Question about Samsung SyncMaster 204B 20.1" LCD Monitor
Without graphic card how will i get 1600 x 900 resolution in my LCD ? is there any software for that
  • Samsung Master
  • 3,866 Answers
You need a graphics card to display images on your monitor. Are you trying to hook up something other then a PC to this?
the 1600X900 is a resolution that the monitor supports depending on the graphics card and or device its connected to. this is not a software thing but rather a hardware device supportive of the resolution format.
thanks if you have any other commetns or questions please ask otherwise please leave your ratings and feedback for your free answer today.
Posted on Apr 28, 2010
Stretched screen
For best graphics and zero stretch select the highest resolution that your LCD supports. Which is the resolution of 1440X900
Right click on your desktop and select properties.
Click the Settings tab.
Slide the resolution Bar to the resolution of 1440X900
Also select (Highest 32Bit) colour quality on the right of the resolution bar.
Click Apply then Ok.
If you are not able to select the resolution of 1440X900 then you should update your graphics card drivers to the latest version.
To download the latest drivers for your graphics card click here.
Select the following:
Geforce
Geforce 5 FX Series
Geforce FX 5500
Select your operating System
Select your prefered language
Please be sure to rate this session.
Take care!
Norman-Wynne Damstra
Nov 14, 2011 | Belinea Maxdata 1925 S1W LCD Monitor
When the monitor is turned on it appears to work - the "acer" name comes up and then the words "no signal". As soon as no signal comes on the sceen it goes to black and the light turns...
You might have one of several problems.
Your monitor might require a driver for your computer/graphics card in order to show up.
Your monitor's input might be slightly damaged.
Or your graphics card might not have the proper drivers in order to display on that kind of monitor.
I would go online and make sure your drivers are up to date for your graphics card first, then inspect your monitor to make sure no pins from the cable have broken into the input, and then make sure that your monitor is compatible with/without drivers to your graphics card.
Mar 16, 2011 | Acer LCD Monitor X223W
I go to screen resolution but the thing is the resolution is greyed out. please help Acer X193w
You need to install the latest drivers for your graphics card, so your computer can run at a higher resolution.
Nvidia Graphics Driver for Nvidia made Graphics Card.
AMD Graphics Driver for AMD Radeon made Graphics Card.
Select your Graphics Card model and Operating System.
Download and install.
Note: Only use the drivers provided for your make and model of graphics card!!!
Thanking you
damnor01
Feb 02, 2011 | Acer X193W LCD Monitor
Need to know the default resolution for this card
There is no default resolution on graphic cards, only on LCD monitors - on CTR ones there's a preferred resolution.
This card does its best at XGA 1024×768 when used in regular 2D tasks like Office.
Jan 13, 2011 | Dell MRMGA8 RADEON X300 SE, (128 MB)...
My Acer AL1716W monitor flickers, but only when I'm on the internet.
flickering monitors normally mean the lamp is on its way out but this sounds like your PC has issues either with the graphics card or memory. Run a virus check and antispyware software. If you don't have this software try microsoft security essentials its free. and people tell me its good.
Also try changing graphics card settings like resolution and refresh rate changes it might have something to do with colour schemes. Update graphics card drivers and I recently had a similar issue and had to upgrade the graphics card to handle the resolution of my monitor
Dec 30, 2009 | Acer AL1716WAB LCD Monitor
OSD + GNR 19M1 LCD screen
Seems that you have set the resolution on your graphics card to a setting higher than the maximum resolution supported by your monitor.
Try to boot into Safe Mode & lower the resolution of your graphics card. If not possible, go to Device Manager & remove the graphics card from it, then reboot your computer. This will reset the resolution.
You can then re-install your graphics card drivers & get it to work properly.
Dec 22, 2009 | GNR 19M1 19" LCD Monitor
I CONNECTED AN AOC LCD MONITOR TO TO A COMPUTER WITH GE FORCE 5200 AND GOT: NO SIGNAL WHAT IS THE REMEDY? THANK YOU gABRIEL
It could be possible that your graphics card has died but if you try with a =nother screen it may help more as to the problem..
Jun 13, 2009 | XFX GeForce FX 5500 Graphic Card
PENTIUM 3
i am afraid thhat this system has not the AGP slot to see the high quality graphics but you can get the PCI graphic card from the old spare parts shop. it will given the quality even better.
Dec 02, 2008 | Computers & Internet
New monitor but unable to use its maximum resolution settings
no, there's nothing wrong with either your graphics card & monitor.. it just that your graphics card does not support a 1680x1050 resolution. if you want to fully enjoy the resolution of your monitor, you should upgrade your graphics card. purchase at least 256mb graphics card and you will see the difference..
Jan 21, 2008 | Gateway FPD2275W LCD Monitor
Al1917w lcd monitor resolution problem
I have the same problem! Here's what I did: Go into the Display control panel, go to SETTINGS, click on ADVANCED, and then on the ADAPTER tab, then on LIST ALL MODES. There are several 1400 settings. Try them out and see which one is best for you.
Jul 30, 2007 | Acer AL1917W LCD Monitor
Samsung SyncMaster 204B 20.1" LCD Monitor Logo
104 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
