Question about Apple iPod MA446LL/A MP3 Player
No volume there is no output volume from my ipod. either from the dock or with the headphones. all other functions work fine.
  • Apple Master
  • 13,433 Answers
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
if that is no use, contact apple or your dealer for more assitance or repairs.
Posted on Mar 25, 2008
  • Ekse Apr 02, 2008
    If my solution fixed your problem, could you give me a Fixya rateing? Becouse Im trying to reach the guru rank and its up to you if I get there or not.
    Thanks alot!
Make an ipod work
Is it compatible with your iPod?
Oct 17, 2014 | Kicker Ik501 Digital Stereo System For...
How to I use the stock radio amp to run an ipod?
You can use any of the following methods
  1. Connecting the iPod via headphone jack
    All you need is a simple Y cable, which is available from any home-electronics store. Connect the small plug to the headphone output of your iPod--or any portable audio player. Then connect the red and white RCA-style plugs to the matching inputs on the back of your stereo receiver or boombox.
  2. Connecting the iPod via iPod dock
    To connect using the iPod dock, you first need to purchase an iPod dock accessory. Using the same type of Y cable, connect the small plug to the matching jack on the rear of the iPod dock. Then, plug the red and white RCA-style plugs to the matching inputs on the back of your stereo receiver or boombox. This method provides a line-level connection that maintains a volume level to your stereo system and allows the iPod to recharge.
  3. Connecting the iPod via wireless FM transmitter
    You can also connect your iPod to your stereo wirelessly. You'll need to purchase a compatible wireless FM transmitter--there are several available--and connect it your iPod. Once your transmitter is connected, simply tune any nearby radio to the correct frequency, and you'll be listening to your own iPod-powered mini radio station.
Thanks for using Fixya
Sep 07, 2010 | Yamaha Royal Star XVZ 1300 A Motorcycles
I have an Apple iPod accessory -- Model A1121-- that doesn't output any sound.
I can help you troubleshoot your A1121 iPOD docking station.
First of all, can you confirm that your iPOD is seating correctly and securely in the docking port?
For example, when the + or - buttons are pressed on the top, does the green light on the front blink, eventually going red after several pushes?
& Is there any indication that the unit is controlling your iPOD, but simply not outputting sound?
Apr 15, 2010 | Audio Players & Recorders
Works great , but Ipod dock only will give about half volume
All Ipod docks bypass the audio processor, so your volume and equalizer presets on the ipod will not work. Use the volume knob on the home theater unit itself.
Dec 20, 2009 | Audio Players & Recorders
For some reason my ipod touch won't play when I plug it into my stereo. It is playing out of the ipod itself. How do I turn this off.
This is a very common problem, you may have to get a different jack that works with the headset jack thats on the iPod. iPhones and iPods have a weird style jack on the top that wont allow most headphone or 3.0mm to 3.0mm jacks to go fully inside the jack causing it so there is not connection with the jack itself in the iPod. You can check this by turning the volume up and down using the rocker buttons on the side while you are at the home screen with no music playing and see if it says speaker or headphones when your turn the volume up and down. Speaker means there is no jack connection, headphone means that there should be music playing through the stereo. Thats using the jack.
If your talking about an iHome or other direct plug in stereo specifically for the iPods and iPhones, make sure that the dock is the correct dock for the iPod, and make sure that it is pressed fully down onto the dock. If all that is correct there should be no problem. If the problem still is happening, it may be your stereo. =/ Goodluck! Hope this helps!
Dec 07, 2009 | Apple iPod touch
Bose Sound Dock remote control - only volume works
My remote worked perfectly until I changed the battery. The original battery was CL 2032 and I replaced it with DL 2032. After replacing the battery, only the volume control works. The off button will only fade the sound while the button is depressed. Release the button, and the volume returns to the original level and the unit remains On.
None of the other buttons work.
If you've found a solution, please post it here.
Oct 03, 2009 | Bose SoundDock® (Black) Docking Station...
Ihome won't play ipod, even after resetting ipod I have de same problem. I got an itouch 2nd generation and docked it on a speaker that supports it. It worked fine for two or three hours, but suddenly it...
Welcome to the wonderful world of the iHome frying the Ipod.
Your iHome, has most likely fried the mainboard on your ipod.
to check plug a usb into the ipod and connect to the computer.
if it comes up disconnect the usb and try a headphones in the jack.
if it doesn;t play sound its fried and you will need a new mainboard.
if it does play through the headphone jack, your lucky and keep it off the dock.
I have fixed at least 30 ipods taken out by ihome docks and other docks.
they are terrible for the ipod. Even Apple sells the docks on their website
that shows how much they care about the product.
If this helps leave a vote on fixya
May 11, 2009 | Apple iPod touch
Ipod plays with no volume
If the sound isn't working from the headphones then normally it's just a new headphone/hold switch cable that's needed, but if it's not working from the docking bay either then you have a problem with your logic board.
Oct 26, 2008 | Apple iPod MA446LL/A MP3 Player
Volume code
As far as I know, there is no unlock for the volume. If you go into settings there is a volume limit. If you go to it just scroll up to the maximum and press the center button. That's maximum volume set. Then play a song and scroll the volume all the way up. If you're still not getting any sound then your headphone cable might be broken. Try the iPod on some sort of docking bay that produces sound. If it works on there then you definitely have a faulty headphone/hold cable. If it doesn't work on the docking bay, then you have a faulty logic board.
Jul 26, 2008 | Apple iPod MA446LL/A MP3 Player
Check settings and look for maximum volume, this might have been changed.
otherwise your plug in your ipod is broken or both your headphones and docking station are broken.
Dec 28, 2007 | Apple iPod nano
Apple iPod MA446LL/A MP3 Player Logo
57 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
