Question about HP Computers & Internet
Screen is going dark/off occasionally, I don't know if it is a display problem or a graphic card problem. Sometimes if I reboot I get the screen comes back after 2 or 3 attempts.
  • 1 more comment
  • glennp2008 Apr 28, 2010
    hp 2230s
    It is a hp2230s only had 9 months from new
  • Peter Wharton May 11, 2010
    Hello glennp2008 What is the model number of your HP laptop? ajblaj
    Novelist:
  • 151 Answers
Hello again glennp2008
Make sure your screen brightness is turned up all the way full. This can usually be done using a combination of the Fn key with one of the Function keys.
Check the display and power options located in Control Panel.
To eliminate any hardware problems, I would suggest using HP's on-line hardware diagnostic tool which you can access directly from this link:
http://h50203.www5.hp.com/hpisweb/customer/HPInstantsupport.aspx?&cc=us&lang=en
Hopefully your screen will remain readable for the duration. If it reports back at there are no hardware issues, you can start eliminating software issues. Use HP's website to update all your drivers, especially ones regarding display and graphics.
Hope this helps. Please don't hesitate to contact me if you require further assistance.
ajblaj
Posted on Apr 28, 2010
Lifebook s6120 display loose connection ?
There is not graphics card it's probably an embedded solution or it's being ran off the processors internal GPU.
If you open the laptop up by one of the hinges there should be a ribbon cable or some sort of large plug which will be your screen cable. Make sure that correctly? inserted in it's slot.
Mar 21, 2017 | Fujitsu LifeBookS6120 Notebook
Display drivers wont work
Dear,
There are two points.
1. Ensure that you are downloading and installing the correct driver for your graphic card.
2. If the fist condition is fulfilled then unplug the graphic card and check the system with the built in graphic card in motherboard and install its driver and get its functionality. When you are ensured that system is working with its own built in graphics then plug it again properly and install the driver. Ensure the proper plugging of your graphic card. Sometimes improper plugging of card cause this issue.
The second step will confirm the two things. one that your motherboard is functional with its own card and the reason is extra graphic card plugged in slot.. and the 2nd is that the card itself causing the issue not the motherboard and the issue was replugging...
best of luck...feel free to ask more...
Mar 06, 2012 | Computers & Internet
Hello, Sir my msi graphics card stoped display ,,i don;t know whether it needs vga bios update or what. when i saw it by turning my pc off it got hot . some times it gives the display but everything big...
hi mrafigkundi,
because you chose to repair by yourself then i will suggest this steps
#1. see if you plug cable data from monitor to VGA correct. if yes...
#2. detach your pci express graphic card from motherboard.
#3. see if some component burn, sometimes it located near pci slot, if it does then you have to change it.
#4. if none of component burn, put again in your CPU
#5 your problem can caused by memory chips defect, you can test it with memory test, its running under dos so you have to reboot it with bootable CD and run VGA memory test.
Mar 12, 2011 | MSI NX7300LE-TD256EH GeForce 7300 LE,...
Fujitsu Siemens Lifebook C1020 laptop display and booting problem
change the ram memory ...this issues appear when the ram memory is not functional like it should..if you have a way to borrow some just to try ..you will make an ideea
If you have more than one boards in the laptop..remove one by one ..and try to boot with the other/s until you locate the one with problem..
Jan 30, 2010 | Fujitsu Siemens LifeBook C1020 Notebook
Hello, I purchased my card about 4 months ago and i m content with it,s performance but i just have one complaint and that is the card gives don,t send error with many new games and sometimes occasional...
Hello
Ok, one thing you need to keep in mind is to always upload the latest driver for your device. You can download it free of charge at the link below, just choose the operating system you are using.
http://www.nvidia.com/Download/index.aspx?lang=en-us
One other thing you need to look at is the cooling of the card. If the card does not get sufficient cooling, it will freeze up your computer. You can have a look at the thermal paste on the cpu of the card, it should still be good though..
If all else fails, i would suggest that you reload windows. Hope this can steer you in the right direction.
Kind regards
Andrea
Dec 27, 2009 | XFX NVIDIA GeForce 8500 Graphic Card
Screen not working but other monitor work
Your "F"keys are multi function. Look for the one with a picture of a monitor. Press the FN key adt the appropriate F key at the same time. You are probably in remote monitor mode. The F key is usually F5 or F8.
Dec 15, 2009 | Acer Aspire 9420-6426 Notebook
Display issues for NX7010 Compaq laptop
Try to plug in an other screen......(graphic component problable shot)
Feb 27, 2009 | HP Compaq nx7010 Notebook
Problem
uninstall ALL video drivers reboot computer should reboot with standard windows video drivers does the screen still play up if so you may have faulty video card.let me know please
Jul 17, 2008 | ATI Mobility RADEON Graphic Card
Graphics question
the problem comes from your graphic card,as far as i know that's a AGP card so next thing u could do is open your computer case take the graphic card out from the AGP slot and clean the slot and pins from graphic card with some contact spray or alcohol wait until spray or alcohol vanish and put the graphic card back power on and see the results
Apr 23, 2008 | XFX NVIDIA GFORCE2 MX 200 (64 MB) Graphic...
Computers & Internet Logo
46 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
