phone on it. This is commonly known as
      the "disconnect call" button, and is located on the upper right-hand
      side. Hold the button down for several seconds, and the phone will turn
      on.
    3. Press the BlackBerry button (the button with seven dots on it). Scroll
      through all of the icons until you find the "Options" icon. This is an
      image of a wrench. Select the "Options" icon, and scroll down to "Auto
      On/Off." After selecting "Auto On/Off," you can specify which times you
      want your phone to automatically turn on each morning. Choose the
      "enable" option on the pop-up menu, and save changes. This will allow
      you to turn the phone on each morning with no effort.
  • Aruna Singh
    anything more.
  • Aruna Singh
    Aruna Singh Apr 29, 2010
    push the silver button then pull up from the slot on the top of the phone.
My blackberry 8800 will not charge even when i put in a new battery !!
First Option:Please change The Phone Bettery and charger and check The check The Phone charging
IF Charging Problem will Not Solved So
Secend Option:Your Phone charging IC Fault SO Please change charging IC And charging Problem will SOlved
thanks.
Jun 21, 2010 | RIM BlackBerry 7250
I need MEP code for blacberry 8800...
Hello
You have to unlock that BB first
This unlock code provider generate full LEGAL unlock code direct from Blackberry server which wont void your warranty, & generate code based on your IMEI, means individual code for every blackberry set.
After unlocking from this provider's code your blackberry not only work with single network, you can use your in any part of world with any network including your browser & MMS picture messaging to work, yes with just one time entering code from your keypad.
They unlock from network who locked your blackberry
This site will help you a lot & good email & 24/7 phone support
http://blackberryimeiunlockcodes.com/
May 04, 2010 | RIM BlackBerry 8800
Blackberry storm charging problem is plugged into the computer to
I've had this problem just since the last software upgrade. New charger, cable & battery haven't solved it.
Dec 14, 2009 | RIM BlackBerry Storm 9530 Smartphone
Why will my phone not power on? The let stays solid while charging but will not power on
are you trying to charge the phone with the wall charger or the USB cable. if it is the USB cable then chk if the USB port both on the laptop and the hand held is faulty or not, then chk if the USB cable is faulty or not. if you are to charge through the wall charger then check if the charge is faulty if every thing this is fine then get chk the battery.
Aug 07, 2009 | RIM BlackBerry 8800
My BlackBerry won't charge, and I think it is related to the phone and not the charger. Any troubleshooting tips?
Its the problem with the battery. Soo try getting a new one. Its not the charger,
Good Luck!!
Aug 06, 2009 | RIM BlackBerry 8800
Blackberry 8800 will not charge on wall charger
You need to find out if the problem is with your current AV charger - the battery or the phone.
Clean the battery and the metal connection with a dry cloth, and try to charge using a USB charger.
May 21, 2009 | RIM BlackBerry 8800
Blackberry 8800 The screen is black. The alert light flashes red.
MY BLACKBERRY 8800 POWERS UP TO A BLACK SCREEN.
TRIED A DIFFERENT SCREEN BUT STILL SAME PROBLEM.
DOES ALL NORMAL AND USUAL NOISES FOR A WORKING PHONE, SIDE BUTTON START THE VOICE COMMAND BUT STILL CAN'T SEE ANYTHING.
SO PLEASE HELP, IS IT TIME TO LET GO OR CAN STILL BE SORTED?
Feb 25, 2009 | RIM BlackBerry 8800
How do you turn on a blackberry 8800?
If the battery is fully charged, it should turn on by pressing the button with the red phone reciever on it. Its to the right of the trackball next to the bent arrow button.
Dec 25, 2008 | RIM BlackBerry 8800
Cell Phones Logo
32 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
