Question about Sony Televison & Video
How to change the red green and blue crt - Sony Televison & Video
  • George Akers Apr 28, 2010
    the model #-kp51hw40
    the model # is kp51hw40,my tv screen turns red after a while .
  • Sony Master
  • 5,138 Answers
What is the Model number printed on back of TV and why do you need to change crts?
Posted on Apr 28, 2010
  • ladywinn
    ladywinn Apr 29, 2010
    You do not need to change CRT Boards. Adjust your Red Screen Drive down on the Focus/screen control blockTop controls are for Focus to each Tube and controls under them are for Screen drive to each Tube R/G/B You will have to remove Front Bottom Panel on TV and behind it is the Focus/Screen control block.
  • ladywinn
    Mats Electronics Has CRT Boards for this set if you think its the Video IC on RED CRT they are $9.95 for whole board 1-800-628-1118
Sony Wega model kv-32fs120. Color is all reds and blues, no greens or yellows. We have tried adjusting the hue as per the owner's manual and also the re-set but nothing changes.
The color of the television are compose of three color RED,GREEN and BLUE.So the lost color is the green.The problem is in the color section of the CRT board in the chroma section and in the CRT socket board.Maybe theres a loose connection in the PCB like the cathode output transistor.
Sep 18, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
CRT problem
you need to adjust the red screen control of the crt under the speaker grill turn it down with the tv running.
Mar 02, 2009 | Sony KP-51HW40 51" Rear Projection...
Bush RFT TV
The picture tube of the tv has 3 color in CRT Red, Green, Blue. The red cathodeof tv set has no function, its either the resistor become higt resistance, that why u need a repairman to replace it.
Apr 10, 2008 | Televison & Video
Lines horizonal - seems to be caused by voltage to green CRT
Your green CRT is shorted. To test put your red crt socket on the green and your red on the green. then try turning up red control if the green now works its not your tube. If the same thing happens with the red socket on the green you can be sure its the green CRT if the green works properly with the red socket, then you have a problem in the green drive circuit and not the CRT. hope this helps.
Jan 19, 2008 | Mitsubishi WS-55313 55" Rear Projection...
Panasonic 47 HDTV blue looks green
What you have there is referred to as white balance... The Overall White Balance May Suddenly Change And Become More Red, Green, Or Blue Depending On Which Crt Has Been Affected. During Turn Off A Crt Might Arc, Causing D304 (Red), D331 (Green) D361 (Blue) Damage And Leak Changing Cutoff Levels. Replace Diodes With Panasonic Kit # Txask02gser. Kit Contains 3 Diodes And 3 100k Resistors. Install New Diode And Resistor In Series In Place Of Old Diode. Install Annode In Crt Socket Where The Old Annode Was. Then Connect Resistor To Cathode End, Other End Of Resistor Goes Into Pcb Where The Old Diode Cathode Was.
A job like this in my shop we charge $280.00 dollars plus tax which includes the kit... Also a pickup/delivery fee if we have to go and get the unit...
Bill
Dec 01, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Help with kogi F9AH screen
Intermittently displays bright red/green/blue raster then shuts down with led flashing 2, 4 or 5 times
Amazingly this was due to the CRT being faulty !
Blank raster
Replace defective TDA6111Q for Red, Blue and green
Red or Green or Blue screen
Check and replace on crt module : D702, D703, D704 (all 1N4148) replace with type 1N4948T
Dead, led flashing red/green at first, then going to red standby
Replace C604 (1000uF, 16v) elec. cap. It is in the decoupling circuit for the 5 volt supply
Nov 23, 2007 | GVision F9AH-TG Television
How to change CRT in Sony KP-57WS500
CRT is expensive!!! Try to shuffle the electronic parts driving the CRT tubes first, it has three sets of parts, all are the same in each color: red, green, blue. Sometimes cleaning the leads or metal parts of the circuits, specially the green region, will gonna solve the problem. Do it first, it wont gonna cost you a dime, just time. [:0)
Nov 12, 2007 | Sony KP-57WS500 57" Rear Projection...
Green color missing from my LG 700s model
as you are electronics engineer so let us discuss technically.
as you are unable to see green colour means you might be seeing picture of magenta colour
as technically
red+blue = magenta
crt has got three cathodes
your two cathodes circuit is fine one ckt that is green cathode circuit is not working.
for that problem your will have to check
  • cable from computer to monitor
  • loose contact in crt base.
  • crt connector loose
  • voltage on green video output.
  • green video output transistor might be defective.or print loose.
  • circuit related to green video ckt
  • green video signal coming to green video ckt.
  • & finally crt defective (in rare case.)
  • hope this will help
  • good luck.
Oct 16, 2007 | LG Studioworks 700S 17" CRT Monitor
Blue Screen
Your blue crt has a short - you can verify this by unplugging the socket from the blue crt and powering up the set and you should see a yellowish looking picture with just the red and green crt's operating. You can try turning down the screen control pot (B) for blue with the blue crt on (just to the point where you no longer see retrace lines in the picture on a blank input)Sony has had a lot of problems with the crt's on these models and sooner or later all the crt's will fail - For a permanent repair all must be changed.
Aug 20, 2007 | Sony KP-46WT500 46" Rear Projection...
Televison & Video Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
