Question about Ricoh Aficio 450 Copier
What is the cause of error sc990 in 2054 copier and what is the remedy
  • 3,866 Answers
SC990: Communication error between BICU and IOCSS board
This board will need to be replaced as a remedy and frankly to tell you the truth and nothing but the truthh so help me God you going to be neck deep into a repair bill.
I would do what i got to do here or pull out of that situation most people purchase repair contracts to help them foot the cost.
sorry to break it to you but facts are facts and they need to be stated up front.
for my FREE info today can you leave a rating and some feedback on how well i serviced your free question today?
thanks
Posted on Apr 28, 2010
  • 4,234 Answers
I was sent the following after an inquiry. Hopefully this provides a little additional info:
SC990 is a level 'b' service code which basically means powering off / on is sufficient to reset this error.
If it's constantly re-occuring after a hard boot then there is clearly a bigger problem that needs correcting.
SC990 is not clear cut as it can and does occur for many different reasons.
Bad drum grounding, HDD fault, loose/snagged harness, blown internal fuses, corupt NVRAM, corupt firmware, bad memory, blown BICU, controller, PSU etc.
Dan
    Problem Solver:
  • 10 Answers
Software defective
Posted on May 08, 2010
How do i fix error code L4-06 on sharp MX-2300
Trouble content
When separating the primary transfer belt unit,
change in the separation position sensor
characteristics is not detected within the specified time.
Section
PCU
Case 1
Cause
Harness connection trouble between the PCU PWB
and the separation position sensor
Check and remedy
Check the harness between the PCU PWB and the separation position sensor.
Case 2
Cause
The belt position sensor is not interrupted or it is always interrupted.
Belt separation clutch operation trouble
Check and remedy
Use SIM6-3 to check the belt separation operation.
Case 3
Cause
The primary transfer belt unit is not installed.
Check and remedy
Install the primary transfer belt.
Hope this help you, good luck!!!
Nov 23, 2015 | Sharp MX-2300N Color Copier
My sharp al2021 showing f5-02 and e7-11 what can do to work
The service manual was not available for the AL-2021 but the error codes are the same for the AR-5316
F5-02 error cause and remedy
Sharp AR 5316 Service Manual Page 27
E7-11 error cause and remedy
Sharp AR 5316 Service Manual Page 26
Jan 07, 2015 | Office Equipment & Supplies
Sharp fo-2081 System error u2-00
U2 04 Content EEPROM serial communication
error
Detail Error in communU2 04 Content EEPROM read/write error (Serial
communication error)
Detail EEPROM access process error
Cause EEPROM abnormality
Check
and
remedy
Check that the EEPROM is properly set.
Use SIM 16 to cancel the trouble.
Replace the MCU PWB.
Oct 18, 2013 | Sharp AL 1631 Copier
Error codes
Content - ICU communication trouble (PCU
detection)
Detail - Communication setup
error/framing/parity/protocol error
Cause - Slave unit PWB connector improper
connection
Slave unit PWB - ICU PWB harness
trouble
Slave unit PWB mother board connector
pin breakage
Check and remedy
Check the slave unit PWB and the ICU
PWB connector connection.
Check the copier earth
Jul 25, 2013 | Sharp AR-M450N Copier
What is the error U2 ?
U2 04
Content: EEPROM read/write error (Serial communication error)
Detail: EEPROM access process error
Cause: EEPROM abnormality
Check and remedy: Check that the EEPROM is properly set.
Feb 10, 2011 | Sharp AR-M205 Copier
Brother HL-4040CN. What does error 37 mean? Thank you!
Belt unit temperature sensor failure.
Step 1:
Cause: Belt unit temperature sensor harness connection failure
Remedy: Check the harness connection between the belt unit temperature sensor and registration relay PCB, and the one between the registration relay PCB and engine PCB. Then reconnect them.
Step 2:
Cause: Transfer HVPS PCB unit failure
Remedy: Replace the transfer HVPS PCB unit.
Step 3:
Cause: Engine PCB failure
Remedy: Replace the engine PCB ASSY
Jan 25, 2011 | Brother HL-4040CN Laser Printer
U2-40 error code on AR5012n
U2-40 Content CRUM chip communication error.
Detail
An error occurs during communication
between the MCU and the CRUM chip.
Cause
CRUM chip abnormality.
Developing unit disconnection.
MCU PWB abnormality.
Check and remedy
Replace the chip.
Check installation of the developing unit.
Sep 07, 2010 | Sharp AR-160 Copier
Error U2-40 Call for Service
Clear the trouble with SIM 16.
Details Error in MCU-CRUM chip communication
Cause CRUM chip failure
Developing unit contact trouble
MCU PWB failure
Check
and
remedy
Replace the CRUM chip.
Remarks CRUM communication error
Jul 06, 2010 | Sharp AR-M237 Digital Copier
Model SF2530 photocopy Erroe F1 how to reset
F1 00 Content Sorter communication trouble Detail Communication line test error occurs when power is turned on or after the exit of a simulation mode. Improper communication with sorter Cause Improper connection or broken wire of connector or harness between copier and sorter Sorter control PWB defective Control PWB (PCU) defective Malfunction due to noise Check and remedy Clear by turning the power supply OFF/ON. Check communication line connector and harness. Replace sorter control PWB or PCU PWB. F1 02 Content Sorter transport motor error Detail Transport motor drive trouble Cause Motor lock Check and remedy Check transport motor operation with SIM3-3. F1 03 Content Sorter guide bar rocking motor trouble Detail Sorter guide bar rocking motor drive error Cause Motor lock Motor speed error Overcurrent to motor Sorter control PWB defective Check and remedy Check guide bar motor operation with SIM3-10. F1 04 Content Sorter indexer lower limit detected Detail Indexer has exceeded lower limit. Cause Sensor defective Sorter control PWB defective Check and remedy Check sensor with SIM3-2. F1 05 Content Sorter indexer upper limit detected Detail Indexer has exceeded upper limit Cause Sensor defective Sorter control PWB defective Check and remedy Check sensor with SIM3-2. F1 06 Content Sorter bin shift motor error Detail 1) Bin shift is not completed within 2.5 seconds after bin shift request Cause Motor lock Improper motor speed Overcurrent to motor Sorter control PWB defective Check and remedy Check bin shift motor operation with SIM3-4.
Jan 11, 2010 | Sharp AR-5316 Advanced Digital Imager...
Help
H5-01 indicates tha the paper sensor is defective in the fusing unit. The only way you can try to reset that one is buy turning the power off, wait 30 seconds and turn the power back on.
If the error code returns the fusing unit will have to be fixed to take care of the paper sensor.
Jul 20, 2008 | Sharp AR-M237 Digital Copier
Ricoh Aficio 450 Copier Logo
1,006 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
