Question about HP Photosmart 3210 Printer
My HP 3210 printer has suddenly started to print badly. All colours are mixed up and/or missing - but not consistant
  • vanbarr Apr 29, 2010
    The printer has now settled down and seems OK. I suspect that I was using photo paper too thick with a duplexer attached and paper fouled the printing heads
  • 4,041 Answers
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Apr 28, 2010
Hp 3210 not printing magenta and leaving large quantities of magenta ink in printer blobs on right side of paper
defective cartridge; make sure you buy ANY cartridge from a REPUTABLE, not cheap, cartridge company.
Dec 24, 2012 | HP Photosmart 3210 Printer
I have a hp 6500. It has started printing pink instead of black.
Either:
* printers mix in a bit of "colour" ink when you request BLACK,
so that the colour ink-jets do not dry-out. So, since your BLACK has become EMPTY, all you get is PINK,
or,
* some printers mix colours to produce BLACK-ish colour.
Check that your CYAN and YELLOW ink-cartridges have not gotten to be EMPTY.
Jul 17, 2010 | Office Equipment & Supplies
Printer HP Deskjet D1460 prints pink"..Instead of Black
The printed colours are an "additive" mix of the "primary" colours in your printer.
So, when the colour ink-jet cartridge is "out-of-ink" on one (or more) of its colours, the "mix" will be off, and the "wrong" colour will be the result.
Change the colour cartridge.
Before changing it, run a "deep-cleaning" cycle, using the HP Support software that was installed when you installed from the CD-ROM that came with the printer, to "clean" any/all "clogged" ink-jets -- i.e., a clog could be preventing one colour of ink from being sprayed onto the paper.
Apr 08, 2010 | HP DeskJet D1460 InkJet Printer
Colour problem
If the printer gives magenta instead of red you have a problem with one of the other colors. Magenta needs other colors to print red. Print a cofiguration print and check witch color is bad or missing. Replace the cartrridge of the missing/bad color
Dec 24, 2009 | HP LaserJet 3000n Printer
Colour cartridge missing but I only want to print
No you cannot. Each one of your cartridges is smart chipped. When this cartridge registers as empty it acts as an on/off switch thus turning the printer off.'
You need to replace the empty cartridge in order to print.
Go printer settings and check option to print only black.
Jul 30, 2009 | HP Photosmart 3210 Printer
Hp psc 1350 colour printing problems
Sir,
Check this link to solve the problem
link 1
Link 2
Thanks Good Luck
Appreciate to rate as "Fixya"
Apr 28, 2009 | HP PSC 1350v All-In-One InkJet Printer
HP 3210 Multi-page print problem
Dear Martin Luke,
Take a look at the posts on "black ink problem" on this site. There are 9 offers of solution.
Many of us with this defectively-designed model have the same problem. Some say the answer is to do with button pressing, but action may need to be more radical and messy, and involves forcing the blockage out of the ink feeder tube etc.
Dec 30, 2008 | HP Photosmart 3210 Printer
Print will not print in color when using word 2007
hi have you check the propertie when printer to makesure is not set to due to not in colour
have a look if not sure let me know
cheers
Dec 09, 2008 | HP Photosmart 3210 All-In-One InkJet...
Cartridge
did you do a clean cartridge and re alignment first?
http://tinyurl.com/6qcpgy
Aug 08, 2008 | HP PSC 1410 All-In-One InkJet Printer
HP Photosmart 3210 Printer Logo
112 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
