Question about Compaq Evo D500 PC Desktop
Hello , My Desktop PC is giving NTLDR problem,& its not accepting new CD of XP also
    Sergeant:
    Champion:
  • 305 Answers
Go into the bios and change the drive boot order cd or dvd first boot save and exit reboot put disc in and reboot again.
hope this helps.
Posted on Apr 28, 2010
Have a hp pavilion a705w that shut down one day and upon restart NTLDR is missing error came up and said hit alt clt del what do i do
Windows was writing to a file when the power went off. Now windows files are damaged. I'm assuming you have Windows XP on the machine. Do you have your Windows XP cd?
Mar 16, 2013 | HP Pavilion a705w PC Desktop
NTLDR missing on XP desktop
NTLDR is the boot loader for windows XP. This is the part the kick starts the entire process of XP loading. It is located at C:\NTLDR One of the easier ways to fix this is Either boot in to the recover console from a Windows XP disc, or download Hiren Boot CD, burn it to a disc. Insert the CD into your Dell and reboot the computer. Note you may need to enter BIOS and enable boot to CD/DVD. Once at the Hiren menu, select Boot Mini XP. Once the Mini XP loads you can copy NTLDR loader from the mini xp to your C:\ drive. Then remove the disc and reboot the computer.
Jun 11, 2012 | Computers & Internet
How to fix a NTLDR is missing error
Fixes for NTLDR Errors
  1. Restart the PC. The NTLDR error could be a fluke.
  2. Check your floppy and optical (CD/DVD/BD) drives for media and disconnect any external drives. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk, CD/DVD/BD, or external hard drive or flash drive.
    Note: If you find that this is the cause of your problem and it's happening a lot, you might want to consider changing the boot order in BIOS so the hard drive with Windows installed is listed first.
  3. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors.
    Note: There is usually an Auto setting for hard drive and optical drive configurations in BIOS which is usually a safe bet if you're not sure what to do.
  4. Restore the NTLDR and ntdetect.com files from the Windows XP CD. Restoring these two important system files from the original Windows XP CD may do the trick.
  5. Repair or replace the boot.ini file. This will prevent the NTLDR error if the cause of the problem is a boot.ini file that is not configured properly for your Windows XP installation.
  6. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the "NTLDR is Missing" error.
  7. Repair the Windows XP master boot record. NTLDR error messages may also appear if the master boot record is corrupt.
  8. Reseat all internal data and power cables. NTLDR error messages could be caused by loose or malfunctioning IDE cables.
    Try replacing the IDE cable cable if you suspect it might be faulty.
  9. Update your motherboard's BIOS. Occasionally, an outdated BIOS version can cause the "NTLDR is Missing" error.
  10. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
  11. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch. While this will almost certainly resolve any NTLDR errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
    If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
  12. Replace the hard drive and then perform a new installation of Windows XP. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
Apr 06, 2012 | HP Pavilion 513n (P9850A#ABA) PC Desktop
Emachines W3619 won't load ntldr
Take a windows XP CD, Switch on your PC and go to "BIOS" menu and select "Boot From CD/DVD" whichever is applicable for your pc.
Now insert the Win Xp disc i drive and start PC, Boot the Pc From CD Drive and you shall get the Blue screen of windows Installation. Restart the PC by hard pressing the power button for 30 secs.
Now you will be able to login to windows.
Dec 02, 2011 | eMachines W3619 PC Desktop
Error message is ntldr not found
hello iam vishal , the solution for ntldr ishere insert windows xp disk restart pc load the cd by pressing any key click r to repair write the following copy f:/i386 c:windows and press enter
Apr 10, 2011 | HP Compaq Presario SR1303wm PC Desktop
Hi! Please help? I have a desktop IBM ThinkCentre 1) I formatted my harddrive in another computer, using via Windows Disk Management option. 2) Replaced the HDD, and wanted to run new Windows XP...
download the Spotmau PowerSuite to solve he problem go for this link http://www.tech-pro.net/howto-fix-ntldr-is-missing.html do step by step .try it afer some time i will give another solution.
Nov 12, 2010 | IBM ThinkCentre A50p PC Desktop
Ntldr is missing
If you have XP then try holding down the F11 key after reboot. This will start the recovery console. I have actually 3 emachines desktops. I feel your pain. If you need more help let me know.
Mar 21, 2010 | E-Machines W3107 (RBW3107) PC Desktop
Dell computer running windows xp will not boot. NTLDR compressed
best thing to do if you can get one is a propper install disk and then follow these instructions..
1. Start the Recovery Console. If you do not have the Recovery Console installed, start it from the Windows Xp compact disc (CD). To do this, follow these steps:
a. Insert the Windows XP CD and restart the computer. If prompted, select any options required to boot from the CD.
b. When the text-based part of Setup begins, follow the prompts; choose the repair or recover option by pressing R.
c. If you have a dual-boot or multiple-boot system, choose the installation that you need to access from the recovery console.
d. When prompted, type the Administrator password.
2. At the command prompt, type "cd \" (without the quotation marks), and then press ENTER.
3. Type "ren ntldr ntldr.old" (without the quotation marks), and then press ENTER.
4. Type "map" (without the quotation marks), and then press ENTER.
5. Note the drive letter assigned to the CD-ROM drive that contains the Windows XP CD. It is displayed in a format similar to the following: D: \Device\CdRom0
6. Type "expand <drive>\i386\ntldr._" (without the quotation marks) (where <drive> is the drive letter of the CD-ROM drive that contains the Windows XP CD), and then press ENTER. For example:
Expand d:\i386\ntldr._ <ENTER>
Note the underscore character after the "."
The following message appears: ntldr, 1 file(s) expanded.
7. Type "exit" (without the quotation marks). The computer restarts.
8. Remove the Windows XP CD and start the computer normally.
Jul 07, 2009 | Compaq Presario 4090US (470016-303) PC...
Replacing with harddrive 40GB
Did you simply swap hard drives? "Couldn't find NTLDR" basically means the PC cannot find any version of Windows installed because the boot file is missing. This could be because you have a CD in the drive or the hard drive is missing or broken.
If you put in a new hard drive to replace your older smaller one you need to reinstall Windows on that new 40GB drive or it just won't work. If you have some PC Tech friends they should be able to move the data which is tricky or help you out.
Mar 18, 2009 | Compaq Presario 5000 PC Desktop
Compaq Evo D500 PC Desktop Logo
32 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
