Question about Cell Phones
Samsung SGH J-750 has no sound, no ringtones etc when the slide is flipped on, but when it is closed, you can't hear any sound. Is there any settings to activate its speaker again when the slide is open?
  • 713 Answers
Hi,the bitter truth is that there is no settings that activates the speaker of the phone when slide open or closed,the problem is from the flex connector cable which is associated with the sliding of the phone,the flex cable needs to be replaced,However you have to disassemble your phone to get the flex cable.
You can get a well detailed description of how to disassemble your phone and how much the flex cable costs at;www.formymobile.co.uk
Thanks and take care
Posted on Apr 28, 2010
Downloading
Your computer is full of potential free ringtones for your Samsung T229 (also known as Samsung SGH-t229, T-mobile t229) :
By Bluetooth:
The Samsung t229 is Bluetooth-enabled. Bluetooth is a wireless system which lets you connect your cell phone to computers, headsets, car kits, etc. If your computer is also Bluetooth-enabled, simply establish a connection between both devices and transfer your music files from your computer to your Samsung t229.
Simply record sound directly:
Since your Samsung t229 has a sound recorder (also known as "voice memo"), a very simple technique involves simply placing your phone near your computer's speakers, playing whatever music or sound you would like as a ringtone, and recording it -- you can even use your voice, your child's voice or even your cat's "meow!" Record it with your mobile and there you go! Unless that function was specifically blocked on the Samsung t229, you should be able to navigate to the ringtones section and choose your new recording as a ringtone. Of course, the quality will not be ideal but, after all, it's free!
Downloading using the phone
NOTE: MegaTones, HiFi Ringers, and Voices & Sounds are stored at Menu > Fun & Apps > Files > Sounds > Sounds. To download using the phone, perform the following steps: 1. At the main screen, select t-zones. 2. Scroll to and select Music & Sounds. 3. Scroll to and select HiFi Ringers, MegaTones, or Voices & Sounds. 4. Scroll to and select the desired category. 5. Scroll to and select the desired tone. 6. On the preview page, select ACCEPT. 7. After the tone downloads, select Play to preview the tone. 8. Select Set as. 9. Select one of the following options:
  • myFaves ringtone: To set as a myFaves® ringtone. Scroll to and select the desired myFaves contact.
  • Default ringtone: To set as the default ringtone.
  • Caller ringtone: To set as a caller ringtone. Scroll to and select the desired contact.
  • Alarm tone: To set as an alarm tone. Scroll to and select the desired alarm. Turn on the alarm and select the desired time and date.
10. Select Save.
Apr 27, 2010 | Samsung SGH-i300 Cellular Phone
My Samsung SGH-X507 keeps having a screen that is flashing "SGH-X507" and off on. I have tried taking the battery and sim card out and nothing helped.
Hello
You are having a flex problem.
A flex is found in Flip phones and slide phones,it is what connects the screen of the phone to the panel of the phone.
Possibly In the cause of dropping the phone,the FLEX shifted from its original position.
What you should do is this;
.open your phone
.you will see something like a little wide plasticlike cable (that is your flex)
.remove it and fix it back properly (be careful) you should hear a click sound
.close the phone and switch it on.
if you cant do this yourself,get somebody with a bit of experience to do it for you
If the problem persists then your flex is weak and needs to be replaced.
Thank you for visiting fixya
Feb 24, 2010 | Samsung SGH-x507 Cellular Phone
Message ringtone on my phone isnt loud enough.
you have to change your tone or loud tone and must reset the volume of your message tone
Jun 09, 2017 | O2 Samsung SGH-E250 Cellular Phone
Cant get downloaded ringtones to play as message tone
AT FIRST GET THE TONES IN PHONE MEMORY.NOW GO TO PHONE PROFILE IN PHONE SETTING.THEN EDIT PROFILE.SLIDE TO NEW MESSAGES.THERE YOU CAN SEE THE OPTIONS
May 01, 2009 | Samsung SGH-E251 Mobile Phone - Black
Samsung SGH-a736 Cellphone Ringtone Problem
how to download music on samsung sgh-a736.
Mar 01, 2009 | Samsung SGH-D900 Cellular Phone
How can i change the ringtone in my samsung sgh g600
settings:- sound settings:- incoming call:- ringtone
Feb 02, 2009 | Samsung SGH-J600 Cellular Phone
How to change a rington on Samsung SGH-F700V
Settings>Phone settings>Phone Profile>Normal>edit>Call alert type and select your ring >ok
Dec 27, 2008 | Samsung SGH-d407 Cellular Phone
Sound Problem
Reset your sound settings, and see if this works. You will need to change you text and ringtone again after you do this.
Go to Settings>Reset Settings>Sound Settings.
If asked for a number or code the generic code for samsungs is 00000000
I hope this helps
Nov 04, 2008 | Samsung SGH-E900 Cellular Phone
Model No.Samsung SGH J600
go to "settings" or "sound settings" (anything relating to sound settings or setting")
you should find volume control settings for increasing the ringtone.
if it is still low after doing through that process mybe it is time for you to change you sound speaker(they do normally get worn with constant use and would need a change)
good luck.
May 14, 2008 | Cell Phones
Samsung SGH-E530
try flashing the phone, it worked for one of my customers
Dec 09, 2007 | Samsung SGH-E530 Cellular Phone
Cell Phones Logo
67 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
