I have a takara multimedia tv/dvd combi, 15". the dvd players works ok but when I tuned the tv in, I cannot get the sound working? What should I do?
  • catinwash Apr 28, 2010
    thank you very much, I appreciate your help
  • 3,866 Answers
If you get sound from the internal DVD and not on regular channels then you got a bad tuner/decoder board inside the tv unit. This will require a repair shop to fix.
Now i have not seen the tv but from what your saying that is what it is. the tuner has failed and that is why you are not getting sound from that part of the tv.
Thanks i hope this helps please do press the accept button for my efforts.
Posted on Apr 28, 2010
I have dvd tv combi and the sound will not go above 30. I have tried going into settings and the volume but nothing happens.
follow this steps and fix it. God bless you
No sound
  1. Check if the TV and Amplifier (if connected) is turned on and set correctly.
  2. Check if the TV, DVD player and Amplifier are connected properly.
  3. Make sure the TV, DVD player and Amplifier volume are not set to Mute.
  4. There will be no sound output during Reverse Play / Pause / Step / Slow / Search.
  5. If the DTS soundtrack is enabled in the DVD Disc Menu, but you are using Stereo Analog audio, the sound will not work. Try switching the soundtrack to Dolby 5.1 or PCM mode in the Disc Menu.
Oct 25, 2013 | Televison & Video
Disque inconnu
Use the remote to find the settings and change the language back to English.
Oct 20, 2013 | Televison & Video
I have 2 alba tv/dvd combi's.1 in kitchen & 1 in bedroom.After digi switchover 1 in kitchen is fine after re tuning.The bedroom tv only has a few stations after numerous re tunes.Both work off
The one that does not work: have you tried to unplug it for a while from power and plug it back to see if it will reboot and allow you to program?
Apr 08, 2012 | Televison & Video
Hello, I want to buy a Toshiba RDXV-60 Combi VHS/DVD Recorder in the United Kingdom and use it in Greece. Can you tell me if it will work here in Greece?
Yes, that is true. Some UK electronic's sound is different from other regions. There was a TV my friend bought, it's from UK the TV didn't bring out sound. The sound had to be converted before it worked. Electronics repairers has a way of converting the sound to work with your region.
So I would advise you shouldn't buy the Toshiba RDXV-60 Combi VHS/DVD Recorder because if you do, you are taking a risk.
When you get to Greece you can get a Toshiba RDXV-60 Combi VHS/DVD Recorder.
I hope this is clear.
Good luck.
Jun 27, 2011 | Toshiba Televison & Video
DVD region playback error
Went into the settings menu, searched for the 'default' tab and reset setting to default & hey presto....all ok!!
Simple when you know how!!
Apr 21, 2008 | DMTech Televison & Video
No SOund
cheak sound output settings and cable to pcm not dolby digital
Feb 02, 2008 | JVC DR-M10SEF DVD Recorder
URC22B universal remote controller 15 in 1
Doing some searching I came across this, I hope it helps.
From instruction booklet
Power on the control device or VCR and put the tape in.
Press on the SET key continuously,then press the device key you want to set.For example, TV1/2,or VCR1/2,or SAT/CBL or AUX.
Then the LED is on, release the key you press.
Press the SET key again and release it,then you will go into QUICK SEARCH MODE and the LED will flash all the time.
Press the POWER key once at the device,URC22B will send another POWER signal of the next code.(If VCR/AUX, you will press the POWER or PLAY key). Observe if the device works(POWER OFF or PLAY),if it works, go to next step , otherwise repeat the step
whenever you want to leave SEARCH MODE,please press the device key,(TV1/2,or VCR1/2,or SAT/CBL or AUX.)
then the LED is off.
Then check other keys like [CH+/-],[VOL+/-] if they can be controlled.If cant be controlled,go back to the step
Nov 27, 2007 | Zenith ZN110 Remote Control
Connecting a dvd player to a BUSH Bush BTV180T 14in TV/VCR Combi
if there is a scart connection on your bush tv then
you can use your panasonic dvd player on it, trust me
just look all over the remote carefully for an AV button, or failing that press channel up or down whilst the DVD is powered up and playing a disc and you will have solved it
hope this helps mate
Nov 05, 2007 | Bush DVD142RC 14 in. TV/DVD Combo
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
