Question about Philips MX5100VR System
Mx5100vr - dead (no Power up). internal mains fuse ok what do i check next
  • Philips Master
  • 3,866 Answers
Tranformer
Mosfets
Relay
transistor with a probe.
bad eletrolytic capacitors
there is many things that could be you problem area, i am not ther eto check and you asked where to check so i gave you some areas. I hope this finds a solution for you but ether way please rate and leave feedback for your free answer.
Posted on Apr 28, 2010
B n O 8000 speaker dead, is there an internal fuse, output from tv ok mains fuse ok, no mains indicator light hence question
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Sep 05, 2014 | Televison & Video
No power to machine. power socket is live as i have plugged in another appliance which works. does the machine have fuses?
Sounds like you need to have the mains suppressor checked out by an engineer.
Someone had this happen to them as well.
I checked fuses - ok I drained detergent water -ok I checked filter and pump - ok Machine will not start. Next step - contact customer service, however under the Sales of Goods Act 1979 I am contacting the supplier as the machine is new.
I hope you get your machine running soon.
Update The fault was as follows: Bosh Washing Machine WAE2446 Fault reported: DEAD Material: SUPPRESSOR Description: REPLACED FAULTY MAINS SUPPRESSOR
In a nut shell. The washing machine failed (went dead) because the mains suppressor was faulty. The suppressor normally filters out unwanted interference from the washing machine mains electrical supply. The part was replaced and the washing machine came back to life.
Mar 18, 2011 | Bosch Washing Machines
Just plain quit. Can not find book. Would like to check if internal fuse is ok but no idea where to look. Model #568755380. Thank You, Hamilton
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Feb 28, 2011 | Kenmore Microwave Ovens
Problem with the Bosch HME9760 / HME9750 800 Watts Microwave Oven Small pop when i went to open door, and now looks dead. 13amp main fuse all ok, so i assume its an internal thermal fuse or something...
Hope this helps.
Jan 06, 2011 | Bosch HME9760 Microwave Oven
No power at all
im guessing you have opened up the case of the amplifer
look in the area where the ac plug plugs into the box.
you may have to remove some of the boards to get to it
the main internal fuse should be next to the place where you attach the ac plug
also check the main wire wires that go into the main board from the power supply check for voltage
May 11, 2010 | NAD C370 2-Channel Amplifier
Denon AVR-687 cannot power on, no power light lit around power
Check the main power switch next to the large power button. It is a small push button. If it is pressed in and you still have no light around the power button then very likely you have a dead power supply.
Apr 27, 2010 | Denon AVR-687
Dead set no standby light power ok up to
Could be anything! From a main board to a power supply. I recommend getting service on it from a authorized sony service center. If standby light doesn't appear at all for any given time, then it maybe the power supply.
Jun 23, 2009 | Sony Bravia KDL-42V4100 42 in. LCD TV
Dryer won't start, no noise
This is most often caused by a bad thermal fuse on the exit chute. Main reason is plugged / restricted venting and dirty or bad thermostat, which is next to the fuse on most dryers. Hope this helps!
Jan 05, 2009 | Whirlpool Dryers
Philips MX5100VR System Logo
121 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
