Question about Samsung SGH-t629 Cellular Phone
No Sound! I can't hear the ring tone, people on the other line (including voice mail) and the people on the other line can't hear me. The only sound I can hear is the cell phone alarm. The phone is not on silent mode and the volume is turnned on to max.
Did you try going to sound settings and going to the Power on/off and making sure it was on? I had that problem.
Posted on Apr 03, 2008
Nokia 5800 XpressMusic dial tone not coming and auto call on
My suggestion is that you upgrade your software and firmware. A good place to start is the Nokia Download Center. CLICK HERE
Jun 17, 2012 | Nokia 5800 XpressMusic Smartphone
My phone is not ringing when I get incoming calls, beeping when I get txts, and it won't go on loud speaker. The volume is high. Its set to normal profile, with ringing volume high. Please advise.
Some how your phone was reset or had the tone turned off. Just follow the below guide and your audio should come back on. I would do a soft reset (turn off the handset, remove the battery then reinsert) before performing the instructions.
Tone settings
To select a ringing tone for voice calls, select Tones >
Ringing tone.
To select a ringing tone for video calls, select Tones > Video
call tone.
To set the ringing type, select Tones > Ringing type. You
can also set the device to sound a ringing tone that is a
combination of the spoken name of the caller and the
selected ringing tone, when someone from your contacts list
calls you. Select Tones > Say caller's name.
To set the volume level of the ringing tone, select Tones >
Ringing volume.
To set the various alert tones, select Tones > Message alert
tone, E-mail alert tone, Calendar alarm tone, or Clock
alarm tone.
To set the device to vibrate when you receive a call, select
Tones > Vibrating alert.
To set the volume level of the device keypad tones, select
Tones > Keypad tones.
I have included a link to download your user manual if needed, it comes as a PDF file so you need to have adobe PDF down loader
http://nds1.nokia.com/phones/files/guides/Nokia_E63-1_UG_en.pdf
Apr 23, 2011 | Nokia E63 Cell Phone
I have a canon mx410 all in one inkjet printer.i need assistance with setting up the fax to a phone line. Thank you Zainy
  • Call your phone company to sign up for service. Ask for an additional line with a "distinctive ring." The additional line is for your fax machine---whenever you hear the distinctive ring you'll know that a fax is coming through. Get voice mail service on the regular phone line as well.
    Purchase a two-jack phone splitter (sometimes called a wall jack adapter) that allows two cords to plug into the same phone line. Plug it into the phone jack in your wall.
  • Run a phone cord from both machines into the wall adapter. Test the system by calling both your regular phone number (assure it rings and the voice mail picks up) and your fax number to see if the fax machine picks up (you'll hear a set of strange beeping tones).
  • Apr 13, 2011 | Canon Pixma MX410 All-In-One Printer
    How can I get the telephone on my Brother Fax T96 to work?
    Step by step information at the link below.
    Brother Fax T96
    The F/T Mode is used to allow the fax machine and the telephones to share the same telephone line. When a call comes in, the fax machine and all extension telephones on that line will ring according to the number of rings you have set for the Ring Delay.
    When the Ring Delay is completed, the fax machine will answer the call and determine if it is a fax call or a telephone (voice) call.
    The fax machine can determine this by the signal it is receiving on the telephone line. If someone is sending a fax automatically , the sending fax machine will transmit a fax tone (a series of beeps every 3 seconds).
    If your fax machine hears these tones, it will receive the fax.
    If the fax machine does not hear any fax tones, it assumes it is a telephone (voice) call and will begin ringing the F/T ring tones (double ring) for the length of time you selected for the F/T Ring Time. These tones will only ring on the fax machine's handset (extension or external phones will not ring). At the end of the F/T ring time the fax machine will go into the receive mode in order to receive a manual fax.
    (If the call was a voice call and was not answered, the caller will hear the fax receive tones also).
    • If you answer the call before the fax machine(during the ring delay period) and determine it is a fax, you can transfer the fax to the fax machine for receiving.
    • If you answer the call on an "extension" phone and hear a beep every 3 seconds (automatic fax) or silence (manual fax), press *51 or *91 for New Zealand (remote activation code) on the telephone keypad, wait to hear the fax machine turn on (chirping sounds) and then hang up.
    • If you answer on the handset of the fax machine and hear a beep every 3 seconds or silence, press the Fax Start or Start/Copy key on the control panel of the fax machine and then hang up the handset.
    • If you answer a call on an "extension" phone during the F/T Ring Time, you will hear the F/T ring tones.
      To release the call from the fax machine, press #51 or #91 for New Zealand (remote deactivation code) on the telephone keypad and you can speak to the calling party.
    • If you pick up the handset of the fax machine during the F/T ring time, you may talk to the calling party immediately.
    Mar 28, 2011 | Office Equipment & Supplies
    Dell 2135CN cuts-off incoming calls to my home phone number after 2 rings and the call goes to the printer. I hear the ringer inside printer, then hear fax tones, even though the call is not a fax. My...
    Hi and welcome to FixYa!
    Well if that's the case, the printer should be detached or powered of during call operations. The printer detects incoming calls that's why it triggers it to operate. Turning it off during operation will surely be the solution.
    Hope this helps and thank you for using FixYa! Have a good one!
    Jan 05, 2011 | Computers & Internet
    Sound/ Voice problem
    hey!! due to high frequency sound... the speakers of ur phone has been damaged...... please get it repaired from any repair centre..... it may cost between 100-150 rs.
    Jan 29, 2009 | Samsung SGH-J600 Cellular Phone
    I need to change the sound of the ring the alert makes when I receive a voice mail message....I don't like the way that one sounds. I looked everywhere on the phone but can't find it. You know, when you...
    please go to profile and choose general and get edit menu,get tone setting or alert or ringing tone then you can get number of tones there and you can choose one from there
    Dec 23, 2008 | Motorola Mobility RAZR V3
    How do I ajust the ringer.
    Hi adititeres,
    Is the phone part of a phone system? If it is that feature is programmed in the phone system itself. Do you have voice mail service on the line? Or is this a voice mail service in the phone? If it is on the line, call your dial tone provider to have the number of rings changed. If it is on the phone itself, your user manual will have it. Please let me know if you have any addtional questions.
    Kay
    Jackson Communications
    Aug 01, 2008 | RCA 25423RE1 Phone
    MP3 ringtones sound 'funny' on my N73!
    ur speaker must be containg dirt or water must have entered in ur speaker if ur cell is in validity period then go to nearest nokia care n tell them ur problem they will solve it surely
    Apr 14, 2008 | Nokia N73 Cellular Phone
    Earpiece
    I Think There maybe a problem with the internal speakers.does anyother sound work or is it just the dialing tone and voices?
    if its just dialing & voices check in the call menu that sound IS NOT muted.This may solve the problem.
    if no sound works at all,maybe its is damaged but you havent noticed? Take it back to the shop you bought it from and tell them about the problem,afterall a phone that you cant ring people on is usless! Or ring your network provider to see if it may be repairable under warrenty.
    Hope That Helps.
    Good Luck
    Regards.
    Sophie x
    Feb 11, 2008 | Samsung SGH-E900 Cellular Phone
    Samsung SGH-t629 Cellular Phone Logo
    94 people viewed this question
    Top Samsung Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
