Question about Canon ImageCLASS MF4350d Laser All-in-One Printer
Sir paper got jam when light was gone, and i pulled the paper out and i tried to run the machine when light came but its not working. machine not opening as usual and the screen is showing paper jam
  • 4,041 Answers
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 28, 2010
Canon IR8070 paper jam infront of Registration roller
If you can reach the paper in the jam you will have to pull it out to dislodge the jam. Be careful not to rip the paper in doing so!
Aug 28, 2014 | Canon Office Equipment & Supplies
Selphy DS700: False paper jam message and poor print quality
1.Sir Please have a vacuum cleaner with you and clean the area where the paper is being pulled in thus the sensor will be clear 2.if your problem isnt yet resolved please post your Windows here i will assisst you further
Sep 30, 2007 | Canon Selphy DS700 InkJet Photo Printer
Where is the paper jam sensor located on a cannon mg 2520 printer?
Technically, you'll have a hard time finding the sensor for a paper jam coming out of the paper tray on a Canon MG 2520. Mainly because its deep inside the middle of the machine.
BUT, more than likely its NOT the sensor which is the problem... Let's go through a couple options...
First, It's probably that the paper feed tire is dirty, worn and is NOT actually picking up the paper from the paper tray. What happens is the machine will simply read "PAPER JAM" when in fact, NO PAPER was ever picked up... Welcome to my world!!
If you get a paper jam, and the paper is actually traveling through the machine, then its either a sensor or there is an internal motor that has gone bad and is not continuing to pull the paper through the machine.
However, my instinct and experience finds that its usually just not pulling the paper at all. Clean the paper feed rollers in the back of the machine down at the bottom where the very bottom of the paper rests in the machine.
DO NOT USE RUBBING ALCOHOL OR COMMON HOUSEHOLD CLEANERS!!! Quickest way to destroy your machine's paper feed rollers is to DRY them out with common over the counter cleaning agents... Instead, you'll want to use this very common compound. It's not what I use, but is attainable for the average household and works in a pinch.
Take 3 parts water and one part Simple Green and combine in a spray bottle. Use a NON-LINT HIGH QUALITY cleaning rag. NOT made of fabric or cloth, but made of high quality, low lint paper cloth.
Use that to clean the rollers, then try again. If its still not pulling in the paper, then the feed tires are shot, and need replaced...
Aug 24, 2014 | Office Equipment & Supplies
I have a paper jam with a samsung CLX 3175FN. Can't get the stuck paper out! Turning on and off didn't work.
If the paper is jammed inside the machine follow these steps:
1. Open the front cover and pull the toner cartridge out, lightly pushing it down.
2. Remove the jammed paper by gently pulling it straight out.
3. After removing the jammed paper, make sure there is no additional paper in the paper path.
4. Insert the toner cartridge and close the front cover.
If the paper is jammed in exit are follow these steps:
1. Open and close the front cover. The jammed paper is automatically ejected from the machine.
2. Gently pull the paper out of the output tray.
- If you do not see the jammed paper or if there is any resistance when you pull, stop and go to the next step.
3. Open the rear cover.
4. Carefully remove the paper by pulling in the direction.
- If the paper tears, make sure that all of the paper fragments are removed from the printer.
5. Close the rear cover. Printing automatically resumes.
Nov 17, 2010 | Samsung Office Equipment & Supplies
Paper jam
Sir/Mam
The problem mite be dirty rollers that feed the paper, try cleaning with alcohol or worn out replace. Problem is the paper roller is miss feeding not taking up the paper instead of hitting something in the machine paper jam.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 18, 2010 | HP 1010 Plain Paper Inkjet Fax
Paper feed is jamming ,I have not even gone through the original ink cartridges yet,so i haven`t done a lot printing
Things to do remove the papers jammed inside the printer.
  1. Please Turn off this Canon Pixma 2600 printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper or any piece of paper got trapped in the printer..
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Do it carefully with utmost care.
  8. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  9. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on. Before inserting the Toner or Catridge, please wipe the roller with cloth gently.
  10. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
See alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jul 16, 2009 | Canon Pixma iP2600 Photo InkJet Printer
I had a paper jam..took out the cartridge..pulled
Hello sir;Track back the paper you pull through you will find a senser either stuck or come off, put it back property.
May 06, 2009 | HP LaserJet 1020 Printer
Grinding Sound - Orange Paper Jam Light
You have a broken gear main motor. I had the same problem, bought $5 part and after the replacement of the gear,it runs like new
Dec 04, 2008 | HP LaserJet 4L Printer
Help please. can't print: paper light flashing even though there is paper in printer
To fix the NON EXISTANT paper jam:
Status light is on, paper light is on - you can hear the paper feed trying to "grab" the paper, but it can't,  and status light goes Red.
Take out paper tray
Reset the blue paper holders, move them tight against the paper so the paper is snug against all blue barriers. Cause: Somehow the blue paper holders got dislodged and the paper is not snug so the feeder is trying to grab paper that  is slightly out of reach.
Mar 15, 2007 | Brother HL 5140 Laser Printer
Canon ImageCLASS MF4350d Laser All-in-One  Printer Logo
313 people viewed this question
old marine
old marine
