Question about Eidos Interactive Conflict: Global Storm
My CGS is messed up , it has light coloured particles on the walls and on the ground , and the colour changes when i look them from another angle EXAMPLE : Map insurrection the hole between the houses is coloured green , when the it should be brown. , WHAT IS CAUSING THIS ?
    Scholar:
  • 107 Answers
Try these:
VIDEO->ADVANCED SETTINGS->PIXEL PER LIGHTING OFF.
VIDEO->ADVANCED SETTINGS->VOLUMETRIC SHADOWS OFF
VIDEO->ADVANCED SETTINGS->FULL SCREEN POST PROCESSING OFF.
Posted on Jun 22, 2010
I have white kitchen cupboards. What color should the wall be and what color for the back splash. No window in the kitchen.
Bear in mind that the splashback will be with you for a fairly long time, so pick a colour that will last and not bore you. Also if the splashback goes behind the hob make sure that you pick a shade which won't show grease marks too easily. As far as the wall colour is concerned, pick something that will tone with the splashback but is maybe a couple of shades darker. You can always change the wall colour in a year or so if you want to.
Jun 16, 2015 | Kitchen Ranges
Outside wall lighting
black brown are hot gray is netral green ground.
Jun 10, 2012 | Home
HI, I set my camera for Tungston bulbs which I use to shoot art. The images come out very brown. I can fix them in Photoshop but why is this happening?
try taking the shots with the camera set to daylight and or on auto colour balance.
daylight is 5600. k or if you like rather blue tungsten light is normally 3200 k. k stands for kelvin as in colour temperature. many digital cameras will sort out the colour for you but make sure that you are not using a mixture of light as this will confuse the colour saturation and give you all sorts of colour problems. what are you trying to photograph anyway. the back ground area must be lit for detail or you will get a blue noisy mess that tends to mess up the over all exposure. you need defused light for the best easy results. tell me more so i can understand your problem better
Apr 09, 2011 | Canon Rebel XT / EOS 350D Digital Camera
I have a 2002 Suzuki Swift 1.3 and I need the colour coding for the car stereo. This is how it looks like looking from the back of the connector. The top colour is the main colour and the bottom is the...
why post non usa cars to USA forum>????
hint, we dont have M13 here. (EPA ******* here)
then not telliny your county.
why"?
my guess is you think all cars same, all suzuki same world wide and all suzuki have 1 radio.
sorry that don't fly.
but most posts here are just like this, hopeless.
wild guess 1:
here is our last swift, sold USA.,(not a m13 for sure)
wires
MAin set; and speakers last.
wht/blk, = ign. on. power 12v
white = memory , hot all time to battery via fuse, station memory
black = ground
red-green = illumination
red-yell = park lamps on, lighting,.
and below is speaker.
this is year 2000 last car sold here,
Mar 13, 2017 | 2001 Suzuki Swift
I can't seem to get the proper colour back
I unplugged everything from the wall outlet and Roger's box. When I plugged it back in the colour was much better.
Nov 15, 2009 | Insignia 42" LCD Flat-Panel HDTV
VGA PIN
pin no 1 - Red colour signal (Red colour wire)
pin no 2 - Green colour signal (Green colour wire)
pin no 3 - Blue colour signal (Blue colour wire)
4&5 Not connected
pin no 6&7&8 are (Grounds)RGB Returns
9&10 NC
pin 13 Hohizontal sync signal
pin no 14 vertical sync signal
Not nessasry other pins
Jul 17, 2009 | LG Studioworks 700S 17" CRT Monitor
HP D4160 printing only in b & w. Changed color cartridge. Have I messed up a setting somewhere?
yes you must have messed up the setting try change the cartridge i mean swap it, black for colour and colour for black, if it does not work, then make sure you bought the right one check the numbers of the one you changed, if its thesame, then return the catridge there must be a factory error or the catridge is a fake one. thanks
Jul 16, 2009 | HP Deskjet D4160 InkJet Photo Printer
Looking for manual for ''nec n-3480'' TV, missing power cord
Colour code Standard wire colours for flexible cable
Such as Extension cords, power (line) cords and lamp cords World Region, country
or other entity(ies) Live Neutral Protective earth/ground EU, Australia & South Africa (IEC 60446) brown blue green & yellow Australia & New Zealand (AS/NZS 3000:2000 3.8.1) red black green/yellow United States and Canada black (brass) white (silver) green (green) Standard wire colours for fixed cable
(In or behind the wall wiring cables) Region Live Neutral Protective earth/ground EU (IEC 60446) including UK from 31 March 2004 brown blue green & yellow Australia and South Africa red black green & yellow (core is usually bare and should be sleeved at terminations) United States and Canada black, red, blue(brass) white (silver) green (green)
or bare copper wire Note: the colours in this table represent the most common and preferred standard colours for single phase wiring however others may be in use, especially in older installations.
Nov 19, 2008 | Televison & Video
Colour change
ur chroma ic may be defective or there exists aany other magnetic field nearby ur tv
Sep 24, 2008 | Sharp Televison & Video
Eidos Interactive Conflict: Global Storm Logo
142 people viewed this question
Top Eidos Interactive Video Game Consoles & Games Experts
Hanzu
Michael Vincent Cruz
James Wishart
Are you an Eidos Interactive Video Game Console and Game Expert? Answer questions, earn points and help others
