Question about Panasonic CT-36SX12 36" TV
I went to Radio Shack to buy my open 6.3 slow-blow
I went to **** Smithj Electronics to buy an open 6.3 slow-blow 125v fuse and they didn't have it. But they did have a 6.3 slow-blow 240v fuse. Will this fuse work or do I have to look for the 125v fuse?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 125 Answers
Yes you can try it,Go to this website Mats Electronics they list all kinds of Parts/Supplies
1-800-628-1118
Posted on Apr 28, 2010
I just got a free sharp LCD LC19SB27UT and it has a power problem, I opened it up and notice a fuse was dead, this all happened because a friend was using it in a thunder storm, I went to radio shack and...
on the power board you will see a black flat ac converter with this on it + ~ ~ - on it check this with a meter its more than likely to have gone as its the first thing to go in a storm. the + and - can be the other way round ~ ~ is the mains volts in and + - is the volts out if the ~ ~ has no resistance it has blown and it will keep blowing the fuse check the + - and you should have a resistance from the rest of the power board.
Jun 05, 2017 | Sharp LC19SB27UT LCD TV
Blew a fuse what kind dose it take is it a slow blow fuse or fast blow one,i took out the old fuse and it reads le.3a/250v is it a 3a or .3a
It is a 3A/250V fuse, also known as a 6A/125V fuse.
Power amps generally have slow blow fuses.
If this is helpful, please be sure to hit the "Thumbs-Up" for me!
Jan 24, 2010 | Polk Audio PSW202 Subwoofer
Tv problem with a fuse
Your degausing thermistor is bad and needs to be replaced. The part number is D4DDF1R50001
Once that is replaced put a new fuse in put the set back together and you should be good to go. You will need to replace the fuse with the correct size and its part number is
XBA2A00101F
Sep 10, 2009 | Panasonic CT-36SX12 36" TV
Panasonic ct-32sl13g blowing fuse by power supply
You will need to remove the back of the TV. Don't worry, it's not that bad.
There are 4 screws across the top, one on each side, one right next to where the power cord goes into the back of the case, and the two more by all of the video connections **These are the most important to remove because they attach the main board to the back of the case.
Once you have remove the screws then the entire back of the set will slide off. If you look where the power cord attaches to the board you will see a small fuse. This is a 6.3 Amp 125 volt fuse. You can replace it with a 6.3 Amp 250 volt fuse from your local Radio Shack. A four pack costs between $3 and $5.
Make sure that you check that it works before putting it all back together. Check for any loose connection cables while you're back there. I found a few when I did this.
Apr 15, 2009 | Panasonic CT-32SL13 32" TV
Sony str-de845 Powers up, relay clicks, fuses BLOW!
This condition, may be produced by defective components (Q506, Q507). you can remove those transistor, replace the fuses, power-on and wait for relays click. if the fuses not blown again, them replace both transistor.
Mar 05, 2009 | Sony STR-DE845 Receiver
RCA HDTV R52WH74YX61 blown fuse
there are 3 small red rectangular shape objects to the right of the flyback transformer these are fuses the fl231 most time goes bad .fl231 is the location number under the green circuit board. the location number can also be wriitten on top(brown side of the cicuit board)
you may have to put back the .6a you took out was it ok?
TRITRONIC ELECTRONICS sell parts . cathray 416 241 1106 sells also
Nov 22, 2008 | Televison & Video
6.3a slow-blow 125v fuse
Hi, If the fuse physically fits into your unit then it will work. However- - - WARNING! Although 6.3 amps on a 250v fuse will allow the current to flow it will not afford you the circuit protection you require for a 125v circuit. If the circuit develops a fault then there is a danger that you burn out the circuit before the fuse. As you have already blown one fuse I would suggest tracking down the fault before you do any thing else.
The Scrivener.
Oct 12, 2017 | Pioneer VSX-D458 Receiver
I can't find a 6.3 125v fuse
If you look on the board that the fuse sits on you will see printed it states 6amp 125 Volt / 3amp 250Volt. This means that you can use either one. I think that is why the fuse states E.6.3 125Volt... I think it means either 6 amp (125 Volt) or 3 amp (250 volt). I noticed on the back of a fuse package that I bought that it stated these were interchangable so I put two and two together.
Jan 11, 2008 | Panasonic CT-36SX12 36" TV
It will work, the amp rating is most important, 125v / 250v does
not matter.......note: if you blow the fuse again, the TV will
need service.................T.
Dec 08, 2007 | Panasonic CT-36SX12 36" TV
6.3 slow-blow fuse
Important parameter is 6.3 amp slow-blow,voltage rating = 125v
or 250v OK, No Worries.............................T,
Panasonic CT-36SX12 36" TV Logo
207 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
