Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Top draw won't close completely
The top draw won't close completely-doesn't seem to slide shut the last few centimetres like it used to-it will still run if nyou hold it closed and then turn it on, there are no obvious dishes/utensils etc stuck
    Problem Solver:
  • 6 Answers
Probably a blockage behind the drawer. If its an older model, the bracket that holds the hoses away from the drawer were apparently designed to fail and there is a retrofit replacement kit available if that is your problem.
Posted on Apr 30, 2010
Why does the detergent drawer of our Asko W6021 refuse to open or close easily?
It probably needs cleaning. Best thing to do when you pull it out, is to release the conditoner tray at the sides, or find out how to remove it completely. It should come out for cleaning - you may find a build up of sludge at the back that is preventing it from opening and closing properly. Clean off using just water and a little vinegar and put back in. You should find that it opens and closes easily after that.
May 09, 2014 | Washing Machines
Power cannot be turned on. led display not on
Check that the draws are closing properly and evenly , there is a door sensor just inside the frame top and bottom on the right side .
If thr machine is not level the doors can slide forward.
if this does not work , feel if the draw really locks in when closed because at the back of the draw slides on each side are two plastic lock mechanisms. when the draw has been out they need to be upwards facing so when closed thy lock the slides in on both sides . Sometimes thy only lock in one side causing it not to deactivate the door sensors and shut down .
Yes it sounds simple, but most problems i have found are
Feb 03, 2014 | Fisher and Paykel DishDrawer DS605FDSM...
Bottom drawer does not stay shut
open door and look under countertop to see if your bolts are tight to hold your dishwasher in place?
Apr 09, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
The DVD player slide draw will not open or close
Check for a manual eject slide on the bottom near the front of the tray
Nov 21, 2009 | Philips DivX DVD Player
Freezer door stays ajar after closing the refrigerator door.
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Oct 16, 2009 | GE GTS22KBP Top Freezer Refrigerator
I have a Kenmore model#1069557915 S#SG1047043 03/97 Coldspot Just recently the main door doesn't completely close, any recommendations?
Sep 17, 2009 | Refrigerators
How do you adjust the doors to closed completely?
Sep 03, 2009 | GE GSH22JFR Side by Side Refrigerator
Kenmore 25360132993 - wasn't closing / sealing. While working on it, it stopped closing altogether, seemed to have dropped 1/4 inch or something. Is it a cam? Is it a hinge? Is it the gasket? Is it the...
Sep 02, 2009 | Refrigerators
My fisher paykel top draw does not close fully and therefore when it operates its floodsa nd the f1 code comes on. I know how to clean and reset it but not sure why the door will not close fully, I can...
check the draw on the sides at the front as the draw sits on runners and there are tabs on the runners at the front which hold the draw on. hold the plastic tabs both sides and slide the draw past the slots on the bottom sides of the draw.
Jul 05, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dacor oven door does not close completely
Place a hammer handle between the hinge and the door frame. Exert moderate pressure to close the door. It should spring back to normal position. Do both sides.
May 05, 2009 | Dacor Epicure ERD36 Dual Fuel (Electric...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
134 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
