Question about GE Spacemaker JVM1640SJ Microwave Oven
What is the wattage?
What is the wattage for GE microwave JNM1731DM1BB?
  • GE Master
  • 9,047 Answers
Oddly, the owner's manual doesn't say.
You can contact GE customer service here, or if it's working properly, here's a test that will tell you how much output power it has:
MICROWAVE HEATING POWER TEST
The following test will provide a suitably accurate measurement of the output power of any microwave oven. Variations or errors in performing this test will produce uncertain results. If the line voltage (from the electrical outlet) is low, the magnetron output will be correspondingly low.
Equipment needed:
- Microwave safe container with 1000 mL (1 Liter) gradation.
- Fahrenheit or centigrade thermometer
Procedure:
Pour exactly 1000 mL (1 Liter) of cool tap water into the container. Using the thermometer, stir the water, then measure and record the temperature. For accurate results the water should be about 60 degrees F (20 degrees C).
Place the container on the center of the oven cooking shelf (do not leave the thermometer in the container and remove any metal racks), and heat the water (at full power) for 63 seconds. Use the second hand of a watch, not the oven timer.
After the heating time is completed, immediately remove the container, stir the water, re-measure and record the temperature of the heated water.
Subtract the starting water temperature (step 2) from the ending water temperature (step 3) to obtain the temperature rise.
To determine the output power in watts, multiply the total temperature rise by a factor of 38.75 if you're using a Fahrenheit thermometer or by 70 if you're using a centigrade thermometer.
Posted on Apr 28, 2010
Product is GE Microwave (Spacesaver-type) JNM1731DM1BB. New surface light bulbs installed. Unable to turn them off or change from bright to dim
Bottom lights are controlled through relays on the main control board which is mounted on the back of the touch pads (control panel).You can check and see if wires are touching each other on the board but my guess is the board is defective and needs replaced.
Apr 02, 2015 | GE Microwave Ovens
GE microwave model PVM1790DR1BB what is the wattage.
Hi Augusto
According to the manufacturer, the wattage is 1000.
http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=PVM1790DRBB&omni_key=FBRRApp
In case you need the owners manual, see the link below.
Hope this helps you out.
-Steve
PVM1790DR1BB GE MICROWAVE Manual
Mar 17, 2015 | GE Microwave Ovens
What is the wattage output of my GE Spacemaker Microwave model JVM1850SH02
The JVM1850SH microwave has a maximum power output of 1100W.
I hope this helps.
(The final two digits are not critical for the microwave's specifications.)
Mar 06, 2015 | GE Microwave Ovens
What is the wattage of the Ge microwave JVM1331WW 005
what is wattage of ge microwave JVM1331WW005
Feb 13, 2014 | Microwave Ovens
Jnm1731dm1bb
For model JNM1731DM1BB, there's no reset. Your membrane keypad is failing and has to be replaced.
On this model, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
It is part number WB07X11033 and you can order it from the Pros here for $148.66 (subject to change).
You can find helpful exploded view diagrams and order other parts at that link, too.
There is a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move your circuit board into the new frame.
Be careful, the display is made of glass.
Oct 26, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Shorted out microwave when i tried tochange lightbulb. GE model jnm1731dm1bb, where is the fuse located?
The fuse is probably located behind the grille, and it may again be behind a small panel behind the grille. Look for the fuse label when you get the grille off.
There is a video here which shows you how to remove the grille.
But chances are good that you also damaged the circuit board when you removed or inserted the bulb without first unplugging the oven, as it says on the label by the light socket.
But that can usually be repaired economically repaired.
Or you can order and install a new smart board.
For model jnm1731dm1bb (also called JNM1731DMBB01) it is part number WB27X10933 and you can get it from the Pros here for $151.56.
Aug 10, 2013 | Smeg MD6CAS Microwave Oven
JNM1731DM1BB
There may be a short in the keypad, or it is the microcontroller board.
Mar 13, 2012 | GE Microwave Ovens
Can not determine the wattage of the microwave we bought. It is a GE microwave model #JNM1851DM4BB
There is no reference to this model on the GE website, but have a look at this webpage:
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?Name=340104_jvm1851bhchshwh_r3.pdf&RequestType=PDF
The wattage of this model JVM1851 is 1100W.
If the model is a counter top unit, you can check whether there is a plate at the back of the oven with the wattage on it.
Feb 26, 2011 | Microwave Ovens
G e microwave model JNM1731DM1BB apparently working, but seems not to go off when time is up,tho' bell chimes. Will not go off unless door is left open. Light also stays on.
you have a micro switch stuck open which is causing unit not to shut off, until open, it will be probably the monitor switch located at top switch or the bottom
Feb 23, 2011 | GE Microwave Ovens
F3 Message given from my GE jvm1650wb008 Microwave!
WATTAGE AND CU.FT IS UP TO YOU. JUST MAKE SURE WHAT YOU GET FITS LIKE THE OLD ONE DID DIMENSIONS WISE. THE HIGHER THE WATTAGE THE FASTER THEY COOK AND HEAT FOOD UP.
Apr 08, 2009 | GE JVM1650 1000 Watts Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
343 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
