Question about Candy 24 in. CD950 Free-standing Dishwasher
Dishwasher trips out when 1/3 way through a cycle
  • 1,998 Answers
By trips out do you mean shuts off completly?or do you mean it trips off the breaker? check the electical connections on the bottom right corner if this is connected properly then you have a control board or wiring problem and it might be better to call a technician
Posted on Apr 28, 2010
Electrolux dishwasher tripping on drying cycle
Good Afternoon friend, thank you for your post!
From my understanding your Electrolux dishwasher is tripping your circuit breaker during the cycles. This could be a wiring issue within your dishwasher and you may need to have a professional technician come out. The technician will have the appropriate tools needed for pinpointing the issue within your dishwasher. Best of luck! -Matt
Feb 11, 2015 | Electrolux Dishwashers
Dishwasher trips out after running for a while
When you say "trips out" do you mean the circuit breaker trips? If so the breaker in the electrical box may be bad. Also do you have anything on that circuit pulling high amps when the dishwasher is running? Also when does it "trip out" during a pump cycle or when the heating element cycle starts?
If the pump does not work at all then the pump may have went out. If it happens when the heating element cycle starts then it may be the circuit is overloading or the breaker is bad.
Oct 14, 2014 | Smeg Dishwashers
Tripping during was cycle
Wash motor does not run during dry cycle. Wash pump motor pulling too much current. May need to replace motor.
Apr 30, 2014 | Beko Dishwashers
Westinghouse dishwasher sb916sk runs 22 minutes then cuts power
Is it on a dedicated circut? A dishwasher needs to have a 12Ga two conductor with ground line that is dedicated to ONLY the dishwasher and possibly share with the garbage disposal.
Also, it should be on a 20 Amp breaker.
Mar 11, 2014 | Westinghouse Dishwashers
Power trips 1-2 secs after on button pressed. Been
hi - i would tend to think that theres an electrical problem with the machine, as most dishwashers will start with the drain operations before commencing any cycle - the drain pump may well be the cause..
Cheers
Jul 08, 2011 | Electrolux EIDW6305GS Builtin Dishwasher
Dishwasher won't drain and trips out
call cda they will repair it for £79 01949862000
Mar 10, 2010 | Dishwashers
Motor does not stop running
problem may be final rinse cycle not happening.
1)check the boiler heater problem.(thermostat trip)
Jan 07, 2010 | KitchenAid Dishwashers
Tripping the breaker
How far into the cycle does it trip the breaker?Does the motor run then trip it?Is it at the end of the cycle when it goes to a dry cycle?Does it trip in the beginning when it fill's up with water?
Mar 19, 2009 | Dishwashers
My dishwasher trips out on certain cycles
sounds like faulty wiring inside unit. your circuit breaker is detecting an overload current condition...must look inside for wire touching frame. if none found, then wire fault may be inside of a device like motor or solenoid, so check these with ohmeter to ground-each wire (except chassis gnd) must be isolated from ground.
Jun 05, 2007 | Ariston Technologies L63SNA Stainless...
Candy 24 in. CD950 Free-standing Dishwasher Logo
140 people viewed this question
Top Candy Dishwashers Experts
Charles T Nevin
Charles T Nevin
 Evgeniy_Getz
Evgeniy_Getz
Are you a Candy Dishwasher Expert? Answer questions, earn points and help others
