Question about Samsung Televison & Video
Hi there, I have an SP54T6HPX/XSA model Samsung Tantus rear projection TV. It recently had a new main board put in to rectify a colour convergence problem, all went well until i turned it on and there was no volume at all. I tried different AV cables and a different input divice but still no sound. Any suggestions or should I cut my losses and put it in the bin???
  • 438 Answers
Try connecting an external amplifier and speakers to the audio out RCA jacks in the back of the TV, aux or tape monitor are good inputs on the amp to use , it sounds like your internal amplifier has gone defective,
Posted on Apr 28, 2010
Yes i have a tantus samsung 40" tv and my problem is that the colours are out of alignment red green and blue so your almost watchonf 3d almost can this be rectified can it be fixed
If this is a tube set--and it sounds like it it--it likely needs convergence chips. IF the color and picture was ok before this happened--it is worth a look, but if it was getting dull and fuzzy, BEFORE the convergence problem--it needs tubes and is NOT worth repair.
May 07, 2014 | Televison & Video
Hi i have samsung tantus 109cm rear pro tv the red is out of alinement how can i fix this
You can get the convergence board from www.tvrepairworld.com your experiencing a convergence failure with the red Circuit.
Jun 17, 2011 | Televison & Video
Samsung rear project colour problem blue and yellow
Hi I am vortash sounds like you have a convergence problem and I am guessing you dont have the manual for this set .. there is one available free from http://www.safemanuals.com
this section here deals with the convergence but their are other things in the settings that can cause this so download your own full copy Regards Vortash e03fb99.jpg
Apr 24, 2009 | Akai PT5598HD 55" Rear Projection...
Missing colour
you will need to open the unit and have to replace the stk ic located on the main board to make the colours proper.as it will not cost u too much but proper technician is required if you yourself does not have proper technical knowledge.its risky and dangerous but not at all costly. thanks.
Jan 04, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung Tantus HCM 22 convergence problem
Check this website to buy the entire convergence amplifier board. Replacing the entire boars is a DIY since there isn't any soldering involve only open back cover of the TV and unplug a few wires to remove the old board and install the new one. Keep in mind that this board could be used or reburbished.
Samsung no longer has the assembly.
If you need more info let me know.
Aug 28, 2008 | Samsung HCM422W 42" Rear Projection...
Samsung 52" tantus pch521r convergence panel
I found a this SITE that carries that convergence assembly for your TV.
Good Luck.
Mar 10, 2008 | Samsung PCH521R 52" Rear Projection...
AUSTRALIAN PARTS
the convergence board has nothing to do with tuning of tv, the convergence board put three colour gun (red, green, blue) to work with each other, else you get three image, of red , green,  blue or mixture of all as seperate image, the convergence board for american tv and Australian tv is possibly the same what you check to see the board  part number is the same you possibly need to see if the convergence board has got the memory i.c. if that is the case, you need to tune you t.v reset the channel etc good luck.
need more help let me know.
Oct 09, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
SAMSUNG TANTUS
Start with SAMSUNG.com---I had trouble with the model # you gave----?? Can your circuitry be repaired??If no,why???
Oct 08, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung SP42W5HFX colour misalignment
Hi. Did the ngineer say that it was problem with convergence pcb ? To be honest the lil git hitting the screen is more likely to damage the screen than convergence. Try going in to the menu then convergence & adjust red & blue to try & get the crosses white with no coloured halo around. Post on here with results your model of tv is pretty straight forward I work for an indepedent tv repair shop the manuals are easy to get hold of thats if he even needs one. Chris..
Oct 06, 2007 | Samsung HCM422W 42" Rear Projection...
Samsung HCN473W 47 in. Rear Projection can't turn on
i know this is a old problem but in case anyone in the future here has this problem, the problem lies in your convergence board ,mainly the stk`s are shot ,you can buy new STK`s for around 15 to 20 dollars and then will need some one to take old ones of and resoldering the new ones on.
anywho if you have this problem unplug or remove your convergence board and then turn on tv and you will see a picture, all colours will be out of convergence but when you put the fixed board back in colours should realign, or you may have to realign a little yourself.
only reason i am posting on this old problem is because was just given this tv samsung hcn473wx/xac for free and decided to fix it and it now works well.
micheal rose
Sep 26, 2007 | Samsung HCN473W 47" Rear Projection...
Televison & Video Logo
135 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
