Question about Frigidaire AEQ6000ES Electric Dryer
How do i fix an e68 fridgidaire problem on an affinity model
    President:
  • 1,554 Answers
A key is stuck as indicated by the error code E68; enter the service diagnostic mode and perform the key test to determine which key is stuck. Unstuck the key then perform the key test again. The electronic control board (part number 134557201) needs to be replaced if the error code continues to appear. Click here for the diagnostic and key test procedure.
Posted on Apr 28, 2010
Need help my affinity dryer has the code E68 on it and the code Dr the model number is LGQ7000ES0
E68 is a stuck button error code... There is a diagnostic video for this on YouTube. You will have to get a new control board to fix the problem because the buttons are part of the board... Frigidaire Dryer Main Control Board 134557200
Jun 08, 2016 | Dryers
I have a affinity dryer model number LGQ7000ES0 IT HAS THE CODE E68 how can I fix it
It has a stuck touchpad button, or it needs a new control.
May 31, 2016 | Dryers
My fridgidaire gives the message E68 then e4
Fridgidair? in game consoles? Wrong section bud. ^^
Jul 14, 2014 | Video Game Consoles & Games
Why is my Frigidaire affinity showing code E68?
Good Morning Gary,
I understand you are receiving an E68 code on your Frigidaire Affinity washer, model# ATF7000E. The E68 code states that there is a current leak to the ground on the heater or there is a fuse open. This could also be a false error code. I suggest resetting your appliance, by either unplugging it or shutting the power off at the circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 19, 2014 | Frigidaire Affinity ATF7000E Front Load...
I have a Frigidaire Affinity Clothes dryer manufactured in 05/07 that is displaying a code E68 after in runs for just a few minutes. Any idea what could be causing this?
The error code E68 means a key or button is stuck. Check the buttons by pressing them one at a time to find the stuck one or enter the service diagnostic mode then the key function test. Click on the link below for the detailed instructions.
Troubleshooting Error Code E68 on Frigidaire Affinity and Gallery Dryers
Mar 06, 2011 | Frigidaire Electric Dryer
Code E36 and Code E68
hello e36 means control board problem E68 means current leakage to ground on heater or fuse opened
shaun
Jan 12, 2009 | Frigidaire ATF6000ES Front Load Washer
I have a Fridgidaire Front Loader Washer _ Affinity. It has an error message flashing. E10. What does that mean? What do I do to fix it?
I have a Fridgidaire Front Loader Washer _ Affinity that flashed the E10 error code. I also had the problem with the fabric softener dispenser not emptying, and staying full of water. The problem was the cold water filter on the back of the washing machine that was semi-plugged. Cleaned the filter and now works perfectly. My machine is no longer flashing the Error code 10. The dispenser works perfectly.
Oct 05, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire Affinity dryer error code?
HELLO,
I HAVE A FRIGIDAIRE AFFINITY DRYER (AEQ6000CE32). WHENEVER I PUT THE CLOTHES IN IT JUST SPINS FOR 10 TO 15 MINUTES AND SHUTS OFF BEFORE THE ALLOTTED TIME. THERE IS NO HEAT IN THE DRYER. ANY SLOUTIONS?
Sep 16, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Dryers Logo
1,706 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
