Question about Nikon Coolpix S210 Digital Camera
Nikon lence is not going inside , It showing lence error
HI
Its under warranty , can i get warranti for it , and what could be problem
Thanks for the same
BR/
Pradeep Shukla
Ya even I hav d same problem..!! I dnt think its covered under warranty..u will have to pay d service charge.
Apurva ,Lucknow
Posted on Oct 20, 2010
Hello! I have a normal NIKON N65 SLR camera. I am going to buy a digital SLR camara. Is it possible to use my old NIKON lences for my new NIKON digital SLR body? Thanks in advance! Adrian
Yes for the higher end cameras - not for the cheaper ones as they use a lens with a motor inside instead of the one in the camera body (you can use your lenses and focus manually)
Oct 23, 2013 | Photography
Lence error
Checkout this tip about digital camera error messages
Lens Errorfix for Digital Camera
heatman101
Aug 14, 2011 | Nikon COOLPIX S570 Digital Camera
Lens error shows up when you turn on camera and lens won't open
This occurs when the spring inside the lens is out of place. Then, the lens is unable to move and autofocus, causing lens error. It is practically impossible to repair it yourself. You will only make it worse if you are not a trained professional. I have tried it myself on my Nikon P1 camera.
The best thing you can do is to take it to a service center for repairing. If the camera is under guarantee, then repairs will be free. If it is not under warranty, you can expect to pay under $50.
Cheers
May 02, 2011 | Nikon Coolpix P1 Digital Camera
On 15 th november i buy 1 nikon coolpex3000 after 3rd day cam shows lences errer with in 3 days why the problem occuer pl advice me
From the ebay listings many Nikon digital cameras have lens movement problems. Many returned to the store for full refund.
Dec 11, 2010 | Nikon Coolpix S3000 Digital Camera
When I Turn on the camera the lence does not be still and after some time it showing lence error in a white screen
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Sep 06, 2010 | Nikon COOLPIX S200 Digital Camera
Nikon d40x error saying "error: press shutter release button again"
check the lence is working properly then the focusin option is auto or manual the auto focus 18-55 lence is properly fixed on mount or not
Oct 18, 2009 | Nikon D40x Digital Camera
Lance alignment is disturbed
hi,if you are a tecnition then open yor camera and remove the lence assembly,then remove the motor and clean the lence unit properly ,and check that smothness between lence beralls, it must be rolling smothly ,and roll the moter by using adapter of 5 volts ,roll motor both side ,after that fix it properly ,now you can check it by put suply on motor and see what has be done,if lence responce smothly in and out then fix it with camera,and see the magic
Aug 25, 2009 | Nikon COOLPIX L10 Digital Camera
Use of teleconvertres
Teleconverters are not recommended with variable aperture and slow zoom lenses. Since there is an additional element, the effective max. aperture will get reduced to about f/8-11. So it is not worth the money.
Dec 24, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon Coolpix S210 Digital Camera Logo
50 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
