Question about Pool & Spa
I am changing the sand in my Triton filter. [filter is over 10 years old, possibly 15 years]. I have drained the water using the drain plug at the bottom. I have removed the transparent plastic dome from the top. But now I am faced with a whitish plastic cylinder, the top of which sits just below the opening into which I need to insert my vacuum hose. How do I remove this cylinder which is joined by an L-shaped plastic pipe to a joint which leads to the multi-valve?
  • 990 Answers
This piece screws into the elbow under it witch in turn screws into the bulkhead fitting. It will stick when removing. I will usually use the handels from my big chanellocks stuck in the holes on top of it to act as a make shift wrench to get it free, or you can turn the whole assembly sidewise a little to get under it to turn it out. After you get the sand out re assembly it and leave it off to the side to refill with sand. Be sure to have water in the filter when you put the sand in so the levels easy and dosen't stress the laterls in the bottom and crack one of them. Then rite up the assembly and feed the air bleed through the top piece. Put the lid back on and your ready to go.
Posted on Apr 28, 2010
Testimonial: "Hi Kieran Many thanks for your very prompt and very helpful reply. Best regards wsma"
Lets try again. Old triton sand pool filter. Two orange valves. What position should they be when filtering and what position when backwashing
if the pipe after the tap goes back to the filter then when that tap is on the water is going through the filter
the line after that tap goes to a drain then that is backwash tap
contact a pool cleaner to get a better explanation
Sep 09, 2015 | Pool & Spa
Drain leak
Your spider (diffuser) gasket is pinched or damaged. You can replace it for under $20 unless it is the SP0714 model. If it is a 714 then you have to purchase a new key assembly or a whole new valve. Usually runs about $80-$120.
Aug 26, 2013 | Hayward SAND FILTER, PRO SERIES
How to change sand in sand filter model sp 312
  • For our top mount filter, you must first disconnect the pipes leading into the valve and open the drain plug on the filter. Next, remove the clamp holding the multiport valve to the tank body. Once the valve has been removed, you will be able to see the sand bed. The best way to remove the sand is to either use a portable wet/dry vacuum or just scoop it out with a small can. Once the old sand has been removed, hose out the inside of the tank to clean the filter out. Once this water is drained, replace the drain cap and fill the tank 2/3 full of water. This is to protect the lateral assembly while the new sand is added. Add the sand slowly till the laterals are fully covered, then just pour in the remaining sand. DO NOT get sand in the vertical pipe sticking up from the bottom of the filter tank. The standpipe may be covered with a paper cup to prevent sand going into the pipe.
  • For a side mount tank, rotate the multi-port valve to the closed position and open the filter's drain plug. Remove the tank closure dome and expose the top diffuser. The top diffuser lifts off and the old sand can be removed. The best way to remove the sand is to either use a portable wet/dry vacuum or just scoop it out with a small can. Once the old sand has been removed, hose out the inside of the tank to clean the filter out. Once this water is drained, replace the drain cap and fill the tank 2/3 full of water. This is to protect the lateral assembly while the new sand is added. Add the sand slowly till the laterals are fully covered, then just pour in the remaining sand. DO NOT get sand in the internal piping.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 06, 2011 | Hayward SAND FILTER, PRO SERIES
I just had a new Hayward s244s sand filter put in and now am having problems draining water from my pool. For some reason I can't get it to drain past the skimmer level. Suggestions?
What are you using to drain the pool? A sand pool filter is not the best option for draining. You need a submersible pump for that. Why are you draining the pool? The filter should be used to filter water, not drain. It is possible, but not efficient.
May 21, 2011 | Hayward SAND FILTER, PRO SERIES
How do i change the sand in the hayward model sp 711
Hello, 1 You need to unscrew the drain plug and screen (if it is still there!) at the base of the filter. 2 You can reclaim most of the sand by letting the filter drain through a sieve (lots of work) or use new sand. 3 Uncouple union joints or couplers that attach to filter head. 4 Remove filter head. 5 You can try pulling some sand out of the top. However, do not damage the filter fingers in the sand. 6 Use a hose to blast the sand out the bottom drain. 7 Inspect all fingers, replace if necessary. 8 After all is cleaned out, place finger mount inside filter. Cover top of mount with a cup or similar to keep the new sand out of the finger assembly. 9 Replace drain plug and screen. 10 Fill filter halfway with water. 11 Slowly pour sand in and spread evenly. 12 Remove mount cover. 13 Reinstall head, unions and couplings. 14 Prime pump and test for leaks.
Good Luck
May 13, 2011 | Hayward SAND FILTER, PRO SERIES
Last fall when I closed my pool, I noticed a fair amount of sand exited out the bottom of the sand filter drain. In previous years, only water drained from this location. I have now opened the pool and am...
You may have to change the sand if you never have. Or if it's not too bad you can "clean" it. When you removed the plug form the pool, there should actually be two parts. This first part threads directly into the filter, and has a screen on it to hold back the sand. The second one is the plug. This is the only part you should remove, except when changing sand etc. Even if the pool filter is working you can have cloudy water. See you pool supply, and try a floc to help settle dissolved solids in your pool. You add this, run the pump awhile to mix, turn pump off overnight, and then vacuum everything next day. Then turn pump back on.
May 22, 2010 | Hayward SAND FILTER, PRO SERIES
Pentair sm2-pp3 valve, triton II filter. Upon
Lots of sand? You may have a broken lateral in your filter.
To repair, you will have to remove all the sand from the tank to physically inspect.
Might you have changed the sand this year? (top 1/3 needed to be changed every 3 to 5 years normally) If you changed the sand ... did you put water in the filter tank first? If not ... there is a good possibility you broke a lateral (a small pipe with slits in it) when you put the sand into the filter.
It could be that you have too much sand in the filter. Check the owners manual for the clearance - top of sand to top of filter.
Thanks for your interest in FixYa.com
May 14, 2010 | Pool & Spa
Dishwasher won't stop washing
Could be a couple things... but let's address the "not draining" first
Have you recently installed a new disposal? Ensure that the drain plug is removed "punched-out". The plug is located where the air-gap or your dishwasher drain-line is directly connected to the disposal.
This can possibly make the rest of the machine malfunction due to the sensing of "sitting" water that is not draining. Ensure you're pump and filter is not clogged from debris (Inside, right, rear of dishwasher or screen type material)
Other than that, the problem can also possibly be your control board ($100+ dollars for part only)
Jan 25, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Winterize
On the bottom there is a thumb screw drain turn it pull out the plug it will drain.
Oct 21, 2008 | Pentair Sand Dollar 19" Filter with 1 Hp...
Pool & Spa Logo
117 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
