Computers & Internet Logo
Anonymous Posted on Apr 28, 2010
Can I download a recorded programme from Sky + to my lap top computer?
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Apr 28, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3058
Points
7
If your cable/satellite/antenna is ran to your Computer as well as your television then yes you could record via software and you can buy converters for your laptop
Testimonial: "Thanks for your help"
4answers
How Tata sky HD superior than Tata sky?
Tata HD has clearer picture as it has high definition technology while Tata sky just has standard definition .
Regards
How do I record a programme I missed with Sky HD box
You can't record a programme that has already started or has been missed. You'll have to wait for a repeat.
Feb 25, 2011 • Sky Toys
I have a toshiba rdxv60kb dvd recorder,,and can;t tune the programes into my sky box.
I have a toshiba Hdd & DVD / Video Recorder However I can not get it to work with my Sky setr up If I set thimer recording it does not work when I turn it on it will only work pn channels that are not from sky it will not instant record nor will it record programmes prerecoreded of sky HDD it will record everthing other than what I want.
My E-Mail Addres Is fj.gadkey_1@sky .com
My Home hone is uk 01527 545284
Can record Sky programmes but not view live.
You must connect up the TV to the SKY box, via Audio Visual cables too, in order to watch, recorded programs. You need to hook, up, Component, HDMI, or Composite, You select it by an EXTERNAL channel.
Connect the cable running from the wall into the "In" port on the Sky Box HD receiver. This cable brings in the signal to your receiver. Make sure the cable is securely fastened to the receiver, otherwise you might experience image and audio issues.
Attach an HDMI cable into the HDMI port on the Sky Box HDTV receiver. The HDMI is a single cable that provides both HD audio and video signals.
Plug the other end of the HDMI cable into an available HDMI port on the HDTV.
Power on the HDTV and the Sky Box HDTV receiver. Press the "HDMI" button on the TV's remote control. This will display the cable contents of the HD receiver onto the television.
Can't finalising the recorded discs, and can't record at high speed from SKY box to DVD recorder.
instruction man available on line
plug the sky output cable directly into the recorder then press record
New sky digibox fitted. Cannot timer record satellite programmes
I encountered a similar problem when recording and I phoned Sky and they changed my settings to eliminate standby mode for me.
No problem any more.
Sky Plus Planner shows message Please Wait and nothing happens. Cannot therefore play previously recorded programmes or record new ones.
try formatting your hard drive, you will loose all the saved programmes but it may fix ur problem.
follow instructions:
http://nice-design.co.uk/blog/sky-plus-system-fault-how-to-fix-faulty-sky-without-a65-callout-fee
1helpful
2answers
Recording from Sky
you need to connect the satellite box directly to the VCR and record
Hi I just bought a Wharfedale DTR250 twin tuner HDD. How can I connect it up to be able to record sky programmes? On my old VCR all I did was set the VCR to EL1 and the selected Sky programmes recorded OK....
My solution was to return item to Argos, got my money back and will now go ahead and order a Sky Plus Box. Apparently these type of Recorder will not record Sky programs!!
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
