Question about HP Pavilion dv1000 Notebook
My hp pavillion was no power without ac adapter
My hp pavilion dv1000 laptop was no power without ac adapter please give an advise.
  • 3 Answers
If the pc is not getting power without the ac adapter then most likely the battery is dead if it does not take a charge via the ac adapter then then the battery is no good or the ac adapter is busted
Posted on Apr 28, 2010
Pavilion dv 1000 battery adaptor
You may take it to a tech center to fix it or buy a new charger. As for the cost, it is almost the same. So it is better to get a new adapter.
Replacement HP Pavilion DV1000 AC Adapter 65Watt 18.5V 3.5A
Nov 22, 2012 | HP Pavilion dv1000 Notebook
HP DV1000 won't run normal after a forced shutdown
For this kind of issue, please follow up the following steps to check:
1.confirm the battery and ac adapter connect the laptop normally.Maybe the bad connect lead to this problem. If there are no lights when you turn on laptop, one of possible reason is that your adapter is malfunction.
2.the second possible cause is laptop dc jack failure. If the dc jack is broken or loose, you are required to replace it or repair it.
3.Another possible reason is that there is something wrong with laptop motherboard. For this situation, it includs two kinds of possibility,a failure in an electronic circuit and BGA malfunction.
For more detailed reasons and solutions, please have a look at the following article:
http://www.ifitjams.com/lappower.htm
If you verify your laptop adapter is dead and you plan to order a new one, I recommend one for you on the basis of your laptop model:
Oct 28, 2012 | HP Pavilion dv1000 Notebook
Hp pavillion wont start at all under battery power or under ac power..
I think its the Motherboard problem because if there is no power at all that means the hardware is already faulty. I recommend try to call the manufacturer or go to any computer local centers.
Feb 07, 2011 | HP Pavilion dv1000 Notebook
HP Pavilion dv6000z 15.4" Notebook Laptop PC (AMD Turion 64 X2 Duo Core TL-50 1.60GHz, 1GB RAM, 100G... (d6000z) PC Notebook: My hp pavillion dv6000 dims while having the ac ad...
Go to Control Panel > Power Options
You will need to change the setting for when it is connected on battery and when it is connected on power.
May 14, 2010 | HP Pavilion dv6000z Notebook
My hp pavillion was no power, please give an advise.
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
To verify this, unplug your laptop & try to run it on battery only. Watch out how long it will stay on (if at all). If it didn't work on battery alone, or worked but for a very short time, then your battery is defective.
Apr 19, 2010 | HP Pavilion dv1000 Notebook
I bought a new ac charger for my hp pavillion dv1000 it will not power on
Check and make sure the Voltage on the AC adapter is the exact same as your previous one. Just because the connector fits in the port, doesn't mean it's the right one. Look in your manual to figure out if your AC adapter voltage is correct. If it is, it's possible that you have a dead battery, it happens when surges happen during power outages. If it's so, look on the HP website for a new replacement battery. It should allow you to type in your pavillion model number.
Jan 08, 2010 | HP Pavilion dv1000 Notebook
I used windows vista on ma hp pavillion dv1000 but i didnt worked properly....no audio drvers detected not even supported and as well as some of others too... i need drivers info related to my dv1000
hello
you reis goninstall your system factory setting and your problem e i advise to u use ur laptop very softly
you can give me high rating for this help
please
Oct 23, 2009 | HP Pavilion dv1000 Notebook
When should you change out your laptop battery?
Laptop batteries life will vary depending on use. In my experience it is suggested to replace the battery within 3 years. This depends on your requiring the battery.
If you wish to work mobile then a new battery makes your investment a tool, and should be considered.
Apr 14, 2009 | HP Pavilion dv1000 Notebook
HP pavillion dv1000 won't charge
Try using your laptop without the battery and just using your power supply (new universal or your old one).
If your laptop works on just mains power it means your battery is causing the problem, which is not unusual.
Aug 07, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 Notebook Logo
199 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
