Question about Zanussi ZWF1630 Front Load Washer
ZWF1630W I have a zanussi ZWF1630W washing machine, which is not spinning. Belt is on and is ok, also tight enough, open the motor inner part as thought was burnt but there are no signs of burn / gone, takes water, and through away but not always empty water. When turning on it takes the water but when starts to spinn it gives contact to the mottor adnd tries but cant spin. thanks
  • 269 Answers
I trust that the drum can be turned by hand.It seems like the filter is blocked you will have to drain the water and remove the filter check that it is clean and the pump is free,with filter out put to spin or drain and see that the pump blade is spinning if not then something is jammed in pump try to free and then replace filter and check for leaks.Check also drain hose not kinked or drain blocked.Hope this helps.
Posted on May 05, 2010
Washer not working
The spinner's belt might be loose or broken, that's why it doesn't spin... Open the back part and you'll see inside the belt and the motor that makes the noise.
post me results...
Feb 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Zanussi fj12544 fills but won't wash
see this probably cause:
t doesn't pump or spin
frozen pulley or broken belt, replace
It pumps, but doesn't spin
lid switch defective,motor coupler defective,belt broken,clutch broken,drive motor defective.
It spins only with the lid closed
lid swtich defective.
Jun 18, 2012 | Zanussi ZWF1420W Front Load Washer
I have a zanussi zwf1630w washing machine. It loads with water then nothing else happens other than the clock/ timer counts down. I've tried draining and resetting but the same occurs. Thanks in...
You must check the output from the timer unit and ensure that the voltage to the MOTOR is present. If not the TIMER unit is faulty and must be checked. If voltage is present then the Motor, the capacitor to the MOTOR must be checked. check the relay and the wiring to the unit.
Jun 15, 2011 | Zanussi Washing Machines
Tumble dryer not turning with heavy load
It could be the problem. Check first to see if belt is tight enough and not slipping on drum. The spindle or axle the drum rotates on could be worn out. Try lubricating it if you can.
Dec 16, 2008 | Zanussi TC7102W Electric Dryer
Zanussi Aqualux washing machine
the belt is a tight fit so you need some strength
remove top. loop belt over the motor pulley and start belt onto drum pulley. turn drum pulley and belt will work its way on. there is just enough room to do this
Oct 08, 2008 | Zanussi F1045W Front Load Washer
FITTING NEW BELT ON ZANUSSI WASHUNG MACHINE F1045W
It is'nt any adjustment on those machines. They were fitted with eleastic belts. Is the belt not tight enough, you need a new belt.
Jan 23, 2008 | Zanussi F1045W Front Load Washer
Hoover Premier 10.1 kg washing machine
do you actually see the motor spinning? or think you hear it, check the belt hasn't come off, or gone slack, it needs to be fairly tight but not too tight, if the belt and pulley go round but the drum doesn't then you have serious damage and need a new inner drum hope i have helped and if i can help more get back to me, i am an appliance engineer of 20 years
Oct 05, 2007 | Washing Machines
Wash but no spin
1st of all is there a spin cancel buuton on this machine and has it been activated, or is there a spin speed selector knob and has it been turned down...is inner drum easily turned by hand.if it is ok then belt tension could be suspect (tighten)im sure there is an out of load balance detection circuit on the main circuit board....also is it draining ok because it wont spin until it cant dectect low or no water prior to final spin.....also if it has a programme dial the select a spin programme on another section of selector dial.........hope this is of some help...
May 08, 2007 | Zanussi F1045W Front Load Washer
Open Questions:
Zanussi ZWF1630 Front Load Washer Logo
191 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
