Question about Boating
2007 Suzuki 200ho four stroke outboard - no power to starter
I have a 2007 Suzuki four stroke outboard and cannot get the starter to engage. It has power from the key but will not engage starter. I bought a new relay and that didnt do the trick (although there seems to be of the same relays). any ideas? where is the neutral safety swith?
  • 2,100 Answers
There is a neutral safety switch, also one thing I found is carbon build up inside the starter will stop it cold. Take and air gun to it and blow it out, (try it, It might get it,) if not, take it down to see what is wrong with it. The safety switch should be a micro switch on the shifter, a couple wires going to it. Check it out. Hope this helps.
Posted on Apr 28, 2010
2010 150 Evinrude E-Tech. Motor was running great then just shut off. Will not start again.Could it be it needes to be reset, all 4 lights at tach light up showing good.
first bit of advice
do not use e-mix fuels in outboard engines
WHY
because ethanol separates from the fuel if not used continuously so letting it stand between outings is not good
secondly ethanol is hygroscopic which means that it absorbs moisture from the air that is going in via the tank vent and that results in corroded aluminium parts and rusted fuel tanks and outboards operate in a very moisture laden environment
now for the problem
being a late model engine , it should be a 4 stroke and like any 4 stroke engine , check the timing belt/chain, crank/cam position sensors , ignition module
it is important to check all harness connections as salt water rapidly causes corrosion in electrical connections and components
have the service agent do a scan for fault codes remember this
Suzuki out board 2 stroke motors were used in the early suzuki 4x4 cars and modern 4 stroke engines are simply car engines on end
Sep 18, 2017 | Clymer Evinrude/Johnson 5-70 Hp...
I need a manual for my 4 stroke 100HP Susuki outboard
Frans, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
suzuki 100 hp outboard specifications Google Search
Suzuki
https://www.tradebit.com/filedetail.php/142965517-suzuki-outboard-service-manual-df90-100-115
May 02, 2016 | Boating
Do I use reg gas or a gas mix?
Matt, If engine is two stroke and not oil injected then yes you must mix 2 stroke oil and fuel. 4 stroke engine have a crank case which is filled to proper level with 4 stroke engine oil. Check the attached links,instruction and guides, Good luck
How to Decide Between Two or Four Stroke Outboard Boat Engine
4 Stroke Outboard Motor vs 2 Stroke Outboards
2 stroke outboard Vrs 4 stroke outboard
http://www.cottagetips.com/tips/boat-motor-gas-to-oil-ratios
Apr 15, 2016 | Boating
Suzuki outboard boat motor 250 hp four stroke 2012, good motor?
Excellant! Just hope you're not putting it on a light boat... that thing could take flight if you're not carefull. Suzuki can build motors - others are copying thier racing designs.
Jun 13, 2012 | Suzuki Motorcycles
Suzuki 4hp two stroke impellar
Dropp the lower unit, should be only 4 bolts holding it on. Impellar housing should be located right on top of the lower unit. four screws it the housing slides off the shaft, insall in reverse order with ne gaskets, make sure you re- align the waterhose/pipe from the lower unit back to the head
Mar 22, 2009 | Boating
Boating Logo
239 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
