Question about Asus Eee Pc 701Sd Notebook
Can I upgrade the hdd? - Asus Eee Pc 701Sd Notebook
  • 3,866 Answers
Yes the hard drive can go up to 1TB in this system you also can buy a solid state hard drive (allot faster) cost more tho but worth it.
good luck to you and please do rate your free support email today and leave feedback.
Posted on Apr 28, 2010
Testimonial: "Thanks for your help."
Sony Vaio pcg 4l2m - can this be upgraded to keep the chasis but put in new motherboard, hdd, memory etc?
I don;t remember seeing a motherboard that will fit. The cockets and control ports are in a different place. The hdd , RAM and OS can be upgraded.
Feb 16, 2016 | Sony Computers & Internet
I want to upgrade the HDD of a Toshiba Satellite P200-156 to 500GB/640GB/750GB or more if possible but I'm not sure which specifications must be compatible. The 250GB HDD is a Fujitsu MHX2250BT Serial...
I think its okay to upgrade your HDD till 1TB, just make sure that HDD have serial ATA port to connect. my little advice is when you want to upgrade your HDD is look your mainboard specification, because HDD is work when it can recognized by mainboard. hope this useful, regard riyan.
Jun 08, 2011 | Toshiba Computers & Internet
What is the largest HDD compatible on a Sony Vaio VGN FS630/w laptop What max HDD size can I upgrade now? Currently my laptop has 80GB HDD.
That model laptop will take anything up to 500GB and yes you can upgrade now or whenever you want.
Regards.
Aug 07, 2010 | Sony VAIO VGN-FS630/W Notebook
Philips DVDR3450H. How format the HD?
Found a document DVDR3450H_3452H_3460H_eurp FWUpgradewk635.pdf Describes procedure of firmware update and disc formatting. Some cut'n'paste from the document:
2. Preparations for new HDD
In the event when the set unable to boot up or recordings not stored due to an defective HDD, the HDD will have to be replaced with the steps describe below:
1. Replace the Faulty HDD with a new HDD.
2. Before connecting the new HDD on the Digital Board ,the jumper pin at the connector of the HDD is to be removed.
3. Connect the new HDD to the Digital Board.
4. Power up the set . It will open the tray and prompt to load the upgrading disc.(the upgrade disc is
the same disc under firmware upgrading.)
5. The set will display
“Load”.
6. Put the upgrade disc and close the tray and the set will show
“Copy” ……… “Boot”
7. The rest of the procedure follows the software upgrade given in 1B -Procedure to apply the firmware upgrade.
*Note : 1)Do not press any button or interrupt the main supply ,otherwise the set may
become defective.
2)When the HDD formatting is successful ,the set will go to standby mode.
Jan 17, 2010 | Philips DVDR3450H DVD Recorder/HDD...
How to expand/upgrade the HDD memory on Toshiba NB200/205?
It is always possible to upgrade to a larger HDD as they are pretty much standard for all makes. If you replace your current hard drive then you will have to re-install your O/S and all your programmes on it. A better option would be a fast external HDD. You can get 1.5TB, 7200rpm for around £100. This is the best option if you are simply looking for more storage, This will not improve the overall performance of your machine but will allow you to store more stuff.
Oct 11, 2009 | Toshiba Computers & Internet
HDD upgrade to extensa 6601 Wlmi.
The BIOS determine the maximum size hard drive that can be installed in the laptop. Put a smaller hard drive in the laptop say 120Gb hard drive, you will lose approx 10% in the formatting process.
Use the 180GB in another laptop or put it into an USB hard drive adapter case and use it as a portable external hard drive.
Jul 18, 2009 | Acer Computers & Internet
The Bios wont recognise the HDD (hard drive)
You are correct your bios needs to be upgraded
Go to Toshiba's site and, download the upgrade and, follow the directions to install it then;reboot.
Do not unplug or, turn off the computer during the upgrade for any reason and, have the battery installed and, fully charged when you start the procedure.
May 20, 2009 | Toshiba Satellite A65-S126 Notebook
Max HDD upgrade the e-pc 42 will support
ya you can upgrade till wat you want ??? dont wrry abt it you can make slave harddisk....and maste one is your 10 gb hdd
Mar 29, 2009 | Computers & Internet
Hoe to install a diferent windows on a DELL
If HDD makes shshshsh.... or spinning sound or generates heat, your HDD might be ok. Next Try with XP sp2 cd. If it again cant detect HDD, go to BIOS setting and watch if the HDD is showing it's status. If Bios can not detect HDD check HDD cable and power cable inserted in HDD. Replace them if needed. Format the HDD with another PC. If you still have problem replace HDD with new one. One thing you might use your corrupted HDD as a slave drive later, i hope.
Keep informing.
Feb 23, 2009 | Dell XPS 600 PC Desktop
HDD Upgrading
mshahzad_nas,
Of cause you can upgrade the hdd to 160GB, the system will detect it, don't worry.
Meanwhile, make sure you have the drivers ready for all the hardware, as new new hdd need to be install with a new windows, and u will need the driver for all the hardware to function properly, like wifi and video.
In case you lost your driver disc, here's the link for you to download
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=316666&lang=en&cc=us&prodTypeId=321957&prodSeriesId=316664&taskId=135
Your rate for my solution is much appreciated, thanks.
Jan 09, 2009 | Compaq Evo N610C Notebook
Asus Eee Pc 701Sd Notebook Logo
165 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
