Question about Acer Aspire 3690 Notebook
Acer Laptop; Black screen. Replacement part?
My Acer laptop has acted up for awhile now. It will power up and stay on, but the screen stays black. I used to be able to get a picture on the screen if I squeezed the top corners of the screen really hard (horrible thing to do, I know lol) but as soon as I released pressure it would turn black. Now it wont even show the screen when I do that. I hooked it up to an external monitor and it worked fine. What part (or parts) need to be replaced?
Thank you in advance for your help! :)
  • Lauren Hagee
    Lauren Hagee Apr 28, 2010
    Thank you! That was very helpful!
  • Acer Master
  • 1,606 Answers
Your problem can be caused by the back-light bulb, the inverter board but also the connector.
Because the squeeze works that can be the connector or the ribbon cable that feeds up along the side of the display. To check those you have to take apart the display and check the connections to see if they are loose or the cable damaged. Usually the connector at the bottom of the screen is the one that gets worked loose by the screen being shut. You just need to unplug and plug the connectors back in. It can also be a grounding screw or strap that is screwed in by the lower left corner under the hinges.
If that doesn't check out to be the problem then you can move on to replacing the inverter board and/ or the CCFL emitter..The board is worth about $60 and the CCFL about $12. The board is a PK070005T00 or a PK070007U00.
I don't know where you are located so I can't provide a url for someone close. There are plenty of good sources for these parts so it is good to keep shipping down and order from someone close to home. To find someone just search using google or bing and the words Acer Aspire parts or Acer replacement parts. You will find quite a few so once you find one then look for the parts listed for your Acer. Then make a note of availability and shipping. And have a look for instructions on the website. Some parts places will have either videos or pictorial instructions showing you how to replace the parts. This isn't hard other than the trick of getting the plastic apart without resorting to a hammer.
So you may find that the parts will come from one place but another has the instructions. It should take you about a half hour to change the parts and get things back together. As a suggestion it is worth ordering a new battery or other parts at the same time.
Here are a couple of links to repair parts, but i would still recommend searching for a close one.
http://www.laptoprepairparts.com/html/LRsearchmodelresults.asp?brand=toshiba&model=A8-&txt=Tecra A8 Series (A8-EZ8314, A8-EZ8411, A8-EZ8412, A8-EZ8413, A8-EZ8414, A8-EZ8415, A8-EZ8511, A8-EZ8512, A8-EZ8513, A8-EZ8514, A8-ST3612)
http://www.lcdparts.net/ccflDetail1.aspx?ProductCCFL=MSLACER154W
Posted on Apr 28, 2010
Black screen when power on my acer laptop
hi
try to isolate using external monitor,
check connection of lcd cable
replaced lcd panel
Apr 07, 2014 | Acer Aspire 5241 5251 5332 5334 5338 5516...
Laptop hp6730b when powered on the flash lock iconA and the flashing icon1 appears and the screen is black and want boot
Being an Hp, it has overheated and unsoldered the GPU from the board. Remove the main board and send it away for a GPU re-balling repair. Take a look on ebay for the re-balling service in your country.
Mar 08, 2014 | HP Compaq 6730b Notebook PC
Laptop black out
When the following situations, you need to replace the LCD inverter:
No image on the screen, but the power light stays on
Dark display but still readable
Between the screen flashes on and off 1/2 to several seconds
Power light stays on, but no display and sound
No image on the screen, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
More:http://www.lcdinverter.info/acer-travelmate-8001-lcd-inverter-p-2046.html
Aug 08, 2013 | Acer Computers & Internet
I have the acer aspire 5536-5112 black screen
I solve this using Fn + F6, using a 5536 model. Just press Fn + F6, keep holding it and hit the power button, wait for about 5 or 7 seconds, release the Fn and F6 keys. thank you so much guys!
Oct 19, 2012 | Acer Aspire Computers & Internet
The screen stays black on my acer 4520
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Sep 29, 2012 | Acer Aspire One PC Notebook
Once it is turn on it stays on a black screen
check your cd/dvd rom drive for a disk. Remove any USB devices, and reboot.
good luck
May 23, 2009 | Acer Aspire 3680 Laptop
Screen stays black when powered on
I replaced my screen on my 5570z, i purchased it off of ebay for 130.00 shipped, but make sure you check out there feedback, and make sure they have a ZERO dead pixel return policy. Some are sneaky and will not let you return it if you have less than 3 dead pixels.
May 17, 2009 | Acer Aspire 3680-2022 PC Notebook
Power comes on but the screen stay`s black dose it have a screen lock or stand by
Black screens can be caused by many things the first bit of video runs through the ram, so try changing the ram or swaping it. the next thing that causes a black screen is the LCD Inverter or the back light bulb to test this is take a flash light and shine it on the screen at an angle and see of you can make any faint images out. Next dis-assemble the laptop and see if the processor is heating up or staying cool.
Hope this helps!
May 02, 2009 | Acer Aspire 1640Z Notebook
Black Screen
look man ACER laptops are the best laptops in the world ! you didn't take care about it ! so don't blame them UNDERSTAND !
Jan 06, 2009 | Acer Aspire 3610 Notebook
Acer Aspire 3690 Notebook Logo
74 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
