Question about Bernina 1008
Bernina 800d sewing machine
How do I thread my bernina 800d sewing machine
  • Bernina Master
  • 11,774 Answers
If it is a Bernina 800DL overlocker, the user manual is available for download at the bernina.com web site. Select "Support" and scroll down to Search Support Info for Bernina models. Once you download, you can enlarge the pictures on your computer screen as sometimes the photos are difficult to see in the book. Be sure to thread in the order as instructed. Guaranteed, your machine will not work if you do not thread in the proper order.
1. UPPER LOOPER FIRST
2. LOWER LOOPER SECOND, and the THREAD TAIL MUST CROSS OVER THE UPPER LOOPER AT THE LAST STEP.
3. Then thread the needles.
If any of threads are not fully seated in the tension disks, you will have issues.
Posted on Apr 02, 2015
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 48 Answers
The machine has a diagram (thread route) inside the front cover if you can follow the coloured dots through the thread guides you do not need a manual
I reccommend threading the upper looper first from thread stand (second thread on right) up to telescoping thread guide down to the appropriate guide (see coloured chart inside the front cover)
follow the coloured dots through the thread guides to the upper looper. Likewise with lower looper.
On the lower looper there is a small white catch, when the machine is advanced by turning the hand wheel so that the looper is furthest to right , that catch can be pulled down and the thread directed into the appropriate guide then it should be retracted upward thus allowing the lower looper thread to move to the left. Then complete the threading through the hole in the end of the lower looper.
Threading the needles is fairly straight forward making sure the needles,are in all the way up so that the left needle is higher than right needle once completed rotate hand wheel so that needles are in upper position, gently pull all the threads under the presser foot and off to left side.
As a rule of thumb the looper tensions should be set at a slightly lower number than the needles or the needle tensions at a slightly higher number
Posted on Apr 01, 2015
  • 107 Answers
You might take a look on ebay item with bernina 700d/800dl instruction manual
Posted on May 02, 2010
How do you thread the bernina 1230
You can probably use the manual for the 1260. Sewing machines basically thread alike from one model to the next.
One thing to remember: ALWAYS RAISE the presser foot when threading the top thread! This will help prevent those dreaded thread nests under the fabric.
BERNINA Sewing Systems (in the Out of Print section)
Jul 25, 2017 | Bernina Sewing Machines
The bobbin assembly has a lot of tangled up thread and is jammed. How do I clear it?
Avoid attempting to run the motor if the machine is bound--it may damage the motor.
Remove the presser foot and, if you can, remove the needle. Then remove the needle plate, the bobbincase, and the hook. If you are unable to remove some of them, you may need to use a small pair of scissors to snip the threads and gently pull them out with needlenose pliers or tweezers.
Once you have the thread tangle removed, clean with a soft brush to remove all the lint and thread bits and place a drop of good quality sewing machine oil (preferably Bernina oil for your machine) on the bobbin race. Install a brand new needle (in case the old one was damaged).. RAISE the presser foot, remove all the thread, and rethread from the very beginning. (The raised presser foot releases the tension disks so the thread will seat properly.) Use good quality thread--avoid old or bargain bin thread (some Berninas object strenuously to Coats & Clark thread too). Some threads create heavy lint buildup in the tension disks and bobbin area in addition to hanging up in the needle and elsewhere. Also, some fabrics shed more (ie fleece), so be sure to clean often. Try to oil your machine as instructed in the owner's manual--every time you change a bobbin, after 8 hours of constant sewing, or every 6 months if not in regular use.
When Thread is Caught in Sewing Machine Sewing Lessons
How to Fix Thread Jam Sewing Machine
Anyone have experience with jammed bernina sewing machine Discussions...
Having trouble with my new Bernina 820
This video may help avoid thread nesting:
How and Why to Bring up the Bobbin Thread
Oct 21, 2015 | Bernina Sewing Machines
How do I thread the Bernina Overlocker
Depends on your serger model. Best idea is consult the owner's manual. Some manuals are available for download on Bernina's web site (look under Support). Be sure to thread in the order specified in the manual. Usually the upper looper is first, then the lower looper second, then the needles. (Hint: The lower looper thread ALWAYS lays over the top of the upper looper thread in the final looper threading step.)
You can also download a serger workbook too.
BERNINA of America Premium Swiss quality sewing machines BERNINA
Aug 25, 2015 | Bernina Sewing Machines
Thread for a rolled hem on the bernina 800d
HI
I would reccommend regular serger thread for the right needle (left needle is removed) and the lower looper. and use wooly nylon in the upper looper
The tensions on the needle should remain at 5-6 upper looper thread tension should be about 3-4
and the lower looper tension at about 8
contact me at Sewaway@shaw.ca if you have further quetions
Wayne Buss
Apr 22, 2010 | Sewing Machines
Machine is threaded but the needle will not pick up the bobbin thread. How do I fix on my bernina 65 machine?
Make sure the needle is not bent and is threaded from the front to the back.
The needle should be installed with the flat side of the needle shaft facing the back of the sewing machine.
Lower & raise the threaded needle, holding onto the end of the thread.
Then begin to sew.
If this does not help, then it may be the timing needs to be adjusted and this has to be done by a Bernina repair tech.
Apr 20, 2010 | Bernina Bernette 75
Bernette 800D seized up
Please don't use WD40 on your sewing machine, WD40 is an alcohol based cleaner and will do the opposite of lubricate. Take your machine to a certified Bernina Repair shop, they will have a look at the timing and lubricate all of your gears. Lubricant will dry out over time, grease turns to putty and oils turn to varnish after several years of non-service. Lint is attracted to moisture, moisture being those key areas of any machine. Lint acts like an oil wick and will draw out your lubricant from key areas. It then begins to attract dust and other nasty things over the years to become grit. Your motor begins to burn out due to stress trying to move all of these clocked gears, cams and shafts. Take your machine in!
Sep 16, 2008 | Bernina Bernette 75
Sewing Machines Logo
476 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
