Question about Samsung Tocco F480 - Pay Monthly Cellular Phone
Inside of front screen dusty how to remove front screen
    Guru:
  • 126 Answers
Unscrew top cover you will find display screen remove it gently and clean it with soft cloth.
Posted on Apr 28, 2010
Cobwebs proscan ps56700 inside screen
It can be done from the front but from the rear is actually more easy and safe--removing front screen and frame entails some danger of damage to the screens.
I have over many years of outside/home service calls encountered this.
As a outside technician I want the quickest and safest way to do this.
With set unplugged simply remove rear cover:
Use a swiffer type duster to reach up and inside and gently get all the webs out(do not use force when against the inside of the screens) and if the handle is long enough you will be able to remove all of the webs.
Also when doing this you will see with cover off 3 large black lens at the top of the chassis above the circuit boards.
They are the light source for your picture--clean them with a lens cloth or a paper towel with Glass cleaner sprayed on it---Do not attempt to clean the mirror in the rear as it is a film material and is easily scratched.
If the lens were dusty/dirty and then cleaned the picture will be brighter and sharper looking----that should be done about one time a year.
If you have questions make a comment here on this page(make a comment button).
Apr 21, 2012 | Proscan PS56700 56" Rear Projection...
Fuzzy picture...direct cable says its in the tv itself...unplugged ,plugged back in removed coaxial and replaced checked all plug ins to no avail..
TV seems dusty inside, please clean optical lens, rear mirror and front screen of TV to get better picture, need to take off back of TV by removing lots of screws at back to clean it inside.
Thanks.
Apr 18, 2011 | Televison & Video
Fuzzy picture...started when first turned on tv,after a few minutes picture be came clear.tv now is fuzzy all the time.model #50vx915 ser.#v4k000487
TV seems dusty inside, please clean optical lens, rear mirror and front screen of TV to get better picture, need to take off back of TV to clean it inside.
Thanks.
Mar 30, 2011 | Hitachi Televison & Video
The picture is dull, what i have to do for the TV?
The usual cause of the DLP's geeting dull is the front small projection mirror gets dusty and needs cleaning. The mirror is located dead center in the front after removing the screen assembly. Its a small mirror directly in front of the lens assembly of the light engine.
May 10, 2010 | Mitsubishi WD-62531 Projection Television
Screen is white. it turns on and off when battery
Either you accidentally dropped and spoilt your phone or water had managed to seep through. Try opening and get your phone screen out to wipe it clean (if you dare). Sometimes the connection can be bad from your phone to your screen if it's wet or dusty inside.
May 04, 2010 | Cell Phones
HOW TO CLEAN MY REAR PROJECTION
There are two ways: the hard and the easy way.
The easy way is with the back removed you should be able to see and reach the three lens with a lens cloth or a paper towel with glass cleaner sprayed on it.
The mirror rarely needs cleaning unless someone smokes in the house or you live in a very dusty environment.
If you have a small mirror with the back off you should be able to use it to see if the mirror is dusty; it rarely is as it hangs at a angle and dust rarely gets on it.
If you had a issue with cob webs or something on the inside of the screen the only way to deal with that is the Hard way: removal of the entire front screen assembly which is secured by screws at the bottom of it behind the front speaker grill.
This would allow you to clean the mirror, lens, and any webs or dirt on the inside of the screen.
Special care has to be taken here as once the screws are removed the screen pops out and usually requires some real care and skill to do. It is not worth damaging the screen just to look inside.
Let me know your thoughts and if you have questions I will attempt to assist you.
SD TECH
May 03, 2010 | Hitachi 53SBX59B 53" Rear Projection...
I have a 60" sony projection TV (2005 mod.). I need to know how to take off the front screen (glass) of the TV so I can clean the inside that has gotten dusty.
U can't take out screen,it screws in as part of the LCD screen.Just take a soft cotton cloth,soap it with some water rinse it,gently clean ur LCD screen.
Apr 01, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
I have a toshiba 50inch rear progetion tv. I was
There is one mirror inside. It is easy to remove the front plastic screen by removing the bottom fabric grill (snaps off by pulling outward like a removable speaker grill). Remove several wood screws along bottom edge of screen. Lift up the whole plastic screen frame and pull it away from the TV; but be careful with the control wires that go to the center panel, which snaps off the big screen frame easily. The mirror is right there.
Apr 01, 2009 | Toshiba TP50G60 50" Rear Projection...
Looks like dust behind front glass on phillips 46pp8621
The only way to remove the dust and or spider webs from that area is to remove the front bezel assembly and separate the protection screen, it's better to leave a svc. co. do this because the two screens behind that are very expensive. Hope this helps..
Feb 23, 2009 | Philips Magnavox 51MP392H Rear Projection...
Dusty inside screen
The screen is just a thin plastic sheet, attached around the edges with an adhesive strip.
If you are careful you can insert a hobby knife, oe electricians screwdriver under the edge & prize it off.
If you are unsure, any mobile phone shop would be able to do it for you. Be careful though, Carphone warehouse wanted to charge me £40 for a new screen, as mine was also badly scratched, my local phone shop charged a tenner for the same job!!
Jan 06, 2008 | Samsung SGH-D600 Cellular Phone
Samsung Tocco F480 - Pay Monthly Cellular Phone Logo
104 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
