Question about DeLonghi Microwave Ovens
My Delonghi DMX 10 (800 W) Microwave making Loud sound
My Delonghi DMX 10 800 W Microwave making Loud crrrrrrrr... sound while working. The food is heating well, but the sound is unbearable and it sounds on and off 4-5 times in a minute run. Is it safe to use this microwave?
FRANKSFIXIT
  • 72 Answers
SOURCE: Damage to samll rectangular material inside microwave
MICROWAVE OVEN FIX
Regarding your microwave's ELECTRON deflector cover being broken.
When your "supposed safe" hard boiled egg device exploded it sent the (it's) cover up through the ELECTRON deflector/scatter cover, which is made of a special material that helps to distribute or scatter the Electron flow energy down to the food target in all directions. This was on all older microwave designs, so I'm guessing your microwave could be as old as 22 years plus?
Older nukers had this scatter fan located directly above that cover to help in this process. Newer designs have all but eliminated them in part, and the newer nukers have the Magnetron mounted on the lower side of the Electronics Bay instead of more on top.
Thus the newer designs have a side plastic cover instead of one being overhead. Easier to clean as well. I believe yours has a scatter fan on top if you look closely you will see it.
Hopefully you didn't damage this part, as then it will need repair as well. You should be able to see the blades moving very slowly while the nuker is running if and when everything is working right. Do you remember seeing this part moving?
You may have damaged the "common wave guide" though, as it's coming off of the Magnetron. Worst case is that you damaged the Magnetron itself.
In which case the electronic sensing circuitry inside the microwave (or 'nuker' as I call them) may have tripped a circuit breaker (if your microwave even has one - but I seriously doubt it), or else it may have blown an internal fuse.
In either case DO NOT USE the unit as it is unsafe as it stands right now.
If you are not going to be repairing the nuker yourself then you have a couple options.
You can call the Mfr for the make & model nuker you have to see if you can get a replacement cover for the unit. They may or may not want to sell you one if it's not going to an authorized factory repair person.
I doubt if your nuker is still under any warranty (possibly might?), but even if it was I seriously doubt a food explosion like that of wish you had would be covered under such warranty. If you had the extended coverage it might, but you would have to read the terms of that extended warranty to see.
Without knowing which make & model you have it's hard to tell what else might be damaged. You may want to include that info here or update your posted ? so people can troubleshoot it in more detail. I've gone as far as I can here.
You do have one of 2 choices though. If it's a cheaper older brand nuker best recommendation is to recycle (junk) it and buy a newer model as the newer models are always improving in quality depending on make - model, and price.
My old manual dial set 500 watt Emerson went 20+ years before the Magnetron went out. Because it had no turntable I threw it out and bought another cheaper Samsung 650 watt with a turntable for under $50. Old one was not worth fixing - parts and labor wise - even though it was my labor.
If yours is a high end priced unit you may want to take it in to an authorized service center if the repair price is not too high. You'll have to make that decision.
Here's a trade cooking secret from me to you that very few people know about. It will replace that old MESSY explosive & expensive method you are using now.
I would highly recommend boiling your eggs in the future by using the method I use every week.
Use a round PYREX 4 quart microwaveable safe dish, and nuke at least 8-10 cold eggs at the same time in cold tap water uncovered for at least 15-20 mins - making sure that they all fit loosely with no overcrowding.
Because my nuker is a rotating type 650 watt unit you will have to experiment with the first batch until you get the cooking time and power setting down-path.
Use the 650 watt setting as a start or find out what that equates to on your nuker. Make sure are all the eggs are covered with water so no shell part is exposed.
Here's the most important part before doing anything!
Before putting those cold eggs into the cold tap water take a clean sharp pin and puncture a centered hole in each end of the egg. Take your time and press gently so as not to crack the shell. I never have busted one egg yet to date - knock on wood.
This a very important part as the egg yoke has to have these 2 ports to expand as it cooks inside. Without them the eggs will all crack miserably. Even with them you might get a couple slightly cracked eggs, but you get the same thing with regular stove top boiling as well. Patience is golden!
Let the eggs stand a few minutes after taking them out, as they will still be final cooking inside after removing them from the nuker. You can run one or two eggs under cold water, and then do a test crack & eat to see how they come out and then adjust the time and power settings accordingly.
