Question about Video Game Consoles & Games
Our X-Box is flashing 3red lights around the power button. Usually the screen freezes, too. We already have unplugged/restarted...all of that...if you have to take out the "hard drive" we're not sure how to do that. Thanks.
  • 99 Answers
Send the unit back to Microsoft for warranty repair.
Call 1-800- 4MY XBOX to set it up.
Hope this helps!
Posted on Mar 24, 2008
Mitsubishi wd-73738 turns itself back on
It sound like the remote is powering off the cable box but not the TV. The remote control may need to be reprogrammed to the TV. When you press power it may only power off the Cable box. At that point, try pressing the TV button on your remote and then Power. If it does not power off the tV after pressing the tV button, the remote may need to be reprogrammed to the tv. Cable companies usually have the codes needed to program their remotes to the TVs.
Jul 09, 2016 | Mitsubishi WD-73738 73" 3D Ready DLP HDTV...
Freezing up
May be you use the xbox too much and too long... Try to keep your xbox in an open area and not in an closed compartment so thet it does not get heated up.....
Mar 18, 2008 | Microsoft Xbox 360 Console
How can I fix "Red ring of death" on my XBox 360
Three flashing red lights around the Xbox 360 power button (nicknamed the "Red Ring of Death" or "Red Lights of Death" or "Red Ring of Doom"), instead of the one to four green lights indicating normal operation, represent an internal problem that requires service. Warning signs may include freeze-ups, graphical problems in the middle of gameplay, such as checkerboard or pinstripe patterns on the screen, and sound errors, and the console only responds to pressing the power button to turn it off. These events may happen once or several times until the hardware failure occurs, or not at all. If the console freezes occasionally, the error will not necessarily follow. The technical problems seem to affect some generations of consoles more than others. e.g. Xbox 360 60GB This error code is usually caused by failure of one or more hardware components, although it can indicate that the console is not receiving enough power from the power supply, which can either be due to a faulty power supply or if the power supply cable is not fully inserted into the console. The 3 flashing lights can also be caused by power surges; if the console is connected to an outlet that receives a power surge, it may have a failure and the 3 lights will appear as long as the console is plugged into the outlet. Turning off the console, unplugging all power cables and plugging them back in, and restarting the console will fix the issue in this case. hope this helps
Nov 30, 2010 | Microsoft Xbox 360 Console
An incomplete red ring circle appeared
At the base of cartridge carrier,on the right-hand side is a red flashing.It flashes along with the green light on the power-on button,and the blk and colour cartridge button.Struck by lightning.lexmark...
Hello. Hope you got working already. But if you're still having the problem, unplug the power supply (the small black box behind the printer where the power cord is attached) with the other end still plugged in to a known working power outlet. Look around the black box, it should have a green LED on around the silver contacts. If not, properly secure the power cord by unplugging and plugging it back in. Otherwise, you got a defective power supply. Try not to use extensions or power strips, plug printer straight to the wall power outlet or plug it to a different known working power outlet. If the power supply is working fine, plug it back in the printer in a correct position. Properly insert it and make sure it pushed all the way in the printer. If you're still getting all blinking lights once plugged in, your printer might be damaged by the the lightning strike. If that's the case, you can call Lexmark and ask for assistance with that. Well, these are the troubleshooting steps you can do to determine where the problem is. Good luck!
Mar 20, 2010 | Lexmark C530dn Laser Printer
When i turn my tv on the screen flashes digital then turns off
Basically, the TV is trying to power up the screen. If it fail to do so, the TV will automatically turn itself off to protect other part from being damaged inside. The problem is going to be the Backlight Inverter Board. It's the circuit board that supplies power to the screen. You can usually find a replacement board at a good price at Shopjimmy.com
Aug 20, 2009 | Sylvania LC370SL8 37 in. LCD Television
Difficulty getting monitor to display when computer powers up
The Problem may be due to the defective inverter unit inside the monitor. Dry to resolder if any dry joint on the inverter PCB or replace the inverter board.
Jun 27, 2009 | Computers & Internet
Locks up and screen freezes. Will work after I push on it.
I think 6 flashes means memory issue. You might want to try and remove and re-insert the memory. Usually found underneath in a compartment held in with 1 screw. If this don't work, I would try and purchase new memory. This would be the cheapest and first thing to eliminate.
Mar 12, 2009 | Dell Latitude D600 Notebook
The machine is frozen, can it be fixed or time to replace?
Hi
We need to reset the printer, please follow the below steps to resolve the issue.
POWER DRAIN:-
Turn off the printer, Unplug the power cable from printer and from the wall outlet.Press and hold ON button for 30-60 seconds.
PARTIAL RESET:-
Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait until the ON light flashes, then release the buttons.
----(for below reset cartridges must be removed out)---------
SEMI_FULL RESET:-
Remove the ink cartridges, Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait until the ON light flashes,or wait for 20 seconds,hen release the button.If the printer goes off don't worry release the button and Push the ON button.
FULL NVM RESET:-
Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold OK and CANCEL button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
(Notes - resets will take a while)
Thanks
Riz
Dec 29, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Video Game Consoles & Games Logo
18 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
