Question about Mag Innovision LT976S 19" Flat Panel LCD Monitor
MAG innovision LT917s problems
Ya, i haven't seen any real answers to this around here so here you go. I have the monitor mentioned above^^^^ and i was wondering why its doing what its doing. When I start my computer and have my monitor on the screen stays black and the green power light is flashing on and off. It has not really been that bad until today when I had to sit here for literally 20 full minutes until my picture finally came up. I restarted my computer entirely after turning the monitor on and off a few times to no avail so I just continued to wait until it came on. I am running Vista on my new machine with a brand new nVidia 7800 graphics card and i found out that its not the computer. When I used this monitor with my original PC it did the same thing for less periods of time, much less, like 30 seconds at most. I am a busy college student and sometimes dont have time to wait for 20 minutes for my monitor to turn on properly. If you could please answer as fast as possiple I would appreciate it I am very sick of this monitor and its only a little over a year old.
  • jimburino May 23, 2008
    I had the same problem, green flashing light and black screen. my daughter told me to get a better power supply, she builds computers..... problem solved
  • Anonymous Jun 18, 2008
    I have the same exact problem too. I messed around with a bit and got it to turn on after about a minute, but now the screen just stays white, I checked all the connections and tried all the different possible connections for it inside and I still get the same thing.
K I just fixed mine! I hope you still have your screen dude. Its easy. Take the screen apart, and take the monitor part off, open up the part thats attached to the back, and remove the big silicon peace thats attached with the golden bolts. Look at the capacitors, if they are bulged up then they are broken, go to radioshack and buy some new ones, they are 470uF 25v 105C, but 470uF 35v and 85C will work as well. Solder them off and put the new ones on, connect everything and it'll work like new. Just did it today and saved myself 200 from buying a new screen!
Posted on Jun 18, 2008
I repaired the same problem and had 6 of the 470uF, 25V, 105C caps that had bulging tops. I replaced them with Digi-key 493-1549-ND parts. I also had a 220uF, 25V, 105C part that had a bulging top. I replaced that one with a Digi-key 493-1826-ND part. The monitor works like new after the capacitor replacement.
Posted on Oct 01, 2008
  • 28 Answers
Even though it is a fairly new monitor, I would say that it is defective. It is possible that the refresh rate for your computer is too high for it, you could try setting that down to a lower level, and see if that works. Otherwise, probly a new one is in order.
Posted on Mar 25, 2008
SOURCE:
I am unable to get MAG Innovision 14" LCD monitor
You need laptop-type 12V, 2.5A (minimum) adapter plugged into back of VGA plug
Nov 13, 2010 | Mag Innovision lt456s 14" Flat Panel LCD...
I have a MAG innovision 900p 19" monitor that turns white everytime it is turned on.. I've tried cleaning the dust from the connectors and have tried turning it on and unplugging it. Nothing I can think of...
White screen means that the video signal is not getting from the vga board inside the monitor to the actual lcd screen panel.
It may be a bad vga input board (also called a main board)
OR
It could be simply a bad connection on the wiring harness that connects this board to the lcd panel
Or
it could be a blown fuse on the board on the board that is permanently mounted to the back top of the lcd panel.
I would check the wiring connection to the lcd panel inside the monitor first
Oct 19, 2010 | Mag Innovision LT917S 19 inch Monitor
How to download a owners manual for MAG Innovision LT717s LCD Computer Manual
I solved the problem myself by going to the homepage of MAG Innovision and i downloaded the manual i needed from there...Thank you.
Oct 29, 2009 | Mag Innovision LT982s 19" Flat Panel LCD...
I have a MAG INNOVISION LT765s LCD monitor. When the computer boots up, the power button on the monitor won't stay on so the display won't come on. It sometimes takes an hour of fooling around with the...
I have had similar problems with my Mag LCD monitor. I recently dicovered that the problem was with the adapter and not the monitor. Try replacing the power adapter.
Sep 21, 2009 | Mag Innovision InnoVision LT765 17" Flat...
Mag Innovision LT917s 19 inch monitor- On and Off !!
Replace it.  It would probably cost more to get it repaired.
May 28, 2009 | Mag Innovision LT917S 19 inch Monitor
Monitor goes blank less than a second after turning on.
Beautiful screen, lasts about for a few minutes, goes black. Power button still green. If I turn it off, and then back on, it works again for a while. Any ideas?
May 11, 2008 | Mag Innovision LT982s 19" Flat Panel LCD...
Monitor problem
my monitor is 17'' lcd...... mag innovision model: LT716s..before was working well but now the lcd monitor don't to turn or either the led doesn't turn or make any sign.... no matter whta the lcd stay blak,,,,,do not want to turn on....
Dec 31, 2007 | Mag Innovision LT976S 19" Flat Panel LCD...
Open Questions:
Mag Innovision LT976S 19" Flat Panel LCD Monitor Logo
878 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Thomas F. Schneider
Damen Wong
Damen Wong
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
