Question about Dryers
F&P ED56 dryer hard to get rolling.
F&P ED56 dryer. Over the past few months, seems as though it is getting harder to start rolling. The bigger the load, the harder and also when it reverses. No load, it starts easier but getting worse. Had a similar problem with a Whirlpool years ago - replaced the bearings and it was fine. Wondering if it could be a similar problem or - the capacitor. Any advice appreciated. Frank
  • Rick Ead
    Rick Ead May 11, 2010
    have you d-linted your dryer? have u replaced the rollers belt and tensioner pulley?
  • Dryers Master
  • 713 Answers
It will be the capacitor. the cap is located on the bracket holding the motor. by memory it is a 4 or 6 uF rating. do u need help in replacing it? please reply 4 more help.god luck. please turn off power b4 you work on it dont want any accidents.
Posted on May 08, 2010
Fisher paykel dryer ed56
Could be the door switch or temp sensor. To check the door switch put pressure against the door and see if it stops. Check the slot the door hits to see if there is anything loose in there.
Jul 20, 2013 | Dryers
F&P ED56 has 2 problems
Yes, (2) certainly sounds like the start/run capacitor has failed. You will see it has a split or bulging case, or a displaced end cap. Replace it with one of the same voltage rating and capacitance.
I can't advise you on (1)
Jun 20, 2013 | Fisher and Paykel Dryers
Dryer will not start. About 4-5 years old. Electric motor sounded a little weak when running the past few months. Heating seemed fine and heat vent is clean. What is cost of new electric motor?
the part # for the motor is 31001589 i have found the price range of it from$100.00 to $140.00
you could copy and paste the part number and perform a google search under the "shopping" tab to find the motor
Jul 25, 2011 | Maytag PYE2300AY Electric Dryer
Fisher & Paykel ED56 not working
Replace (repair) the exhaust sensor this looks like a transistor with the middle leg cut off. it is situated below the lint filter but can only accessed by removing the back panel, top panel (or rear screws to allow the removal of the drum). drum and then front panel to remove the connector from the mainboard. If you follow the exhaust tube once the back is off you will see a single phillips head screw that is the sensor. check the wires to the circuit board are not broken or dry joints or just replace it. sorry i had a spare machine i scavenged from to fix my problem so i dont know where to buy new.
Mar 06, 2010 | Fisher and Paykel Dryers
Fisher & Paykel ED56 Dryer Motor Problem.
sounds like the motor is burned or the wiring!
Jan 01, 2010 | Dryers
Oreck upright hard to push
If hard to push, only a few things to check:
(1) Rear wheels will get hair or thread wrapped around axles, dust, etc. and be hard to turn. Make sure each wheel turns easily.
(2) Small wheels on newer models (since about 1997-98) toward front are worn, missing or have same problem as item 1.
(3) Brush roll not turning. The brush roll actually helps pull this unit along the floor, as it rotates in the "forward" direction. If the belt broke, and you do not realize it, it may suddenly seem harder to push.
Oct 11, 2009 | Oreck XL2000 Bagged Upright Vacuum
Fisher & Paykel Dryer model ED56 constant beep
Diagnostic Mode
Entering the Diagnostic Mode
(a) Turn the power supply to the dryer on.
(b) Press and hold the Auto Dry down button, then press the Power
button.
The dryer is now in level 0 of the diagnostic mode. After initial entry into the
diagnostic mode, the Start/Pause button operates the dryer as normal. Press
the Auto Dry up or down buttons to scroll through the fault levels.
There are several levels of diagnostics, most of which are used in
development and production. These levels may bring on various LEDs, but
the level of use for the service technician is that of the last fault.
Last Fault
To enter the last fault diagnostics, enter the diagnostic mode as described
above, then press the Auto Dry up button three times. The last fault will be
displayed on the drying progress LEDs.
The manual is here
Sep 08, 2009 | Dryers
My fisher and paykel dryer ( mod# ED56 ) wont start, power is on
I had this same problem with my Dryer. It is making the few quick beeps because it thinks the door is still open. Near the bottom of the opening to the dryer there is a sensor switch that gets pushed in when you shut the door. Try holding the switch in with a knife or something and then start the dryer with the door open to check if that is the problem.
After i did this, i closed the door and my dryer started as normal.
Aug 11, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Kenmore 90 series dryer screeches when starts
The likely cause is your belt slipping. The reason it is louder when you start is just that...It pulls harder to get the tub rolling and as it gains momentum the belt doesn't have to work as hard. Your belt is worn and will eventually break. When it slips, it is wearing at a greater rate, so you may want to go ahead and replace it.
Jun 21, 2009 | Kenmore 63942 Dryer
Dryers Logo
330 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
