Question about Apple iPhone 3G
My phone keep popping a message : "this accessory is not made to work with iphone. would you like to turn on airplane mode to reduce audio interference? you will not be able to receive or make calls. yes OR no" What do i do please?
Check message centre number
Posted on Apr 28, 2010
I have a Sonic Integrity Tube Pod (Tube Pod) and need to know how to make it work with iphone 4. I can play the iphone 4 only through the earphone jack at this point. The iphone 4 however can sit on the...
It is normal to get incompatible devie message when you attach your iphone to dock because you don't use apple dock. I have 5 different brand portable speakers, charging docks. And all of them give same message when i attach my iphone 4 to dock. When you press "ok" on your iphone screen, it should start to play your songs. You don't need to use your iphone at airplane mode.
You may have problem with your iphone dock conncector cable pins. If audio related pins are damaged, you can not use any external iphone speakers with your iphone4. In order to test your sonic integrity tube pod; try another ipod or iphone on its dock. If it gives same result, you may need to change dock connector unit on sonic integrity tube pod due to damaged pins. If it works; iphone 4 dock connetor cable of your iphone 4 needs to be replaced.
Nov 29, 2010 | Sonic Integrity MP5-DS iPod Tube Docking...
Compatibility issues iPhone 3G - JBL On Stage IIIp
hi there, believe it or not, apple has put a authentication chip into newer devices. It won't allow you to play music or display video on devices that are old. Apple wants you to go out and buy new accessories for the new stuff to make more money. My suggestion is to sell it on eBay and use the money to get a newer compatible dock with your iPhone.
Feb 17, 2010 | On Stage Stands JBL On Stage IIIP Portable...
Every 10 secs or so i get an error message saying "This accessory is not meant for this phone, wouldyoulike to turn off airplane mode yes or no"
try YES and see what it does. Or restart iPhone (hold the On/Off button together with central button until you see Apple logo).
Aug 24, 2009 | Apple iPhone 3G Black Smartphone
How do you turn of phone - no calls and turn off just roaming?
Enable Airplane Mode on your iPhone by choosing Settings, then turn airplane mode off.
This will disable the ability to:
Make phone calls
Send or receive email
Browse the Internet
Send or receive text messages
Stream YouTube videos
Get stock quotes
Get maps locations
Get weather reports
When in airplane mode you can still:
Listen to music and watch video
Listen to visual voicemail
Check your calendar
Take or view pictures
Hear alarms
Use the stopwatch or timer
Use the calculator
Take notes
Read text messages and email messages already stored
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 01, 2009 | Apple iPhone 3G
Txt n on the iphone
it's a workaround, but it works if you're going to leave your phone unattended...
First, go to Settings > General > Passcode Lock Turn the passcode on and create a password to protect your phone--set this to the time you prefer for your phone to go into locked mode.
Next, under the same Passcode Lock screen, set the "Show SMS Preview" to off.
Lastly, when you're going to be away from your phone, set the phone to Airplane Mode under general settings.  By setting to airplane mode, you won't get any new information pushed to you.
If you're not in airplane mode, it will still show on your home screen that you received a text message from a specific number but it won't preview the message. In order to retrieve the message you will have to go into the sms function, which will require that you enter your passcode.
It's not perfect and it requires you to think about it, but it will work for you.
Oct 17, 2008 | Apple iPhone Smartphone
This accessory is not made to work with iPhone. would you like to turn on airplane mode to reduce audio interference? You will not be able to make or recieve calls. ...
This message appears even though there is nothing plugged into the iphone port. It is caused by a short in the iphone dock/port for charging and synching. This may be a manufactur defect or could have been caused by moisture or humidity. Chances are you will need to replace the iphone port. If you have soldering experience, you can order the part online, and make the repair yourself. The cost of the specific part is $10 to $23. Good luck!
Jul 13, 2008 | Lands Phones
Error Message "no SIM card installed"
Hold down the power switch at the top and the main selection button at the bottom. After a few seconds a new screen should come up that allows for shutdown should you slide the slider to the right. DO NOT SLIDE THE POWER OFF. Keep holding the two buttons down. Wait until the silver apple logo comes on the screen. At this point you may release the two buttons. Continue to wait while the iPhone reboots. Once the iPhone finishes booting the "No Sim" message should be gone and you should see bars again. No new sim card or reactivation required!
Jan 05, 2008 | Apple iPhone Smartphone
IPhone accessory problem
When the iPhone loses power while playing a song, there was a bug in older firmware that caused all audio to be usable through the speaker only. The solution is to stop the song before you undock the iPhone - or, update your iPhone firmware to the latest.
Dec 24, 2007 | Apple iPhone Smartphone
Apple iPhone 3G Logo
108 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