When doing more then one batch make sure your PYREX dish is cold again before the 2nd round and so forth, so everything is at or near the same temp before going into the nuker.
Hopefully this info has helped you out, and possibly solved your damaged nuker.
Best regards,
Frank
Posted on Mar 05, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave makes loud noise and does not heat. Smell of light burning
Chances are you have a bad magnetron.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 28, 2008
SOURCE: Microwave won't heat food.
My Whirlpool microwave, over the stove, stopped working when my son used it to heat his food and a heavy sound came out, like something exploded in it. When I check it, there was nothing broke. Everything works fine except that it does not heat. I will appreciate any help
Nate
Posted on Nov 09, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Sparks from the interior of the microwave
Quiteoften this is due to grease or food particles stuck somewhere in thecavity of the oven or stuck on or behind the waveguide cover.
It can be fragile, andthe metal edges of the oven behind it can be sharp, so be careful!
The cover and the metalbehind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal ofthe oven is chipped or charred, it will have to be sanded smooth andclean and dried thoroughly.
Then you can apply somehigh-temperature appliance paint, available from places like Wal-Mart,Lowe's or Builder's Square.
If your waveguide coveris burned, it will need to be replaced. It provides importantprotection for the magnetron.
You can findhelpful exploded view diagrams and order parts by entering your fullmodel number here.
We'rehappy to help you with free advice and we'd appreciate yourthoughtful rating of our answer.
Posted on Jan 18, 2009
built in 3/94 is it worth fixing how much for magetron
Posted on Feb 12, 2009
My microwave just made a loud sound. It still runs but doesn't heat up. Is it likely a fuse & if so what do I do?
fuses make very little sound when they blow so a loud sound in a microwave is an expensive sound
best take it in for a proper diagnosis and quote as many loud sound repairs cost more to fix than a new unit
Dec 05, 2016 | Microwave Ovens
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
I need a instruction manual for a Delonnghi touch control microwave oven with grill model No.DMX 30
http://www.delonghi.com/en-gb/customer-experience/instruction-manuals
either go here and use the product code bar on the label on the back
or send an email to the customer support
they will email you the manual
i cant see it onlne...
Dec 10, 2014 | DeLonghi Microwave Ovens
How to fix microwave with bang, flash
That was the magnetron tube breaking. Too expensive to fix. Better to go and buy a new microwave.
Feb 04, 2013 | DeLonghi MW 535 Microwave Oven
My microwave no longer heats anything and also makes a really loud buzzing sound when i attempt to use it.
The problem is most likely caused by a defective magnetron that "heats the food" is loading down the high voltage transformer causing it to make a loud buzzing sound. The cost to repair (depending on make and model) will probably approach the cost of a new microwave oven when you factor parts and labor.
Jan 23, 2011 | Microwave Ovens
My delonghi em821aan-x2 works without making food hot
in most cases the magnatron has gone bad as they are very expensive in most cases we write them off . sorry i think its time for a new microwave
best wishes
sonic boom electronics
Nov 06, 2010 | DeLonghi MW 605 Convection/Microwave Oven
Our microwave oven started making a loud sound and quit heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101==]-]=-
Feb 14, 2010 | Emerson MW8107WA Microwave Oven
Danby microwave does not heat food and makes loud constant noise
IF the noise is a sound coming from the oven area, its the megatron tube. Typically, replacing the megatron tube is more expensive than replacing wiht a new unit and a new warranty.
Nov 06, 2009 | Danby DMW112 Microwave Oven
It turns on ...lights up but doesnot heat or warm the food
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
Apr 17, 2009 | DeLonghi MW 605 Convection/Microwave Oven
Microwave not heating food and is making loud noise.
You have burned out the magnatron (heating element) which is common on GE microwaves. most service companies will charge about 200-250 to replace it
Jan 31, 2009 | GE JVM1860 Microwave Oven
Microwave Ovens Logo
106 people viewed this question
Top DeLonghi Microwave Ovens Experts
William Miller
William Miller
Steve Mason
Are you a DeLonghi Microwave Oven Expert? Answer questions, earn points and help others
