Question about Stoves Premier 720GRa Gas Double Oven
BOTTOM OVEN GOES OFF AFTER TEN MINUTES THEN TURNS ON WHEN IT COOLS DOWN
  • 1,998 Answers
You have to be able to check the ignitor in the lower oven sounds like you have a weak ignitor when this happens it is taking to long for the oven to light and when it reaches to a tempreture it shuts off the ignitor in which case when it trys to reach to the tempreture that you have set it trys to ingnite again look to buy a new ignitor
Posted on Apr 28, 2010
Frigidaire Oven door wont open after self clean cool down
Good Morning Marlyn Allen, thanks for your post!
Based off the information you have provided your Frigidaire oven door will not open after it has cooled down. I would hold down the clear or cancel button for ten seconds that should release the door. If that does not work I would perform a reset on your oven and you can do that by disconnecting the power from it for approximately ten minutes. You can also perform another self-cleaning cycle and before it starts cancel the self-cleaning and then wait for ten seconds and the door should release. If you follow these steps and the door does not open it could be a faulty door latch and that would need to be replaced by a technician. Best of luck! -Matt
Dec 12, 2014 | Frigidaire Ovens
My electric amana oven turns off after it has preheated and is baking for a little while. the display goes off and will not turn on until the oven has cooled. is the control board bad?
Ovens have a thermal overload beneath the outer skin which prevents the oven from overheating. If the temperature in the cavity gets too hot the overload will operate and cut all power. When the oven cools down sufficiently the power is then restored. My guess is that this is what is occurring. If the electronic timer is faulty is doesn't normally turn off and on, it just won't work. It sounds as if the thermal overload needs replacing.
Feb 26, 2011 | Amana Ovens
Hi, I have 90 AJC 06 GC. AEG single oven. At thhe moment when the oven is turned off the cooldown fan will not turn off so I have to turn it of at the main fuse box. Also sometimes the oven turns itself...
The oven cooldown fan will sometimes run for 10 to 15 minutes after turning the oven off. This enables the outer shell of the oven to cool down. Most ovens also have an inbuilt thermal overload in the outer shell. If the temperature in the outer shell gets too hot it will open circuit the oven power until it cools down a bit.
Feb 10, 2011 | AEG Ovens
Ask a question yesterday did not get an answer .i will ask again kenmore self cleaning oven tried to clean pressed button door locked .after ten minutes oven did not heat up to clean did i miss a step that...
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Nov 09, 2010 | Kenmore Ovens
Frigidaire wall oven fan running - door will not unlock
the fan will run untill the oven cools. if it dont shut off you need to shut down power for ten mineuts the reset if still runs you shuold call for service
Mar 22, 2010 | Ovens
Cleaning Kenmore double ovens back to back. During second cleaning got F9 code and the bottom oven is locked. Cleared the F9 will the bottom oven unlock when it cools down?
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 10, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Intermittent tripping of circuit as oven just reaches temp
Sounds like the oven element is cracked and absorbing moisture when the oven cools down thus causing it to trip. Should buy a new element. there are hundreds of suppliers on the internet.
Jun 09, 2009 | Neff B1691 Single circotherm super...
GE JKP45 double wall oven shuts off
This sounds like a loose connection (solder joint) on the main control board. I had one that had a similar problem. checked the price of a control board $350. I took the control panel off, took the board apart and found a loose connection on one of the relays. resoldered the bad connection. oven works fine now.
Nov 07, 2008 | GE JKP45 Electric Double Oven
Shut down after 10 minutes
it is reaching the correct temperature and then switches back on when cools a bit?
Jan 11, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Oven cuts out after ten minutes and comes back after cooling down.
thermal cut out fuse, costs about £30, my company fits them for £78 all in in essex
Nov 19, 2007 | AEG B3101-4 Electric Single Oven
Stoves Premier 720GRa Gas Double Oven Logo
194 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
