Question about Canon PowerShot G2 Digital Camera
Won't power up. I have tried new battery & connecting power adapter
  • Canon Master
  • 3,866 Answers
You got a bad powerboard inside the camera or the flash capacitor is blown out thus not allowing power to pass threw the cap to the rest of the camera (very possiable) take it to a camera shop for a estimate i bet you it will not even cost $30 bucks to fixy if it does then it may not be worth it.
But a camera the has a new battery and does not power on would be the powerboard inside or the flash capacitor.
thanks and please do rate and leave feedback for your free answer today.
Posted on Apr 28, 2010
I can't control click or shift click
POWER SUPPLY & BATTERY PROBLEM
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Aug 11, 2012 | ASUS G2S-B1 Notebook
I hav a hp p6570. the battery used to work jus fine until one day suddenly it stopped charging and an amber color light started blinkin. dis won't stop. my lap won't start till its connected to the...
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Oct 04, 2010 | Dell Latitude D600 Notebook
My baterry won't charge... Connected to AC adapter.. WIndows 7 shows plugged in and cheging but battery charge won't go up. I have replaced battery and AC adapter both but still same issue.
Sep 24, 2010 | Toshiba Satellite M115-S3144 Notebook
When I connect Adapter to laptop the green light on adapter goes off, if I disconnect from laptop, the green light on adapter stays solid, can u help what is the problem, and how to solve it.
Sep 20, 2010 | Acer Aspire 6920 Notebook PC
It will not power on. will not take a charge. I have removed the battery and it will not even indicate the power cord is connected
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
Sep 18, 2010 | Velocity Micro Notemagix M10 Gx Netbook
Hey hi this is nammy........my acer 4736z battery is not charging.....actually whn i plug in, the orange light comes for a while and it shows tht battery is charging but after a few seconds it loses...
Sep 15, 2010 | Acer Aspire 4730-4947 Notebook
Laptop wont turn on, with battery one light flashes green for a second without battery and connected to the mains it does nothing.
Sep 05, 2010 | Acer Aspire5100 Notebook
When connected to power my computer often drops to battery mode. I have changed the adaptor but it doesnt charge consistently
Sep 02, 2010 | Dell Inspiron 6400 Notebook
Have power problems with my Pavilion dv 5016 EA laptop.New battery but battery power runs down even when operationg connected to AC power
Aug 22, 2010 | HP Computers & Internet
Hp nc4200 won`t start
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
If this did not work, try also disassembling the laptop & make sure that all main components are seated properly. Also make sure that all ribbon cables interconnecting the various components of the laptop are tightly connected.
Dec 28, 2009 | HP Compaq nc4200 Notebook
Canon PowerShot G2 Digital Camera Logo
145 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
