Which transformer is bad in my panasonic PT-47WX51E TV when it suts off when te picture starts to come on and you have to un plug it and plug it back in to get it to turn on again but it will still cut off the same way. IS it the flyback transformer or the ordianary transformer.
  • pbarnett2003 Apr 28, 2010
    thank you thay will help me out alot thank you very much.
  • 3,866 Answers
Probably a bad capacitor on the power supply board or a hvac relay stuck. I would need to look at the in nerds of the system if you wound not mind, take some closeup shots of the board inside. its really hard to say without the projection tv being looked at the most common with these are the convergence board giving out early and it makes the tv turn off.
1. check capacitors on power supply board.
2. check and verify power values from the HVAC
if you cannot do these steps you need to call a repairman.
thanks i sure hope this guides you to a solutions there is not 100 percent way to tell you what it is without a look.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Apr 28, 2010
Panasonic tv PT-47WX51E has green vertical lines,how do I get them out?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes are given with illustrations. You can get an idea about the fault to an extent.
Jul 27, 2015 | Panasonic Televison & Video
Should I replace my lamp for my Panasonic 1080i htd t.v. pt-50LC14
Replacing a lamp won't work. There is not even one lamp in your TV. I'm afraid the lightening has done more damage than can be repaired. Even when some tech manages to repair te error, the TV can have the next error in days or weeks.
Try reading something about ESD. Electro Static Discharge and what it does to electronics. Electrostatic discharge
Apr 25, 2015 | Panasonic Televison & Video
Panasonic PT-51hx40b projection TV powers off when I try to turn it on
Not sure if the transformer is bad or something on secondary side is pulling the voltage down--if replacing it cured the issue you did good.
If not try to disconnect at source on secondary side to see if with no load the voltage comes up.
Looking for either the xfmr to be bad or something shorted pulling the voltage it creates down.
May 14, 2012 | Panasonic Televison & Video
I bought a panasonic pt-50lcx7k tv. i press power and it starts to warm up(green blinking lite and i can hear fn kick in ) but no picture and green light flashes for about 5 min then powers off and i get 2...
theres a problem on the board of the tv set jsut go back to the service center for further check up of of the technician of the panasonic un plug the tv set for it can cause further damage
Mar 25, 2011 | Panasonic Televison & Video
Panasonic pt-53wx42f no sound
Pls go to the audio menu with the panasonic remote and be sure the speakers are on........you may also want to un plug and plug back after ten min to reset the tv. You may want to reset your cable box the same way
Jun 02, 2010 | Panasonic PT-53WX42 53" Rear Projection...
Can a blu ray dvd work with a panasonic pt-47wx51e?
Yes, you will need to hook it up just like a normal DVD.
If you can use the component inputs you will get a better picture.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Nov 28, 2009 | Panasonic PT-47WX51 47" Rear Projection...
My panasonic tv pt-47wx51e color looks like 3d how can i fix this
There is a convergence kit available for your model which contains the new ICs and resistors plus the instructions of how to install the repair kit on CD. Heres a link look under Panasonic repair kits and you will see your model listed.
www.tvrepairkits.net
Jun 26, 2009 | Panasonic PT-47WX51 47" Rear Projection...
No hdmi input?
You can use the component inputs on your Tv which is almost as good.
Mar 30, 2009 | Panasonic PT-47WX51 47" Rear Projection...
BLACK LINES ACROSS THE SCREEN Panasonic PT-47WX51E
Replace c7136 & c7154 on A board This should clear up your problem
Dec 11, 2008 | Panasonic PT-47WX51 47" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
