Question about Garden
My Honda 5.5hp pressure washer always started
My Honda G200 5.5hp pressure washer always started first time I've had it 7 years.
Now I have oul coming out of the top of the gold block (changed the washer) and also it won't start propably through me adding some old unleaded petrol.
The machine is not used a great deal and has never had a service.
I live near Manchester Airport.
Many thanks in advance.
Paul
2 Suggested Answers
  • 21 Answers
SOURCE: Which type of oil do I use for my Honda G200 5.5hp
straight 30 weight oil
Posted on Aug 29, 2010
Testimonial: "Many thanks."
How do i fix a honda landa 3500 pressure washer, when the water doesn't come out when started?
Check out the trigger mechanism. Water should come out at any time, even when you do not have the unit started.
Aug 22, 2016 | Honda Landa PG 3500 PSI Pressure Washer
HOW DO I DRAIN THE WATER FROM MY HP WASHER FOR WINTER
What I've always done is just disconnect the water hose then start the washer and pull the trigger till no more water comes out. You don't want to run it very long at all after there's no more water though, you can quickly overheat the pump if it is ran without a water supply for too long. I've been doing this for the past 3 years with one of my washers and haven't had any problems with the pump.
Oct 05, 2012 | Powerboss 020309 3000 psi 2.5...
Service manual for Honda g200 engine
Hello, the manual you requested can be downloaded at the following link:
http://engines.honda.com/parts-and-support/owners-manuals/g200
Hope this is what you have beel looking for.
May 26, 2011 | Honda Garden
I can not pull the string to start the engine of power washer
Try removing the spark plug then pulling the cord! If the cord pulls then you cycle the engine a couple of time to see if fuel is coming out of the spark plug hole! If no fuel present replace spark plug and try starting the engine. always have water running through your washer before you attemp to start!
Jul 17, 2010 | Honda Pressure Washer PSI 3000
Last year around this time I tried to start my
Carburetor is probably gunked up from old gas left in system. It will need some cleaning and / or dissasembly.
Have it repaired at a reputable mower or small engine repair shop. When being stored for long periods, run it out of gas or use a fuel stabilizer in the gas to prevent this from reoccuring.
May 13, 2010 | Honda 2500 PSI Gas Pressure Washer
OUR KARCHER 2600 PSI PRESSURE WASHER W/ HONDA ENGINE WON'T START. WE BOUGHT IT A SAM'S CLUB LAST YEAR AND PROBABLY HAS ONLY BEEN USED ABOUT 4 TIMES. PLEASE ADVISE.
Hello:
Have you tried changing the gas, Especially, if it has been in the machine of a while. Also some Honda engines will not start if the oil is low. Also try removing the high pressure hose before you start it? Do not run it very long without water flowing through the pump, though.
Sep 20, 2009 | Karcher Garden
Honda gas power pressure washer runs for awhile then cuts off.
did you pour all of the old gas out before you started to use it. Sometimes condensation builds up in gas tank when stored. You need to dump old gas an put in new gas.
Jul 27, 2009 | Honda Karcher G4000RH Pressure Washer
Losing pressure more and more often, especially
not quite sure where to get the parts, but if the pressure starts out ok and decreases as it runs, it is generally that the piston rings/seals are worn out, this can happen just from sitting up over the winter.
You can google Honda Pressure Washer Parts to find a supplier for the seals/rings
Jul 05, 2009 | Honda Garden
Garden Logo
412 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
